在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 4091|回复: 4
请问一个指令
发表于 2007-6-22 16:49:58 | 显示全部楼层 |阅读模式
mips的启动代码中开始的时候出现了一条指令:
bal 1f#请问这条指令是什么意思呢,跳转到1:这个位置
1:li  t0,1fff
 楼主| 发表于 2007-6-25 13:40:34 | 显示全部楼层
没人回答,!我现在知道什么意思了贴出来,大家共勉吧!
我最初不知道的是,bal 1f
1f 是什么意思,答案终于在see mips run chapter 9上找到了!
In code you can use a number (decimal between 1 and 99) as a label.
This is treated as temporary, and you can use the same number as
many times as you like. In a branch instruction “1f” (forward) refers to the next “1:” label in the code and “1b” (back) refers to the previous “1:”label. This saves you thinking about names for little branches and loops.Reserve named labels for subroutine entry points or for exceptionally big jumps
摘自 see mips run 251 -252
That's all!
 楼主| 发表于 2007-6-25 13:55:01 | 显示全部楼层
大家,一起探讨阿
 楼主| 发表于 2007-6-25 13:56:24 | 显示全部楼层
我是做broadcom网络通信的
发表于 2015-2-8 15:00:08 | 显示全部楼层
回复 2# hanlin11
   赞。
GMT+8, 2024-4-26 19:50 , Processed in 0.020694 second(s), 8 queries , Gzip On, Redis On.
