在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1492|回复: 1
[求助] set_dft_signal -type 的定义
发表于 2019-1-15 14:10:10 | 显示全部楼层 |阅读模式
请教一个问题,set_DFT_signal -type TestMode 和 set_dft_signal -type constant有什么区别吗?在实际testmode他们都是为1的
发表于 2020-12-27 21:29:06 | 显示全部楼层
The primary difference between Constant and TestMode signal definitions is as follows:
(1)Constant signal definitions specify the value of the signal in test mode, but they do not specify anything about the signal's value in functional mode:
(2)TestMode signal definitions specify the value of the signal in both test mode and functional mode:
GMT+8, 2024-4-27 12:19 , Processed in 0.015839 second(s), 6 queries , Gzip On, Redis On.
