查看: 2245|回复: 0
[求助] TetraMAX中获取输出端口的实际值
发表于 2018-4-16 16:00:56 | 显示全部楼层 |阅读模式
TetraMAX在测试向量生成的过程中,有fault simulation 的过程
,现在由于实验需要,需要获取primary outputfault simulation过程中得到的实际输出值,查阅用户手册发现一个命令:
Set_pindata -fault_sim_results<pin_pathname | gate pin_number> <0|1> pattern
相关的解释是:
This displays the good machine value and faulty machine value for aselected fault and a selected pattern. If they are different, the good machinevalue is given first followed by the faulty value separated by a slash"/". If there is no difference, only the good machine value isdisplayed. Selecting fault_sim_results is not supported if the -nobasic_scanoption of the set_simulation commandhas been used.
我认为通过这个命令可以获得实际的值,但是在实际运行过程中,出现了如下问题:
1.请问命令中的pattern位置应该输入什么样的数据?
2.这种方法是否可以正确获得真实输出值?
GMT+8, 2025-11-5 02:22 , Processed in 0.012979 second(s), 5 queries , Gzip On, Redis On.
