在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2655|回复: 8
[讨论] siliconsmart IO单元表征问题,求大神指教
发表于 2019-3-22 12:37:25 | 显示全部楼层 |阅读模式
不晓得为什么泄漏功耗显示是0值?  还有一个问题是仿真报 Error: <class 'SimBrAcquisition.FailedMeasurement'> 错误,希望各位大神指点迷经 !   表征的IO单元是PIDW
Info:    Fri Mar 22 11:42:43 CST 2019: Begin characterize stage
Info:    Simulator used is hspice F-2011.09-SP2
Info:    Simulator command is /opt/EDA_Tools/synopsys/F-2011.09-SP2/hspice/bin/hspice
Info:    Optimizing cell order for efficiency...
Info:    Checking templates...
Info:    Loading information for 1 cell... (SMSC-61)
Info:    Start generating characterization tasks. ... (SMSC-63)
Info:    Generated 3 tasks. Bundling tasks into jobs and submitting... (SMSC-64)
Info:    Characterization starting, distributing work via adaptive job manager... (IOSH-29)
Info:    Using 5 standalone slots
Info:    [CDPL] Tasks: 0/3, (0.0%, 0 Cached, 0 Failed); Active Workers: 1, Pending Workers: 2, Elapsed: 0m00s
Warning: PIDW::VDD33: leakage current is negative for state 'none'. Parameter replace_negative_leakage_with (0) will be used to model leakage power
Warning: PIDW: leakage_power__ACQ_1 state: none: leakage current does not sum to 0 (tolerance 1.0e-6)
Info:    [CDPL] Tasks: 1/3, (33.3%, 0 Cached, 0 Failed); Active Workers: 3, Pending Workers: 0, Elapsed: 0m30s
Warning: Simulation delay__PAD__hl__C__hl__ACQ_1.sif for cell PIDW failed. (SMSC-105) (PIDW::delay__PAD__hl__C__hl__ACQ_1)
Warning: Error: <class 'SimBrAcquisition.FailedMeasurement'>: Failed measurement for ['Tout__C__hl', 'delay__PAD__hl__C__hl'] in PIDW::delay__PAD__hl__C__hl__ACQ_1  Failed sweep: ['slew_PAD', 'max_load_C', 'load_C', 'delay_view', 'energy_view', 'process_tag', 'temperature_tag', '__param_VDD', '__param_VDD33', '__param_VDD33:', '__param_VSS', '__param_VSSD', '__param_VSSD:', 'voltage_tag'] [5.6e-11, 4e-14, 4e-15, 1, 1, "'SP013D3W_V1p4_typ'", 25.0, 1.2, 3.3, 3.3, 0.0, 0.0, 0.0, "'__param_VDD:__param_VDD33:__param_VDD33::__param_VSS:__param_VSSD:__param_VSSD:'"] (PIDW::delay__PAD__hl__C__hl__ACQ_1)
Warning: Task 2 (delay__PAD__hl__C__hl__ACQ_1 of PIDW) failed on W3 on debian
Info:    [CDPL] Re-submitting delay__PAD__hl__C__hl__ACQ_1 of PIDW (1/1)
Info:    [CDPL] Tasks: 2/4, (50.0%, 0 Cached, 0 Failed); Active Workers: 3, Pending Workers: 0, Elapsed: 1m00s
Info:    [CDPL] Tasks: 2/4, (50.0%, 0 Cached, 0 Failed); Active Workers: 3, Pending Workers: 0, Elapsed: 1m30s
Warning: Simulation delay__PAD__lh__C__lh__ACQ_1.sif for cell PIDW failed. (SMSC-105) (PIDW::delay__PAD__lh__C__lh__ACQ_1)
Warning: Error: <class 'SimBrAcquisition.FailedMeasurement'>: Failed measurement for ['Tout__C__lh', 'delay__PAD__lh__C__lh'] in PIDW::delay__PAD__lh__C__lh__ACQ_1  Failed sweep: ['slew_PAD', 'max_load_C', 'load_C', 'delay_view', 'energy_view', 'process_tag', 'temperature_tag', '__param_VDD', '__param_VDD33', '__param_VDD33:', '__param_VSS', '__param_VSSD', '__param_VSSD:', 'voltage_tag'] [5.6e-11, 4e-14, 4e-15, 1, 1, "'SP013D3W_V1p4_typ'", 25.0, 1.2, 3.3, 3.3, 0.0, 0.0, 0.0, "'__param_VDD:__param_VDD33:__param_VDD33::__param_VSS:__param_VSSD:__param_VSSD:'"] (PIDW::delay__PAD__lh__C__lh__ACQ_1)
