在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: min4max
在Ubuntu上设置并运行Calibre2014的终极解决方案,本方案对其他类似问题也应该有帮助
发表于 2014-12-23 08:47:24 | 显示全部楼层
多谢 正好学习下
发表于 2014-12-24 09:33:38 | 显示全部楼层
必须赞一个!
发表于 2015-1-6 08:56:23 | 显示全部楼层
必须支持啊。服务器软件安装必修
发表于 2015-1-14 23:16:01 | 显示全部楼层
很详细。辛苦LZ
发表于 2015-1-23 19:16:36 | 显示全部楼层
不错的诶。。。。
发表于 2015-1-27 16:32:22 | 显示全部楼层
回复 1# min4max
请问该patch是否适用于calibre 2014.4?我用这个patch 2014.4版本时,出现Rochester@P151:~/opt/mentor/Calibre2014$ sudo ./patch_calibre aoi_cal_2014.4_18.13
[sudo] password for Rochester:
[total hits/matching patterns/non-matching patterns]
90error: failed to read+write: sfk - skipping
                                        warn : empty file: aoi_cal_2014.4_18.13/pkgs/icwb.aoi/dependencies/version - skipping
66% install.iwarn : empty file: install.ixl/JRE/.systemPrefs/.system.lock - skipping
warn : empty file: install.ixl/JRE/.systemPrefs/.systemRootModFile - skipping
9862 files checked, 0 changed.
1 errors, 3 warnings occurred.
发表于 2015-2-3 19:33:05 | 显示全部楼层
大神 你好 最近我装calibre2011 出现了以下的问题 616和MMSIM131都是按照你之前的帖子做的 脚本也使用的你提供的 但是集成后 启动出现了以下的问题(每次都是启动后弹出IC616的CIW后有消失掉) 请教到底是什么原因? 错误如下:
yandy@yandy:~/work616$ ./cadence_4_calibre
yandy@yandy:~/work616$ 19:17:43 (lmgrd) -----------------------------------------------
19:17:43 (lmgrd)   Please Note:
19:17:43 (lmgrd)
19:17:43 (lmgrd)   This log is intended for debug purposes only.
19:17:43 (lmgrd)   In order to capture accurate license
19:17:43 (lmgrd)   usage data into an organized repository,
19:17:43 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
19:17:43 (lmgrd)   software license administration  solution,
19:17:43 (lmgrd)   FLEXnet Manager, to  readily gain visibility
19:17:43 (lmgrd)   into license usage data and to create
19:17:43 (lmgrd)   insightful reports on critical information like
19:17:43 (lmgrd)   license availability and usage. FLEXnet Manager
19:17:43 (lmgrd)   can be fully automated to run these reports on
19:17:43 (lmgrd)   schedule and can be used to track license
19:17:43 (lmgrd)   servers and usage across a heterogeneous
19:17:43 (lmgrd)   network of servers including Windows NT, Linux
19:17:43 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
19:17:43 (lmgrd)   www.acresso.com for more details on how to
19:17:43 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
19:17:43 (lmgrd)   for your enterprise.
19:17:43 (lmgrd)
19:17:43 (lmgrd)
19:17:43 (lmgrd)
19:17:43 (lmgrd) FLEXnet Licensing (v11.6.1.0 build 66138 i86_re3) started on yandy (linux) (2/3/2015)
19:17:43 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved.
19:17:43 (lmgrd) US Patents 5,390,297 and 5,671,412.
19:17:43 (lmgrd) World Wide Web:  http://www.acresso.com
19:17:43 (lmgrd) License file(s): /opt/cadence/mentor/calibre2011/ixl_cal_2011.2_34.26/shared/license/license.dat
19:17:43 (lmgrd) lmgrd tcp-port 5288
19:17:43 (lmgrd) Starting vendor daemons ...
19:17:43 (lmgrd) Started mgcld (internet tcp_port 59792 pid 4380)
19:17:43 (mgcld) FLEXnet Licensing version v11.6.1.0 build 66138 i86_re3
19:17:43 (mgcld) Cannot create lock file. Old lockfile exists. errno=13 (/var/tmp/lockmgcld): Permission denied
19:17:43 (mgcld) EXITING DUE TO SIGNAL 41 Exit reason 9
19:17:43 (lmgrd) mgcld exited with status 41 (Exited because another server was running)
19:17:43 (lmgrd) MULTIPLE "mgcld" license server systems running.
19:17:43 (lmgrd) Please kill, and run lmreread
19:17:43 (lmgrd)
19:17:43 (lmgrd) This error probably results from either:
19:17:43 (lmgrd)   1. Another copy of the license server manager (lmgrd) is running.
19:17:43 (lmgrd)   2. A prior license server manager (lmgrd) was killed with "kill -9"
19:17:43 (lmgrd)       (which would leave the vendor daemon running).
19:17:43 (lmgrd) To correct this, do a "ps -ax | grep mgcld"
19:17:43 (lmgrd)   (or equivalent "ps" command)
19:17:43 (lmgrd) and kill the "mgcld" process.
19:17:43 (lmgrd)
WARNING: HOST <yandy> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
19:17:51 (lmgrd) Failed to open the TCP port number in the license.
发表于 2015-2-3 20:03:35 | 显示全部楼层
发表于 2015-2-6 15:31:53 | 显示全部楼层
謝謝.....
发表于 2015-2-6 17:37:57 | 显示全部楼层
启动后闪退出  问题如下:
The TCP port number in the license, 5288, is already in use.
17:38:49 (lmgrd) Possible causes:
17:38:49 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.
17:38:49 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
17:38:49 (lmgrd)    3) Another process is using this port number (unlikely).
17:38:49 (lmgrd) Solutions:
17:38:49 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
17:38:49 (lmgrd)       license are not running.
17:38:49 (lmgrd)    2) You may have to wait for the OS to clear this port.
17:38:49 (lmgrd) Retrying for about 5 more minutes
GMT+8, 2024-4-27 12:18 , Processed in 0.028392 second(s), 6 queries , Gzip On, Redis On.
