楼主: 高低杠
[转贴] JSSC 2013 06
 楼主| 发表于 2013-5-27 15:26:12 | 显示全部楼层
20130527 补充
上次IEEE网站上的文章还没更新完我就发帖了,现在把剩下的部分补全。
JSSC 2013 06_1.part1.rar (15 MB , 下载次数: 1099 )
JSSC 2013 06_1.part2.rar (1.43 MB , 下载次数: 127 )
这次上传的两个附件中的文章包括:
A 1 Mb Nonvolatile Embedded Memory Using 4T2MTJ Cell With 32 b Fine-Grained Power Gating Scheme
A 10-b Two-Stage DAC with an Area-Efficient Multiple-Output Voltage Selector and a Linearity-Enhanced DAC-Embedded Op-Amp for LCD Column Driver ICs
A Bang-Bang Clock and Data Recovery Using Mixed Mode Adaptive Loop Gain Strategy
A High Layer Scalability TSV-Based 3D-SRAM With Semi-Master-Slave Structure and Self-Timed Differential-TSV for High-Performance Universal-Memory-Capacity-Platforms
A Low Power BAW Resonator Based 2.4-GHz Receiver With Bandwidth Tunable Channel Selection Filter at RF
A Second-Order ΔΣ ADC Using Noise-Shaped Two-Step Integrating Quantizer
Correction to “A 2 Gb/s Throughput CMOS Transceiver Chipset With In-Package Antenna for 60 GHz Short-Range Wireless Communication”
The Outphasing RF Power Amplifier: A Comprehensive Analysis and a Class-B CMOS Realization
Correction to “A Linearized, Low Phase Noise VCO Based 25 GHz PLL With Autonomic Biasing”
发表于 2013-5-27 21:36:29 | 显示全部楼层
多谢楼主!
发表于 2013-6-4 12:30:03 | 显示全部楼层
这下补全了吗?
发表于 2014-1-6 11:19:25 | 显示全部楼层
太厚道了
发表于 2014-2-7 17:51:30 | 显示全部楼层
非常感谢1!
发表于 2014-2-13 01:55:36 | 显示全部楼层
多谢大侠
发表于 2014-2-15 12:21:57 | 显示全部楼层
非常感谢!
发表于 2014-6-20 15:53:27 | 显示全部楼层
xiexie
发表于 2014-6-25 11:55:29 | 显示全部楼层
lz辛苦了,支持一下!
发表于 2014-8-27 14:58:38 | 显示全部楼层
大谢楼主!
GMT+8, 2025-11-1 11:16 , Processed in 0.019157 second(s), 4 queries , Gzip On, Redis On.