Warning: Task 1 (delay__PAD__lh__C__lh__ACQ_1 of PIDW) failed on W2 on debian
Error:   Simulation delay__PAD__hl__C__hl__ACQ_1.sif for cell PIDW failed. (SMSC-105) (PIDW::delay__PAD__hl__C__hl__ACQ_1)
Error:   Error: <class 'SimBrAcquisition.FailedMeasurement'>: Failed measurement for ['Tout__C__hl', 'delay__PAD__hl__C__hl'] in PIDW::delay__PAD__hl__C__hl__ACQ_1  Failed sweep: ['slew_PAD', 'max_load_C', 'load_C', 'delay_view', 'energy_view', 'process_tag', 'temperature_tag', '__param_VDD', '__param_VDD33', '__param_VDD33:', '__param_VSS', '__param_VSSD', '__param_VSSD:', 'voltage_tag'] [5.6e-11, 4e-14, 4e-15, 1, 1, "'SP013D3W_V1p4_typ'", 25.0, 1.2, 3.3, 3.3, 0.0, 0.0, 0.0, "'__param_VDD:__param_VDD33:__param_VDD33::__param_VSS:__param_VSSD:__param_VSSD:'"] (PIDW::delay__PAD__hl__C__hl__ACQ_1)
Error:   Task 3 (delay__PAD__hl__C__hl__ACQ_1 of PIDW) failed on W1 on debian
Info:    [CDPL] Re-submitting delay__PAD__lh__C__lh__ACQ_1 of PIDW (1/1)
Info:    [CDPL] Tasks: 4/5, (80.0%, 0 Cached, 1 Failed); Active Workers: 3, Pending Workers: 0, Elapsed: 2m00s
Info:    [CDPL] Tasks: 4/5, (80.0%, 0 Cached, 1 Failed); Active Workers: 3, Pending Workers: 0, Elapsed: 2m30s
Info:    [CDPL] Tasks: 4/5, (80.0%, 0 Cached, 1 Failed); Active Workers: 3, Pending Workers: 0, Elapsed: 3m00s
Error:   Simulation delay__PAD__lh__C__lh__ACQ_1.sif for cell PIDW failed. (SMSC-105) (PIDW::delay__PAD__lh__C__lh__ACQ_1)
Error:   Error: <class 'SimBrAcquisition.FailedMeasurement'>: Failed measurement for ['Tout__C__lh', 'delay__PAD__lh__C__lh'] in PIDW::delay__PAD__lh__C__lh__ACQ_1  Failed sweep: ['slew_PAD', 'max_load_C', 'load_C', 'delay_view', 'energy_view', 'process_tag', 'temperature_tag', '__param_VDD', '__param_VDD33', '__param_VDD33:', '__param_VSS', '__param_VSSD', '__param_VSSD:', 'voltage_tag'] [5.6e-11, 4e-14, 4e-15, 1, 1, "'SP013D3W_V1p4_typ'", 25.0, 1.2, 3.3, 3.3, 0.0, 0.0, 0.0, "'__param_VDD:__param_VDD33:__param_VDD33::__param_VSS:__param_VSSD:__param_VSSD:'"] (PIDW::delay__PAD__lh__C__lh__ACQ_1)
Error:   Task 4 (delay__PAD__lh__C__lh__ACQ_1 of PIDW) failed on W3 on debian
Info:    [CDPL] Tasks: 5/5, (100.0%, 0 Cached, 2 Failed); Active Workers: 3, Pending Workers: 0, Elapsed: 3m30s
Info:    [CDPL] Summary:
Info:    Failed tasks:
Info:      PIDW:
Info:          delay__PAD__hl__C__hl__ACQ_1
Info:          delay__PAD__lh__C__lh__ACQ_1
Info:    Fri Mar 22 11:46:13 CST 2019: Done characterize stage (Elapsed: 210 seconds | 0.06 hours  Memory: 613.08MB)
Info:    ===========================================================================================================
发表于 2019-3-22 12:45:14 | 显示全部楼层
你是研究生吗
 楼主| 发表于 2019-3-22 12:57:08 | 显示全部楼层
日   你个瓜皮
发表于 2019-3-22 12:59:30 | 显示全部楼层
asic405 发表于 2019-3-22 12:57
日   你个瓜皮
院长记下你的名字了,叫你留下来
 楼主| 发表于 2019-3-22 20:17:33 | 显示全部楼层
各路大神   能否给点设置提取IO PAD cell的关键点     也不知道自己错在哪了     感觉跟BUF功能差不多   但一样的过程,会报上面的错误    还请大神指点
发表于 2021-6-11 09:39:00 来自手机 | 显示全部楼层
解决了吗 我也遇到了这个问题
发表于 2023-9-4 16:06:08 | 显示全部楼层
大佬,后来这个问题怎么解决的啊?我也遇到了相同的问题,还请不吝赐教,谢谢!
发表于 2024-1-12 14:19:24 | 显示全部楼层
楼主,解决了吗
发表于 2024-4-11 15:11:38 | 显示全部楼层
我也遇到这个问题,后面发现王表里的SCA值太大,重新提了网表,SCA变小了很多就不报错了
GMT+8, 2024-4-26 08:43 , Processed in 0.026630 second(s), 6 queries , Gzip On, Redis On.
