在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 13394|回复: 57
[资料] [ebook 2016] Toward 5G Software Defined Radio Receiver Front-Ends
发表于 2016-7-23 12:46:06 | 显示全部楼层 |阅读模式
The Authors: Spiridon , Silvian
This book introduces a new intuitive design methodology for the optimal design path for next-generation software defined radio front-ends (SDRXs). The methodology described empowers designers to "attack" the multi-standard environment in a parallel way rather than serially, providing a critical tool for any design methodology targeting 5G circuits and systems. Throughout the book the SDRX design follows the key wireless standards of the moment (ie, GSM, WCDMA, LTE, Bluetooth, WLAN), since a receiver compatible with these standards is the most likely candidate for the first design iteration in a 5G deployment The author explains the fundamental choice the designer has to make regarding the optimal channel selection:. how much of the blockers / interferers will be filtered in the Analog domain and how much will remain to be filtered in the digital domain. The system-level analysis the author describes entails the direct sampling architecture is treated as a particular case of mixer-based direct conversion architecture. This allows readers give a power consumption budget to determine how much filtering is required on the receive path, by considering the ADC performance characteristics and the corresponding blocker diagram.
http://www.springer.com/gp/book/9783319327587
Toward 5G Software Defined Radio Receiver Front-Ends.pdf
2.66 MB, 下载次数: 573 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2016-7-23 17:48:53 | 显示全部楼层
回复 1# amir98
    ok.....................
发表于 2016-7-23 18:36:02 | 显示全部楼层
thanks
发表于 2016-7-24 06:17:09 | 显示全部楼层
good,thanks a lot!
发表于 2016-7-25 08:56:09 | 显示全部楼层
下载看看。
发表于 2016-7-25 10:01:08 | 显示全部楼层
回复 1# amir98
谢谢分享
发表于 2016-7-25 17:39:02 | 显示全部楼层
Thanks a lot
发表于 2016-7-25 18:59:25 | 显示全部楼层
thx for sharing~
发表于 2016-7-26 10:29:49 | 显示全部楼层
感谢。很想看的。
发表于 2016-7-28 23:45:33 | 显示全部楼层
Thanks for sharing valuable books
GMT+8, 2024-4-27 02:14 , Processed in 0.043372 second(s), 9 queries , Gzip On, Redis On.
