- //// CRC_chk.v ////
- //// This file is part of the Ethernet IP core project ////
- //// http://www.opencores.org/projects.cgi/web/ethernet_tri_mode/////
- //// Author(s): ////
- //// - Jon Gao (gaojon@yahoo.com) ////
- //// Copyright (C) 2001 Authors ////
- //// This source file may be used and distributed without ////
- //// restriction provided that this copyright statement is not ////
- //// removed from the file and that any derivative work contains ////
- //// the original copyright notice and the associated disclaimer. ////
- //// This source file is free software; you can redistribute it ////
- //// and/or modify it under the terms of the GNU Lesser General ////
- //// Public License as published by the Free Software Foundation; ////
- //// either version 2.1 of the License, or (at your option) any ////
- //// later version. ////
- //// This source is distributed in the hope that it will be ////
- //// useful, but WITHOUT ANY WARRANTY; without even the implied ////
- //// warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ////
- //// PURPOSE. See the GNU Lesser General Public License for more ////
- //// details. ////
- //// You should have received a copy of the GNU Lesser General ////
- //// Public License along with this source; if not, download it ////
- //// from http://www.opencores.org/lgpl.shtml ////
- // CVS Revision History
- // $Log: not supported by cvs2svn $
- // Revision 1.2 2005/12/16 06:44:16 Administrator
- // replaced tab with space.
- // passed 9.6k length frame test.
- // Revision 1.1.1.1 2005/12/13 01:51:45 Administrator
- // no message
- module CRC_chk(
- Reset ,
- Clk ,
- CRC_data ,
- CRC_init ,
- CRC_en ,
- //From cpu
- CRC_chk_en ,
- CRC_err
- input Reset ;
- input Clk ;
- input[7:0] CRC_data ;
- input CRC_init ;
- input CRC_en ;
- //From CPU
- input CRC_chk_en ;
- output CRC_err ;
- //internal signals
- reg [31:0] CRC_reg;
- wire[31:0] Next_CRC;
- //input data width is 8bit, and the first bit is bit[0]
- function[31:0] NextCRC;
- input[7:0] D;
- input[31:0] C;
- reg[31:0] NewCRC;
- begin
- NewCRC[0]=C[24]^C[30]^D[1]^D[7];
- NewCRC[1]=C[25]^C[31]^D[0]^D[6]^C[24]^C[30]^D[1]^D[7];
- NewCRC[2]=C[26]^D[5]^C[25]^C[31]^D[0]^D[6]^C[24]^C[30]^D[1]^D[7];
- NewCRC[3]=C[27]^D[4]^C[26]^D[5]^C[25]^C[31]^D[0]^D[6];
- NewCRC[4]=C[28]^D[3]^C[27]^D[4]^C[26]^D[5]^C[24]^C[30]^D[1]^D[7];
- NewCRC[5]=C[29]^D[2]^C[28]^D[3]^C[27]^D[4]^C[25]^C[31]^D[0]^D[6]^C[24]^C[30]^D[1]^D[7];
- NewCRC[6]=C[30]^D[1]^C[29]^D[2]^C[28]^D[3]^C[26]^D[5]^C[25]^C[31]^D[0]^D[6];
- NewCRC[7]=C[31]^D[0]^C[29]^D[2]^C[27]^D[4]^C[26]^D[5]^C[24]^D[7];
- NewCRC[8]=C[0]^C[28]^D[3]^C[27]^D[4]^C[25]^D[6]^C[24]^D[7];
- NewCRC[9]=C[1]^C[29]^D[2]^C[28]^D[3]^C[26]^D[5]^C[25]^D[6];
- NewCRC[10]=C[2]^C[29]^D[2]^C[27]^D[4]^C[26]^D[5]^C[24]^D[7];
- NewCRC[11]=C[3]^C[28]^D[3]^C[27]^D[4]^C[25]^D[6]^C[24]^D[7];
- NewCRC[12]=C[4]^C[29]^D[2]^C[28]^D[3]^C[26]^D[5]^C[25]^D[6]^C[24]^C[30]^D[1]^D[7];
- NewCRC[13]=C[5]^C[30]^D[1]^C[29]^D[2]^C[27]^D[4]^C[26]^D[5]^C[25]^C[31]^D[0]^D[6];
- NewCRC[14]=C[6]^C[31]^D[0]^C[30]^D[1]^C[28]^D[3]^C[27]^D[4]^C[26]^D[5];
- NewCRC[15]=C[7]^C[31]^D[0]^C[29]^D[2]^C[28]^D[3]^C[27]^D[4];
- NewCRC[16]=C[8]^C[29]^D[2]^C[28]^D[3]^C[24]^D[7];
- NewCRC[17]=C[9]^C[30]^D[1]^C[29]^D[2]^C[25]^D[6];
- NewCRC[18]=C[10]^C[31]^D[0]^C[30]^D[1]^C[26]^D[5];
- NewCRC[19]=C[11]^C[31]^D[0]^C[27]^D[4];
- NewCRC[20]=C[12]^C[28]^D[3];
- NewCRC[21]=C[13]^C[29]^D[2];
- NewCRC[22]=C[14]^C[24]^D[7];
- NewCRC[23]=C[15]^C[25]^D[6]^C[24]^C[30]^D[1]^D[7];
- NewCRC[24]=C[16]^C[26]^D[5]^C[25]^C[31]^D[0]^D[6];
- NewCRC[25]=C[17]^C[27]^D[4]^C[26]^D[5];
- NewCRC[26]=C[18]^C[28]^D[3]^C[27]^D[4]^C[24]^C[30]^D[1]^D[7];
- NewCRC[27]=C[19]^C[29]^D[2]^C[28]^D[3]^C[25]^C[31]^D[0]^D[6];
- NewCRC[28]=C[20]^C[30]^D[1]^C[29]^D[2]^C[26]^D[5];
- NewCRC[29]=C[21]^C[31]^D[0]^C[30]^D[1]^C[27]^D[4];
- NewCRC[30]=C[22]^C[31]^D[0]^C[28]^D[3];
- NewCRC[31]=C[23]^C[29]^D[2];
- NextCRC=NewCRC;
- end
- endfunction
- always @ (posedge Clk or posedge Reset)
- if (Reset)
- CRC_reg <=32'hffffffff;
- else if (CRC_init)
- else if (CRC_en)
- CRC_reg <=NextCRC(CRC_data,CRC_reg);
- assign CRC_err = CRC_chk_en&(CRC_reg[31:0] != 32'hc704dd7b);
- endmodule
复制代码
最后一行代码是怎么回事?他是怎么实现CRC校验的 |
