查看: 8864|回复: 8
[资料] ACE 3000 格式转换工具 DXF, GDSII, Gerber, Postscript, PDF, ODB++
发表于 2016-10-16 17:49:01 | 显示全部楼层 |阅读模式
ACE 3000 V6 - Convert DXF, GDSII, Gerber, Postscript, PDF, ODB++, TIFF, BITMAP, STEP, STL, and more.The Easiest CAD/EDA/3D Conversion tool available
ACE 3000 is perfectly suited for converting AutoCAD DXF and DWG files to manufacturing formats like: Gerber, Drill, GDS-II, and ODB++. ACE includes the most comprehensive set of DXF import options available - giving you more Power & Flexibility. ACE allows you to selectively control how each layer is imported, choose which blocks to import, and so much more.
ACE 3000 V6.2 HeXIe
PJ.rar (13.08 MB , 下载次数: 266 )
 楼主| 发表于 2016-10-16 17:55:42 | 显示全部楼层
发表于 2019-6-27 13:25:05 | 显示全部楼层
3Q~~~~~~~~~~~~~~~~~~~~~~~~
发表于 2020-12-8 23:22:19 | 显示全部楼层
发表于 2020-12-8 23:32:03 | 显示全部楼层
发表于 2020-12-9 10:18:38 | 显示全部楼层
good for layout tool
发表于 2021-11-8 15:26:38 | 显示全部楼层
試試能否work
感謝分享
发表于 2021-11-16 11:34:35 | 显示全部楼层
直接运行不行哦
发表于 2023-12-6 09:38:29 | 显示全部楼层
能转,但是转出来的有问题,图形全是错的,个人觉得linkcad确实能转,但是要license,没钱~
GMT+8, 2025-12-19 07:16 , Processed in 0.022289 second(s), 6 queries , Gzip On, Redis On.
