在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
EETOP诚邀模拟IC相关培训讲师 创芯人才网--重磅上线啦!
查看: 5759|回复: 5
[求助] cadence AMS仿真问题求助
发表于 2013-5-23 16:26:02 | 显示全部楼层 |阅读模式
用irun的脚本方式运行,跑仿真出现以下错误!
Discipline resolution Pass...
.vop( net9 ), .vss( cds_globals.\gnd!  ), .ck2( net028 ), .ck1( net11 ),
ncelab: *E,CUVNCM (./ihnl/li/mixsim/schematic/verilog.vams,20|53): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance mixsim.I6.
ncelab: *E,CUVNCM (./ihnl/li/mixsim/schematic/verilog.vams,20|68): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance mixsim.I6.
net022[0:15] ), .filter_in( { cds_globals.\gnd! ,net9 } ), .reset(
ncelab: *E,CUVNCM (./ihnl/li/mixsim/schematic/verilog.vams,27|47): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance mixsim.I1.
net17 ), .clk( net017 ) );
ncelab: *E,CUVNCM (./ihnl/li/mixsim/schematic/verilog.vams,28|4): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance mixsim.I1.
请知道解决办法的高手赐教!
发表于 2015-7-4 11:40:08 | 显示全部楼层
没有加connect rules
发表于 2016-3-24 10:38:21 | 显示全部楼层
adding the connect rules "ConnRules_18V_fll_fast".
发表于 2019-9-19 17:42:34 | 显示全部楼层
请问楼主这个问题解决了吗?
发表于 2020-1-9 23:08:25 | 显示全部楼层
2# 正确
发表于 2021-10-14 16:03:39 | 显示全部楼层
问题解决了吗
GMT+8, 2024-4-26 22:17 , Processed in 0.038708 second(s), 8 queries , Gzip On, Redis On.
