查看: 2989|回复: 2
[讨论] 旧帖重提 oserdes 暂时性结论 并转串
发表于 2017-6-17 10:42:40 | 显示全部楼层 |阅读模式
目前还有一点问题:不过我会在后续讨论中完成,欢迎大家留帖发言,对我进行指导,大家可以一起讨论。
原帖网址:
http://bbs.eetop.cn/thread-443590-1-1.html
大家可以比较我跟原帖的不同之处,就是下面的一段话:
100MHz钟-->MMCM-->(CLK=500MHz钟,CLK_DIV=250MHz钟)-->OSERDES(DDR,8:1,并行数据=8'b10100111)-->500MHz数据时钟输出
源码如下:
module oserdes
      input  clk_in,
      input  reset_pll,
      input  reset_serdes,
      output[7:0] rstdly_show,
      output clkfbout,
      output clkout0,
      output clkout1,
      output TQ,
      output OFB,
      output TFB,
      output TBYTEOUT,
      output mmcm_lock,
      output CLK_TO_PINS_P,
      output CLK_TO_PINS_N
assign rstdly_show= rst_dly;
//wire        clkfbout;
//wire        clkout0;
//wire        clkout1;
wire        clkfbout_buf;
wire        clkin1;
wire        highspeed_clk;
wire        lowspeed_clk;
reg         IO_RESET;
reg  [7:0]  rst_dly;
wire        oserdes_out;
MMCME2_ADV #
        .BANDWIDTH            ("OPTIMIZED"),//
        .CLKOUT4_CASCADE      ("FALSE"),//
        .COMPENSATION         ("ZHOLD"),//
        .STARTUP_WAIT         ("FALSE"),//
        .DIVCLK_DIVIDE        (1),//设置中只能取1'b1;
        .CLKFBOUT_MULT_F      (10.000),//相乘100M*10=1000M
        .CLKFBOUT_PHASE       (0.000),//feed back
        .CLKFBOUT_USE_FINE_PS ("FALSE"),//相移使能
        .CLKOUT0_DIVIDE_F     (2.000),//2分频的意思吗?,多长了个F==500M
        .CLKOUT0_PHASE        (0.000),//
        .CLKOUT0_DUTY_CYCLE   (0.500),//
        .CLKOUT0_USE_FINE_PS  ("FALSE"),//相位移动
        .CLKOUT1_DIVIDE       (4.000),//4分频的意思吗?==250M
        .CLKOUT1_PHASE        (0.000),//
        .CLKOUT1_DUTY_CYCLE   (0.500),//占空比
        .CLKOUT1_USE_FINE_PS  ("FALSE"),//
        .CLKIN1_PERIOD        (10.0),//精度ns-ps
        .REF_JITTER1          (0.010)//抖动
U1_MMCM
     (  // Output clocks
        .CLKFBOUT            (clkfbout),
        .CLKFBOUTB           (),
        .CLKOUT0             (clkout0),
        .CLKOUT0B            (),
        .CLKOUT1             (clkout1),
        .CLKOUT1B            (),
        .CLKOUT2             (),
        .CLKOUT2B            (),
        .CLKOUT3             (),
        .CLKOUT3B            (),
        .CLKOUT4             (),
        .CLKOUT5             (),
        .CLKOUT6             (),
        // Input clock control
        .CLKFBIN             (clkfbout_buf),
        .CLKIN1              (clkin1),
        .CLKIN2              (1'b0),
        // Tied to always select the primary input clock
        .CLKINSEL            (1'b1),
        // Ports for dynamic reconfiguration
        .DADDR               (7'h0),
        .DCLK                (1'b0),
        .DEN                 (1'b0),
        .DI                  (16'h0),
        .DO                  (),
        .DRDY                (),
        .DWE                 (1'b0),
        // Ports for dynamic phase shift
        .PSCLK               (1'b0),
        .PSEN                (1'b0),
        .PSINCDEC            (1'b0),
        .PSDONE              (),
        // Other control and status signals
        .LOCKED              (mmcm_lock),
        .CLKINSTOPPED        (),//
        .CLKFBSTOPPED        (),//
        .PWRDWN              (1'b0),//powerdown
        .RST                 (reset_pll)//
BUFG U2_BUFG
        .O (clkfbout_buf),
        .I (clkfbout)
BUFG U3_BUFG
        .O (highspeed_clk),
        .I (clkout0)
BUFG U4_BUFG
        .O (lowspeed_clk),
        .I (clkout1)
IBUFG U5_BUFG
     (  .I (clk_in),
        .O (clkin1)
OSERDESE2
         .DATA_RATE_OQ   ("DDR"),
         .DATA_RATE_TQ   ("SDR"),
         .DATA_WIDTH     (8),
         .TRISTATE_WIDTH (1),
