查看: 2770|回复: 1
[活动] 每日一奖----20140509
发表于 2014-5-9 10:00:31 | 显示全部楼层 |阅读模式
悬赏200资产未解决
Q4. Which layer is used for clock routing and why?
发表于 2014-5-9 10:15:25 | 显示全部楼层
M5 ~ (top layer -2) maybe suitable.
Utilization of metals below M5 used for signal route maybe very high, if used to route clock, may cause some violations. Also, higher metals have low resistance(higher width, higher thickness) and the performance maybe better.
top layer -2 ~ top metal is better to be used for power route.
GMT+8, 2025-12-21 14:47 , Processed in 0.011387 second(s), 3 queries , Gzip On, Redis On.
