楼主: Student
[原创] Xilinx ISE官方IP可以解密源码了
发表于 2017-7-21 17:09:52 | 显示全部楼层
基于以上原理,VIVADO2017.2也是可以解出的:
-- Filename     :   can_top.vhd
-- Version      :   1.00.a
-- Author       :
-- Company      :   Xilinx
-- Description          :   Top level design, instantiates IPIF and top module for CAN core.
-- Standard     :   VHDL-93
-- Structure:
--          can_top.vhd
--              -- cantop.vhd
--                  -- can_tl_top.vhd
--                      -- can_tl_synch.vhd
--                      -- can_tl_clkdiv.vhd
--                      -- can_tl_om.vhd
--                      -- can_tl_bsp.vhd
--                          -- can_tl_arbit.vhd
--                      -- can_tl_btl.vhd
--                      -- can_tl_acf.vhd
--                  -- can_ol_top.vhd
--                      -- can_txfifo_cntl_gen.vhd
--                          -- can_ol_fifopriority.vhd
--                              -- can_tl_arbchk.vhd
--                      -- can_rxfifo_cntl_gen.vhd
--                      -- can_ol_synch.vhd
--                      -- can_ic_main.vhd
--                      -- can_bram.vhd
-- Naming Conventions:
--  active low signals:                    "*_n"
--  clock signals:                         "clk", "clk_div#", "clk_#x"
--  reset signals:                         "rst", "rst_n"
--  generics:                              "C_*"
--  user defined types:                    "*_TYPE"
--  state machine next state:              "*_ns"
--  state machine current state:           "*_cs"
--  combinatorial signals:                 "*_com"
--  pipelined or register delay signals:   "*_d#"
--  counter signals:                       "*cnt*"
--  clock enable signals:                  "*_ce"
--  internal version of output port:       "*_i"
--  device pins:                           "*_pin"
--  ports:                                 "- Names begin with Uppercase"
--  processes:                             "*_PROCESS"
--  component instantiations:              "<ENTITY_>I_<#|FUNC>"
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
use ieee.std_logic_misc.all;
library can_v5_0_16;
use can_v5_0_16.proc_common_pkg.all;
use can_v5_0_16.ipif_pkg.all;
-- Entity section
entity can_top is
    generic
        -- ADD USER GENERICS BELOW THIS LINE ---------------
        C_CAN_RX_DPTH           :   integer                 := 64;
        C_CAN_TX_DPTH           :   integer                 := 64;
        C_CAN_NUM_ACF           :   integer                 := 4;
        C_S2C_MTBF_STAGES : integer :=  2;    -- Number of MTBF Stages for System to
                                              -- CAN CLK Crossing.
        C_C2S_MTBF_STAGES : integer :=  2;    -- Number of MTBF Stages for CAN to
                                              -- System CLK Crossing.
        -- ADD USER GENERICS ABOVE THIS LINE ---------------
        -- DO NOT EDIT BELOW THIS LINE ---------------------
         -- axi lite ipif block generics
        C_S_AXI_ADDR_WIDTH : integer := 8;
        C_S_AXI_DATA_WIDTH : integer := 32;
        C_FAMILY                :   string                  := "virtex7"
        -- DO NOT EDIT ABOVE THIS LINE ---------------------
    port
        -- ADD USER PORTS BELOW THIS LINE ------------------
        CAN_CLK                 : in    std_logic;
        CAN_PHY_RX              : in    std_logic;
        CAN_PHY_TX              : out   std_logic;
        IP2Bus_IntrEvent        : out   std_logic;
        -- ADD USER PORTS ABOVE THIS LINE ------------------
        -- Bus protocol ports, do not add to or delete
        -- System signals
        S_AXI_ACLK      : in  std_logic;
        S_AXI_ARESETN   : in  std_logic;
        -- AXI interface signals
        S_AXI_AWADDR    : in  std_logic_vector (C_S_AXI_ADDR_WIDTH-1 downto 0);
        S_AXI_AWVALID   : in  std_logic;
        S_AXI_AWREADY   : out std_logic;
        S_AXI_WDATA     : in  std_logic_vector (C_S_AXI_DATA_WIDTH-1 downto 0);
        S_AXI_WSTRB     : in  std_logic_vector ((C_S_AXI_DATA_WIDTH/8)-1 downto 0);
        S_AXI_WVALID    : in  std_logic;
        S_AXI_WREADY    : out std_logic;
        S_AXI_BRESP     : out std_logic_vector(1 downto 0);
        S_AXI_BVALID    : out std_logic;
        S_AXI_BREADY    : in  std_logic;
        S_AXI_ARADDR    : in  std_logic_vector (C_S_AXI_ADDR_WIDTH-1 downto 0);
        S_AXI_ARVALID   : in  std_logic;
        S_AXI_ARREADY   : out std_logic;
        S_AXI_RDATA     : out std_logic_vector (C_S_AXI_DATA_WIDTH-1 downto 0);
        S_AXI_RRESP     : out std_logic_vector(1 downto 0);
        S_AXI_RVALID    : out std_logic;
        S_AXI_RREADY    : in  std_logic
    attribute SIGIS                         : string;
    attribute SIGIS of S_AXI_ACLK             : signal is "Clk";
    attribute SIGIS of S_AXI_ARESETN         : signal is "Rst";
    attribute SIGIS of IP2Bus_IntrEvent     : signal is "INTR_EDGE_RISING";
    -- IP licensing section
    attribute check_license : string;
发表于 2017-9-2 19:22:03 | 显示全部楼层
都是大牛水平呀
发表于 2017-9-3 17:40:20 | 显示全部楼层
学习了,学习了,学习了,
发表于 2017-10-18 17:07:18 | 显示全部楼层
回复 21# biangbiang8899
  能高速如何破解的吗,跪求
发表于 2017-12-2 16:01:53 | 显示全部楼层
请问如何破解的呀?可否赐教
发表于 2017-12-31 17:33:42 | 显示全部楼层
厉害了
发表于 2018-1-3 06:51:18 | 显示全部楼层
    自vivado2017.3之后修改了RSA密钥解不开了,还没时间去看新密钥
发表于 2020-12-1 11:46:03 | 显示全部楼层
mark
发表于 2021-1-6 18:06:06 | 显示全部楼层
感谢楼主的分享
发表于 2021-1-7 02:50:08 来自手机 | 显示全部楼层
Who is it
GMT+8, 2025-12-5 16:52 , Processed in 0.021280 second(s), 6 queries , Gzip On, Redis On.