         .SERDES_MODE    ("MASTER")
U6_SERDES
         .D1             (1'b1),
         .D2             (1'b1),
         .D3             (1'b1),
         .D4             (1'b0),
         .D5             (1'b0),
         .D6             (1'b1),
         .D7             (1'b0),
         .D8             (1'b1),
         .T1             (1'b0),
         .T2             (1'b0),
         .T3             (1'b0),
         .T4             (1'b0),
         .SHIFTIN1       (1'b0),
         .SHIFTIN2       (1'b0),
         .SHIFTOUT1      (),
         .SHIFTOUT2      (),
         .OCE            (rst_dly[4]),//output clk enable
         .CLK            (highspeed_clk),//
         .CLKDIV         (lowspeed_clk),//
         .OQ             (oserdes_out),//
         .TQ             (TQ),//
         .OFB            (OFB),
         .TFB            (TFB),
         .TBYTEIN        (1'b0),//
         .TBYTEOUT       (TBYTEOUT),//
         .TCE            (1'b0),//
         .RST            (IO_RESET)
OBUFDS
      #(.IOSTANDARD ("LVDS"))
obufds_inst
       (.O          (CLK_TO_PINS_P),
        .OB         (CLK_TO_PINS_N),
        .I          (oserdes_out)
always @ (posedge lowspeed_clk or posedge reset_serdes)
begin
    if(reset_serdes)
       begin
   IO_RESET <= 1'b1;
rst_dly  <= 8'b0000_0000;
end
    else
       begin
   IO_RESET <= 1'b0;
rst_dly[7:1] <= rst_dly[6:0];
rst_dly[0] <= 1'b1;
end
end
endmodule
仿真激励文件与原帖完全相同:
module sim();
localparam CLK100_PERIOD  = 10;   //in nSec
reg         clk_in;
reg         reset_pll;
reg         reset_serdes;
wire        mmcm_lock;
wire        CLK_TO_PINS_P;
wire        CLK_TO_PINS_N;
oserdes
  SIM (
           .clk_in        (clk_in),
           .reset_pll     (reset_pll),
           .reset_serdes  (reset_serdes),
           .mmcm_lock     (mmcm_lock),
           .CLK_TO_PINS_P (CLK_TO_PINS_P),
           .CLK_TO_PINS_N (CLK_TO_PINS_N)
// Stimulation Generation
initial
   begin
      reset_pll = 1'b1;
      #200
      reset_pll = 1'b0;
   end
initial
   begin
      reset_serdes = 1'b1;
      #1200
      reset_serdes = 1'b0;
   end
// Clock Generation
initial
      clk_in = 1'b0;
always #(CLK100_PERIOD/2.0) clk_in = ~clk_in;
endmodule
下面是我的总结与问题:
仿真图中显示:8位的并行数据转成了串行数据,且速率是1000M=clkout0*2,双倍速率采样的缘故。
时钟就三个:clk_in=100M,clkout0=500M,clkout1=250M;
目前的问题只有一个,哪个时钟来驱动输入的并行数据,并转串模块只有两个输入时钟,因此只能是clkout1=250M,它是串行数据速率的1/4,用来驱动并4转串1刚刚好。在本例中并8转串1也成功了,我猜是因为,clkout1上升沿给个8并行数据,然后开始转串,又来上升沿,串行工作只完成了一半,给的并行数据(此例中给的并行数据保持相同,后面的工作我会改正)被丢弃,然后又上升沿,正好串行工作完成。
我下面的工作就是论证我观点的正确与否了。希望大家关注,多多指教我。
 楼主| 发表于 2017-6-17 11:27:40 | 显示全部楼层
列位看官,此问题已经解决,我的猜想是正确的。
将clkout0的分频数由2改为1,clkout0由500M变为1000M,代码如下:
.CLKOUT0_DIVIDE_F     (1.000),
分析:此时clkout1仍然是250M,输出串行数据速率虽然是1000M,但是由于是DDR(上升沿下降沿都采样)双倍速率采样,1000M*2/250M=8,正好进行并8转串1的操作,刚好同步,由clkout1驱动输入并行数据。
为了方便测试验证我的说法,我在主程序中加入小段代码:
reg[7:0]datain;
begin
    if(reset_serdes)
        begin
            datain<=8'h01;
        end
    else
        begin
            datain<={datain[6:0],datain[7]};
        end
end
很简单哦,为了方便观察嘛。。。
然后把datain输入D1-D8,代码修改如下:
U6_SERDES
         .D1             (datain[0]),
         .D2             (datain[1]),
         .D3             (datain[2]),
         .D4             (datain[3]),
         .D5             (datain[4]),
         .D6             (datain[5]),
         .D7             (datain[6]),
         .D8             (datain[7]),
下面给出仿真结果:
无疑,结果是正确的。
欢迎大家踊跃参加讨论,还有很多问题值得探讨,并串,串并转换,还有mmcm始终配置模块,还有低压差分信号等等一系列的内容,大家都可以一起讨论。我希望他是一个生长贴,学习进步贴。
发表于 2017-6-25 17:39:07 | 显示全部楼层
自己去看XAPP860
GMT+8, 2025-12-18 09:52 , Processed in 0.013988 second(s), 4 queries , Gzip On, Redis On.
