查看: 6309|回复: 4
[求助] UVM connect 出错?
发表于 2016-10-24 12:19:53 | 显示全部楼层 |阅读模式
Fatal error in Function uvm_pkg/uvm_port_base::connect at C:/questasim64_10.2c/verilog_src/uvm-1.1d/src/base/uvm_port_base.svh line 431
没查到这个错误出在哪,代码参考了张强的代码
程序:
class SPI_env extends uvm_env;
`uvm_component_utils(SPI_env);
SPI_agent
i_agt, o_agt;
SPI_model
mdl;
SPI_scoreboard scb;
uvm_tlm_analysis_fifo #(SPI_transaction) agt_scb_fifo;
uvm_tlm_analysis_fifo #(SPI_transaction) agt_mdl_fifo;
uvm_tlm_analysis_fifo #(SPI_transaction) mdl_scb_fifo;
function new(string name = "SPI_env", uvm_component parent);
super.new(name, parent);
endfunction
function void build_phase(uvm_phase phase);
super.build_phase(phase);
i_agt = SPI_agent::type_id::create("i_agt", this);
o_agt = SPI_agent::type_id::create("o_agt", this);
i_agt.is_active = UVM_ACTIVE;
o_agt.is_active = UVM_PASSIVE;
mdl = SPI_model::type_id::create("mdl",this);
scb = SPI_scoreboard::type_id::create("scb", this);
agt_mdl_fifo = new("agt_mdl_fifo", this);
agt_scb_fifo = new("agt_scb_fifo", this);
mdl_scb_fifo = new("mdl_scb_fifo", this);
endfunction
function void connect_phase(uvm_phase phase);
super.connect_phase(phase);
i_agt.ap.connect(agt_mdl_fifo.analysis_export);               //报错在这行
mdl.port.connect(agt_mdl_fifo.blocking_get_export);
mdl.ap.connect(mdl_scb_fifo.analysis_export);
scb.exp_port.connect(mdl_scb_fifo.blocking_get_export);
scb.act_port.connect(agt_scb_fifo.blocking_get_export);
o_agt.ap.connect(agt_scb_fifo.analysis_export);
endfunction
endclass
发表于 2016-10-24 18:27:50 | 显示全部楼层
回复 1# fgg1991
   你 i_agt o_agt 里的ap 应该跟monitor连的吧 两个montior 采集的trans类型一样么?
 楼主| 发表于 2016-10-25 03:46:04 | 显示全部楼层
回复 2# DS_LOGIC
   一句话点醒梦中人!我突然意识到bug可能出在哪了!谢谢!
 楼主| 发表于 2016-10-25 03:53:53 | 显示全部楼层
回复 2# DS_LOGIC
   修复成功!谢谢回复!果然自己看自己的代码会有盲区。在i_agt里我省略了mon,应该直接在drv里把trans驱动到ap上,但是在drv里忘记初始化一个ap导致i_agt的ap是悬空的了。
agent的connect改成
  1.         function void connect_phase(uvm_phase phase);
  2.                 super.connect_phase(phase);
  3.                 if(is_active == UVM_ACTIVE)begin
  4.                         drv.seq_item_port.connect(sqr.seq_item_export);
  5.                         ap = drv.ap;
  6.                 end else
  7.                         ap = mon.ap;
  8.         endfunction
    复制代码
就对了
发表于 2021-3-17 15:28:54 | 显示全部楼层
我也遇到这个错,不过是build_phase拼错了
GMT+8, 2025-10-19 02:10 , Processed in 0.024582 second(s), 6 queries , Gzip On, Redis On.
