在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2521|回复: 2
[求助] 关于RHEL6.4 下安装QUESTASIM64位的问题
发表于 2016-9-9 10:12:16 | 显示全部楼层 |阅读模式
执行install.linux的时候出现以下LOG信息:
  1. Using previously installed MSI 3.4-023 from: /root/mgc/install.ixl
  2. [root@localhost questasim]# Using Java version 1.6.0
  3. Exception in thread "main" java.lang.UnsatisfiedLinkError: /root/mgc/install.ixl/JRE/lib/i386/xawt/libmawt.so: libXtst.so.6: cannot open shared object file: No such file or directory
  4. at java.lang.ClassLoader$NativeLibrary.load(Native Method)
  5. at java.lang.ClassLoader.loadLibrary0(Unknown Source)
  6. at java.lang.ClassLoader.loadLibrary(Unknown Source)
  7. at java.lang.Runtime.load0(Unknown Source)
  8. at java.lang.System.load(Unknown Source)
  9. at java.lang.ClassLoader$NativeLibrary.load(Native Method)
  10. at java.lang.ClassLoader.loadLibrary0(Unknown Source)
  11. at java.lang.ClassLoader.loadLibrary(Unknown Source)
  12. at java.lang.Runtime.loadLibrary0(Unknown Source)
  13. at java.lang.System.loadLibrary(Unknown Source)
  14. at sun.security.action.LoadLibraryAction.run(Unknown Source)
  15. at java.security.AccessController.doPrivileged(Native Method)
  16. at java.awt.Toolkit.loadLibraries(Unknown Source)
  17. at java.awt.Toolkit.<clinit>(Unknown Source)
  18. at java.awt.Color.<clinit>(Unknown Source)
  19. at javax.swing.plaf.metal.MetalTheme.<clinit>(Unknown Source)
  20. at javax.swing.plaf.metal.MetalLookAndFeel.getCurrentTheme(Unknown Source)
  21. at javax.swing.plaf.metal.MetalLookAndFeel.createDefaultTheme(Unknown Source)
  22. at javax.swing.plaf.metal.MetalLookAndFeel.getDefaults(Unknown Source)
  23. at javax.swing.UIManager.setLookAndFeel(Unknown Source)
  24. at javax.swing.UIManager.setLookAndFeel(Unknown Source)
  25. at javax.swing.UIManager.initializeDefaultLAF(Unknown Source)
  26. at javax.swing.UIManager.initialize(Unknown Source)
  27. at javax.swing.UIManager.maybeInitialize(Unknown Source)
  28. at javax.swing.UIManager.getDefaults(Unknown Source)
  29. at com.mentor.install.controlpanel.Install.main(Install.java:630)
复制代码
然后 安装 libXext.i686之后依然提示这个lib找不到;有谁遇到过这个问题吗?
发表于 2019-10-23 23:47:05 | 显示全部楼层
遇到了,不知道楼主解决了嘛?如果解决了请指点一下,如果还没有的话,交流下?
发表于 2020-8-15 11:56:24 | 显示全部楼层
有人已经结局了么,你们的Linux系统用起来怎么样,费了半天劲才走到这一步的,之前是64位机不能运行32位程序,安装32位的库,都整了半天。感觉ubuntu 不适合用来干这个
GMT+8, 2024-4-26 20:06 , Processed in 0.022182 second(s), 8 queries , Gzip On, Redis On.
