在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 4200|回复: 10
[求助] check tluplus file 出现error
发表于 2020-4-12 08:25:48 | 显示全部楼层 |阅读模式
100资产
最近使用smic 180工艺库,在使用ICC时,set tluplus_max以及tluplus_min,
tluplus max:smiclog018_6lm_cell_max.tluplus
tluplus min: smiclog018_6lm_cell_min.tluplus
tf files      :smic18_6lm.tf
图一、 itf  file
  图二、tf file
自己写了一个map文件,如下:
#conducting layers
metal1 metal1
metal2 metal2
metal3 metal3
metal4 metal4
metal5 metal5
metal6 metal6
poly poly
polyCont polyCont
#via layers
via1 via1
via2 via2
via3 via3
via4 via4
via5 via5
但是
check_tlu_plus_files的时候,总是报一下错误:
Error: Layer "METAL1" (metal1) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "METAL2" (metal2) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "METAL3" (metal3) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "METAL4" (metal4) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "METAL5" (metal5) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "METAL6" (metal6) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
----------------- Check Ends ------------------
0
 楼主| 发表于 2020-4-12 18:39:49 | 显示全部楼层
原来是自己的map文件写的有问题,正确的格式为:
conducting_layers
metal1 metal1
metal2 metal2
metal3 metal3
metal4 metal4
metal5 metal5
metal6 metal6
poly poly
via_layers
via1 via1
via2 via2
via3 via3
via4 via4
via5 via5
polyCont polyCont
//---------------------分割线------------------------------//
ps:上述map文件中的via_layers 以及conducting_layers 不能省去,且添加时,应该注意下划线不能省去。最终check_tlu_plus_file  successfully
 楼主| 发表于 2020-4-12 08:26:57 | 显示全部楼层
请教各位大佬,能够告知是什么原因,按照ICCuser guide 写的map,看到论坛其他小伙伴也遇到这样的问题,但是给出的解决方案,我检查了,都是正确的
 楼主| 发表于 2020-4-12 18:38:52 | 显示全部楼层
conducting_layers
metal1 metal1
metal2 metal2
metal3 metal3
metal4 metal4
metal5 metal5
metal6 metal6
poly poly
via_layers
via1 via1
via2 via2
via3 via3
via4 via4
via5 via5
polyCont polyCont
发表于 2020-7-3 15:24:19 | 显示全部楼层
我也是这个问题,按照你的方法修改了也成功解决了,感谢。
发表于 2021-1-24 14:35:50 | 显示全部楼层
tf文件里面不是对应的大写的METAL1吗?我看答主map写的是小写,求问。
发表于 2021-2-6 02:16:36 | 显示全部楼层
great solution ~~~ I met the same problem and solved right away.
发表于 2021-4-16 09:37:48 | 显示全部楼层
发表于 2022-2-16 13:47:46 | 显示全部楼层
可以用,谢谢楼主
发表于 2022-3-22 16:16:45 | 显示全部楼层
这个tf文件不能做place_opt,没有RC model
GMT+8, 2024-4-26 11:48 , Processed in 0.043511 second(s), 9 queries , Gzip On, Redis On.
