在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1573|回复: 1
[求助] about reset pin timing check
发表于 2015-7-16 12:27:40 | 显示全部楼层 |阅读模式
my reset signal is come from clk port after some logic cell , so in encouter , it will ckeck reset pin's timing with clk fall edge ,
thus setup violation is larger due it introduced half cycle at data path , so how to deal with it in SDC contrains file ?
it means reset singal and clock signal is from the same root ,
发表于 2015-7-16 15:49:05 | 显示全部楼层
input delay可以设小点,或者干脆false path,
GMT+8, 2024-4-26 15:38 , Processed in 0.020126 second(s), 9 queries , Gzip On, Redis On.
