在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3596|回复: 3
[求助] Foemality遇到 loop问题,存在aborted points该怎么解决
发表于 2018-2-3 15:13:53 | 显示全部楼层 |阅读模式
Foemality遇到 loop问题,存在aborted points该怎么解决,验证报告如下:
*********************Verification
Results *********************
Verification INCONCLUSIVE
(Equivalence checking aborted due to complexity)
   ATTENTION:  synopsys_auto_setup mode was enabled.
               See Synopsys Auto Setup Summary for details.
Reference design: r:/WORK/TOP
Implementation design: i:/WORK/TOP
1829 Passing compare points
686 Aborted compare points
0 Unverified compare points
Matched Compare Points    BBPin   Loop  BBNet   Cut    Port    DFF   LAT   TOTAL
Passing (equivalent)
0        0    0
0      2      1827       0
1829
Failing (not equivalent)
0        0       0              0       0
0         0       0
Aborted
  Loop  (cycle-driven)               0        0        0               0       0       686       0     686
验证结果如图:
发表于 2018-2-4 20:30:23 | 显示全部楼层
先检查一下lint错误,存在combinational loop?
 楼主| 发表于 2018-2-6 09:54:45 | 显示全部楼层
回复 2# haoyz
loop是由于设计中的异步逻辑导致的,但在setup阶段做了以下设置,结果还是一样
set verification_asynch_bypass true
set verification_auto_loop_break false
发表于 2023-7-12 21:28:41 | 显示全部楼层
同问,请问群主解决了么
GMT+8, 2024-5-15 01:06 , Processed in 0.021928 second(s), 8 queries , Gzip On, Redis On.
