查看: 2615|回复: 0
[讨论] sv中类的声明/嵌套
发表于 2015-9-16 11:02:05 | 显示全部楼层 |阅读模式
例子1:
class Outer;
int outerProp;
local int outerLocalProp;
static int outerStaticProp;
static local int outerLocalStaticProp;
class Inner;//类Inner为嵌套类
function void innerMethod(Outer h);
//类Outer声明
outerStaticProp = 0;// Legal, same as Outer:uterStaticProp
outerLocalStaticProp = 0;// Legal, nested classes may access local's in outer class
outerProp = 0;// Illegal, unqualified access to non-static outer
h.outerProp = 0;// Legal, qualified access.
h.outerLocalProp = 0;// Legal, qualified access and locals to outer class allowed.
endfunction
endclass
endclass
例子2:
class Packet;
    Packet next;
    function Packet get_next();// single line
        get_next = next;
    endfunction
// out-of-body (extern) declaration
    extern protected virtual function int send(int value);
endclass
function int Packet::send(int value);
// dropped protected virtual, added Packet::
// body of method
endfunction
这是在sv手册中看到的,代码中红色字体的声明应该怎么理解或者解释?
像例子1中红色字体的声明,如果它的位置位于类中其他成员变量定义的前面,还能像例子中的那种方式引用吗?
GMT+8, 2025-9-18 04:04 , Processed in 0.016059 second(s), 5 queries , Gzip On, Redis On.
