在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2174|回复: 2
[讨论] uvm1.2中default_sequence问题
发表于 2020-7-2 23:13:02 | 显示全部楼层 |阅读模式
function void uvm_sequencer_base::build();
  int dummy;
  super.build();
  `ifndef UVM_NO_DEPRECATED
  // deprecated parameters for sequencer. Use uvm_sequence_library class
  // for sequence library functionality.
  if (uvm_config_string::get(this, "", "default_sequence", default_sequence)) begin
    `uvm_warning("UVM_DEPRECATED",{"default_sequence config parameter is deprecated and not ",
                 "part of the UVM standard. See documentation for uvm_sequencer_base::start_phase_sequence()."})
    this.m_default_seq_set = 1;
  end
endfunction
uvm1.2中uvm_sequencer_base.svh中看到如上代码,什么意思?是不是我们常用的如下设置default_sequence的方法不能用了吗?
virtual function void build_phase(uvm_phase phase);
      super.build_phase(phase);
      uvm_config_db#(uvm_object_wrapper)::set(this,
                                              "i_agt.sqr.main_phase",
                                              "default_sequence",
                                               my_sequence::type_id::get());
endfunction
发表于 2020-7-3 12:20:55 | 显示全部楼层
过时了~~未来会被删除~
 楼主| 发表于 2020-7-3 22:40:13 | 显示全部楼层
A1985 发表于 2020-7-3 12:20
过时了~~未来会被删除~
uvm1.2推荐的方法是怎么样的?
GMT+8, 2024-4-27 10:41 , Processed in 0.017856 second(s), 7 queries , Gzip On, Redis On.
