在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 4098|回复: 3
[原创] PROFINET-IO stack
发表于 2019-11-4 20:26:43 | 显示全部楼层 |阅读模式
2.2 Stack-Supported PROFINET-IO Functionality
The PROFINET-IO stack enables an "automatic operation controller" application (programmable
logic controller, adapter card, robot controller, machine control system etc.) to be created on the
PROFINET network. It manages full communication with all devices configured for exchanging
process data.
The PROFINET-IO stack enables:
• Cyclic functionality (RT_CLASS_1):
o Exchange of input/output data with connected devices
o The connection configuration supports:
o 1 AR
o 1 input CR
o 1 output CR
o 1 alarm CR
• Acyclic functionality
o Reading of diagnostic information contained in the devices
o Device configuration
o Writing of configuration parameters
o Acyclic access to device "record data"
o Management of device-generated alarms
• General functionality
o RPC support for PROFINET
o DCP support
profinetIO
profinetIO
profinetIO
profinetIO
 楼主| 发表于 2019-11-8 22:58:18 | 显示全部楼层
提供molex profinet IO  开发技术
发表于 2020-5-8 00:02:44 | 显示全部楼层
你好,你电话或QQ是多少啊,咨询Profinet IO
发表于 2020-5-8 00:04:05 | 显示全部楼层
你好,请问你的QQ?  我联系你。
GMT+8, 2025-7-3 15:53 , Processed in 0.017144 second(s), 9 queries , Gzip On, MemCached On.
