搬自各处,其中有不少是从本站搬来。为方便而做成合集。本合集内,文件名做了适当修改以方便辨识,并且也仅包含Synopsys官方文档。
因为本论坛支持的附件后缀名中没有7z,不得不进行了双重压缩,大家先把附件中的文件解压到同一个目录下,再用7z解压。
(总体积197 MB,压缩后87.0MB)
目录:
D:.
│ IC Compiler Commands , Version D-2010.03.pdf
│ IC Compiler Design Planning User Guide , Version D-2010.03-SP2.pdf
│ IC Compiler Error Messages , Version C-2009.06-SP4.pdf
│ IC Compiler Implementation User Guide , Version D-2010.03-SP2.pdf
│ IC Compiler Technology File and Routing Rules Reference Manual , Version D-2010.03-SP2.pdf
│ IC Compiler Variables , Version C-2009.06-SP4.pdf
│ IC Compiler Zroute User Guide , Version C-2009.06-SP4.pdf
│ Library Data Preparation for IC Compiler User Guide , Version D-2010.03-SP2.pdf
│ Synopsys? Low-Power Flow User Guide , Version D-2009.12.pdf
│ Synopsys? Timing Constraints and Optimization User Guide , Version D-2010.03.pdf
│ UPF Library Preparation Application Notes , Version B-2008.09-SP3.pdf
│ Using the Synopsys? Design Constraints Format Application Note , Version C-2009.06.pdf
├─newer
│ IC Compiler Design Planning User Guide , Version E-2010.12-SP4.pdf
│ IC Compiler Implementation User Guide , Version F-2011.09.pdf
│ IC Compiler Technology File and Routing Rules Reference Manual , Version E-2010.12-SP2.pdf
│ Library Data Preparation for IC Compiler User Guide , Version E-2010.12.pdf
│ Library Data Preparation for IC Compiler User Guide , Version F-2011.09.pdf
├─older
│ IC Compiler Commands , Version B-2008.12.pdf
│ IC Compiler Commands , Version C-2009.06-SP4.pdf
│ IC Compiler Commands , Version C-2009.06.pdf
│ IC Compiler Data Preparation Using Milkyway? User Guide , Version C-2009.06-SP4.pdf
│ IC Compiler Design Planning User Guide , Version C-2009.06-SP4.pdf
│ IC Compiler Implementation User Guide , Version C-2009.06-SP4.pdf
│ IC Compiler Technology File and Routing Rules Reference Manual , Version C-2009.06-SP4.pdf
│ IC Compiler User Guide , Version A-2007.12-SP2.pdf
│ IC Compiler User Guide , Version A-2007.12.pdf
│ IC Compiler User Guide Design Planning , Version B-2008.09.pdf
│ IC Compiler User Guide Implementation , Version B-2008.09.pdf
│ IC compiler user guide Zroute , Version B-2008.09-SP4.pdf
│ IC Compiler Variables , Version B-2008.12.pdf
│ Synopsys? Timing Constraints and Optimization User Guide , Version C-2009.06-SP4.pdf
└─other
IC Compiler Classic Router User Guide , Version E-2010.12.pdf
IC Compiler Installation Notes , Version A-2007.12 .pdf
IC Compiler Installation Notes , Version B-2008.09 .pdf
IC Compiler Installation Notes , Version C-2009.06.pdf
IC Compiler Installation Notes , Version D-2010.03.pdf
IC Compiler Quick Reference , Version C-2009.06-SP4.pdf
IC Compiler Tool Invocation Commands , Version B-2008.09.pdf
IC Compiler Tool Invocation Commands , Version C-2009.06-SP4.pdf
IC Compiler.7z.001.zip
(15 MB, 下载次数: 4959 )
IC Compiler.7z.002.zip
(15 MB, 下载次数: 2039 )
IC Compiler.7z.003.zip
(15 MB, 下载次数: 1987 )
IC Compiler.7z.004.zip
(15 MB, 下载次数: 2350 )
IC Compiler.7z.005.zip
(15 MB, 下载次数: 2272 )
IC Compiler.7z.006.zip
(12.03 MB, 下载次数: 4353 )
