在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1971|回复: 3
[求助] ICC中电源PAD连接不上core power ring,Warning: wire dropped because obstruction。
发表于 2019-12-20 11:03:34 | 显示全部楼层 |阅读模式
在icc中,通过preroute_instances -primary_routing_layer preferred -preferred_routing_layer high命令,将电源PAD的引脚同core power ring相连接的时候, 遇到一堆的 warning如下:
WARNING: FAIled to make a connection for the following pin:
((1728.520, 1007.905) (2035.995, 1010.105))(Net: VDD)(wire on layer: M4 [64])
Warning: wire dropped because obstruction,((2036.070 1007.905) (2036.220 1010.105)) (Net: VDD) (Layer: M3 [63]) isblocked by ((1729.930 930.200) (2035.995 2037.060)) (Net: null) (Layer: M3[63]). (PGRT-030)
WARNING: Failed to make a connection for the following pin:
((1728.520, 1553.955) (2035.995, 1556.155))(Net: VDD)(wire on layer: M4 [64])
Warning: wire dropped because obstruction,((2036.070 1553.955) (2036.220 1556.155)) (Net: VDD) (Layer: M3 [63]) isblocked by ((1729.930 930.200) (2035.995 2037.060)) (Net: null) (Layer: M3[63]). (PGRT-030)
导致
电源PAD的引脚同core power ring连接不上,请问这个问题怎么解决啊??????
求高手指点啊!!!!!
发表于 2020-12-15 11:15:33 | 显示全部楼层
请问解决了吗,我也遇到这个问题了
发表于 2020-12-16 17:52:35 | 显示全部楼层
被route guide挡住了吧,检查下这里有没有route guide, 手动连一下呢
发表于 2020-12-17 09:53:48 | 显示全部楼层
没有route guide的。现在手动连了,只是每次自动连线都报这个错
GMT+8, 2024-4-27 06:30 , Processed in 0.022610 second(s), 7 queries , Gzip On, Redis On.
