在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3005|回复: 10
[资料] 自己编译的Verilog代码美化工具istyle 1.21
发表于 2017-8-27 17:28:12 | 显示全部楼层 |阅读模式
istyle.rar (413.52 KB, 下载次数: 87 )
发表于 2017-8-27 19:43:11 | 显示全部楼层
kankan
发表于 2017-8-27 21:03:20 | 显示全部楼层
怎么用?
发表于 2017-8-28 10:04:23 | 显示全部楼层
谢谢分享!
发表于 2017-8-28 20:33:42 | 显示全部楼层
bei defender jiezhu
发表于 2017-8-29 15:37:49 | 显示全部楼层
回复 1# xixilu
    thanks
发表于 2017-9-5 11:06:56 | 显示全部楼层
咋用啊
发表于 2017-9-15 09:14:19 | 显示全部楼层
比较 好奇 看看!!
发表于 2018-6-3 17:52:01 | 显示全部楼层
xie xie ni de code
发表于 2019-1-11 22:43:43 | 显示全部楼层
iStyle 1.21 (Fast and Free Automatic Formatter for Verilog Source Code)
(Created by haimag, Report Bugs: haimag@gmail.com) (Thanks to Tal Davidson & Astyle) Originally hosted at http://code.google.com/p/istyle-verilog-formatter before Google Code EOL
Usage  :  iStyle [options] Foo.v  B*r.v  [...]
When indenting a specific file, the resulting indented file RETAINS the
original file-name. The original pre-indented file is renamed, with a
suffix of ".orig" added to the original filename.
By default, iStyle is set up to indent Verilog files, with 4 spaces per
indent, a maximal indentation of 40 spaces inside continuous statements,
and NO formatting.
Option's Format:
    Long options (starting with '--') must be written one at a time.
    Short options (starting with '-') may be appended together.
    Thus, -bps4 is the same as -b -p -s4.
Predefined Styling options:
    --style=ansi
    ANSI style formatting/indenting.
    --style=kr
    Kernighan&Ritchie style formatting/indenting.
    --style=gnu
    GNU style formatting/indenting.
Indentation options:
    -s   OR   -s#   OR   --indent=spaces=#
    Indent using # spaces per indent. Not specifying #
    will result in a default of 4 spacec per indent.
    -t   OR   -t#   OR   --indent=tab=#
    Indent using tab characters, assuming that each
    tab is # spaces long. Not specifying # will result
    in a default assumption of 4 spaces per tab.
    -T#   OR   --force-indent=tab=#
    tab is # spaces long. Force tabs to be used in areas
    iStyle would prefer to use spaces.
    -B   OR   --indent-brackets
    Add extra indentation to 'begin' and 'end' block brackets.
    -G   OR   --indent-blocks
    Add extra indentation entire blocks (including brackets).
    -m#  OR  --min-conditional-indent=#
    Indent a minimal # spaces in a continuous conditional
    belonging to a conditional header.
    -M#  OR  --max-instatement-indent=#
    Indent a maximal # spaces in a continuous statement,
    relatively to the previous line.
    -E  OR  --fill-empty-lines
    Fill empty lines with the white space of their
    previous lines.
    --indent-preprocessor
    Indent multi-line #define statements
Formatting options:
    -b  OR  --brackets=break
    Break brackets from pre-block code (i.e. ANSI C/C++ style).
    -a  OR  --brackets=attach
    Attach brackets to pre-block code (i.e. Java/K&R style).
    -o   OR  --one-line=keep-statements
    Don't break lines containing multiple statements into
    multiple single-statement lines.
    -O   OR  --one-line=keep-blocks
    Don't break blocks residing completely on one line
    -p   OR  --pad=oper
    Insert space paddings around operators only.
    --pad=paren
    Insert space paddings around parenthesies only.
    -l OR --pad=block
    Enclose one statement in a begin-end only for keyword if/else/while/for.
    -P   OR  --pad=all
    Insert space paddings around operators AND parenthesies.
    --convert-tabs
    Convert tabs to spaces.
    --break-blocks
    Insert empty lines around unrelated blocks, labels, ...
    --break-blocks=all
    Like --break-blocks, except also insert empty lines
    around closing headers (e.g. 'else', ...).
    --break-elseifs
    Break 'else if()' statements into two different lines.
Other options:
    --suffix=####
    Append the suffix #### instead of '.orig' to original filename.
    -n   OR  --suffix=none
    Tells Astyle not to keep backups of the original source files.
    WARNING: Use this option with care, as Astyle comes with NO WARRANTY...
    -X   OR  --errors-to-standard-output
    Print errors and help information to standard-output rather than
    to standard-error.
    -v   OR   --version
    Print version number
    -h   OR   -?   OR   --help
    Print this help message
    --options=####  OR --options=none
    Parse used the specified options file: ####, options=none, none
    parse options file, and not looks for parse options files
Default options file:
    iStyle looks for a default options file in the following order:
    1. The contents of the ISTYLE_OPTIONS environment
       variable if it exists.
    2. The file called .iStylerc in the directory pointed to by the
       HOME environment variable ( i.e. $HOME/.iStylerc ).
    3. The file called .iStylerc in the directory pointed to by the
       HOMEPATH environment variable ( i.e. %HOMEPATH%\.iStylerc ).
    If a default options file is found, the options in this file
    will be parsed BEFORE the command-line options.
    Options within the default option file may be written without
    the preliminary '-' or '--'.
GMT+8, 2024-4-27 02:04 , Processed in 0.031623 second(s), 7 queries , Gzip On, Redis On.
