查看: 4786|回复: 5
[求助] smic18mmrf的电阻在AMS中编译通不过
发表于 2017-1-11 10:51:22 | 显示全部楼层 |阅读模式
ncvlog: 09.20-p007: (c) Copyright 1995-2009 Cadence Design Systems, Inc.
file: /home/zhuchaoyong15/simulation/PLL_AMS_MIX/ams/config/netlist/ihnl/PLL_AMS/PLL_AMS_MIX/schematic/verilog.vams
module PLL_AMS.PLL_AMS_MIX:schematic
errors: 0, warnings: 0
ncvlog: Memory Usage - 9.5M program + 9.4M data = 18.9M total
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 65.2% cpu)
Successfully compiled ('PLL_AMS' 'PLL_AMS_MIX' 'schematic').
Compilation successful.
ncelab: 09.20-p007: (c) Copyright 1995-2009 Cadence Design Systems, Inc.
Elaborating the design hierarchy:
ncelab: *N,SFEDPL: Deploying new SFE in analog engine.
ncelab: *E,CUTODP: maximum design hierarchy component instance depth (100) exceeded.
   Module instantiation: PLL_AMS_MIX.I45@DIVIDER_1<module>.I0@\8or9_Div <module>.I0@CML_div_1<module>.I3@latch_1<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>.R0@rhrpo<module>
ncelab: Memory Usage - 20.4M program + 611.8M data = 632.2M total
ncelab: CPU Usage - 0.1s system + 0.2s user = 0.2s total (0.2s, 99.8% cpu)
Failed to elaborate ("PLL_AMS" "PLL_AMS_MIX" "config").
 楼主| 发表于 2017-1-11 10:53:40 | 显示全部楼层
在没有用smic电阻情况下,编译可以通过,仿真正常。但是调用电阻后,就出现了如上问题,求大神指点
 楼主| 发表于 2017-1-11 10:56:17 | 显示全部楼层
上面提示错误:实例深度超过最大值100层,这是什么鬼?我尝试就只在top层用一个电阻,还是会出现同样错误。说明和实例深度没有关系吧
发表于 2017-1-12 11:54:05 | 显示全部楼层
AMS simulator+PDK电阻的确有这个问题,两个改动方法:
1. 将PDK电阻换成理想电阻;
2. 改变netlist option,用OSS-based方法;
 楼主| 发表于 2017-1-12 22:54:45 | 显示全部楼层
回复 4# 远上寒杉
我的很多模块涉及电阻,这样修改不是很切实际啊。第二种方法,整个仿真15秒就通过了,但是出来的信号都是错的(其中有警告我的信号节点没有连接,但事实上连接好的)。是否用OSS需要其他的设置才能正常仿真
 楼主| 发表于 2017-1-13 15:53:47 | 显示全部楼层
再顶一下
GMT+8, 2025-12-23 09:42 , Processed in 0.015208 second(s), 4 queries , Gzip On, Redis On.
