查看: 26275|回复: 28
[讨论] 用verilog写一段代码,实现消除一个glitch
发表于 2012-8-6 20:56:45 | 显示全部楼层 |阅读模式
    最近在准备FPGA方面的求职面试,遇到这样一题目“用verilog写一段代码,实现消除一个glitch”,于是在网上找了些资料,根据一篇博客作者提供的资料,现把消除glitch方法做了如下整理,望批评指正:
    滤掉小于1个周期glitch的原理图如下:
verilog代码实现如下:
module digital_filter_(clk_in,rst,host_rst,host_rst_filter);
input  clk_in;
input  rst;
input  host_rst;
output host_rst_filter;
reg host_rst_d1;
reg host_rst_d2;
always@(posedge clk_in or negedge rst)
  begin
    if(~rst)
    begin
        host_rst_d1 <= 1'b1;
        host_rst_d2 <= 1'b1;
       end
    else
      begin
        host_rst_d1 <= host_rst;
        host_rst_d2 <= host_rst_d1;
      end
  end
assign host_rst_filter = host_rst_d1 | host_rst_d2;
endmodule
    滤掉大于1个周期且小于2个周期glitch的原理图如下:
verilog代码如下:
input  clk_in;
input  rst;
input  host_rst;
reg host_rst_d1;
reg host_rst_d2;
reg host_rst_d3;
  begin
    if(~rst)
    begin
        host_rst_d3 <= 1'b1;
      end
    else
  begin
        host_rst_d3 <= host_rst_d2;
       end
  end
assign host_rst_filter = host_rst_d1 | host_rst_d2 | host_rst_d3;
endmodule
发表于 2012-8-7 09:54:35 | 显示全部楼层
`timescale 1ns/1ps
module glitch_filter_TB;
    parameter
parameter   U_DLY   = 1;
parameter   CLK_P   = 10;
    signals
reg                        clk;
reg                        rst_n;
reg                        glitch1;
reg [1:0]                  glitch_shifter1;
wire                       filter1;
reg                        glitch2;
reg [1:0]                  glitch_shifter2;
wire                       filter2;
    Generat clok and reset
initial
begin
    clk = 1'b0;
    rst_n = 1'b0;
    #(CLK_P*10);
    @(negedge clk);
    rst_n = 1'b1;
end
always #(CLK_P/2) clk = ~clk;
    main code
assign filter1 = &glitch_shifter1;
assign filter2 = &glitch_shifter2;
initial
begin
    glitch1 = 1'b0;
    glitch2 = 1'b0;
    wait(rst_n==1'b1);
    #(CLK_P*10);
    @(negedge clk)
    begin
        glitch1 <= 1'b1;
        glitch2 <= 1'b1;
    end
    @(posedge clk);
    glitch1 <= #1 1'b0;
    @(negedge clk);
    glitch2 <= #1 1'b0;
    #(CLK_P*10);
    $stop;
end
always@(posedge clk,negedge rst_n)
begin
    if(rst_n==1'b0)
    begin
        glitch_shifter1 <= 'h0;
        glitch_shifter2 <= 'h0;
    end
    else
    begin
        glitch_shifter1 <= #1 {glitch_shifter1[0],glitch1};
        glitch_shifter2 <= #1 {glitch_shifter2[0],glitch2};
    end
end
endmodule
仿真结果如下:
发表于 2012-8-7 09:56:17 | 显示全部楼层
发表于 2012-8-7 10:17:23 | 显示全部楼层
看电路图只是消除单边glitch,一般使用都会用双边。
发表于 2012-8-7 11:13:52 | 显示全部楼层
有两个问题:
1.glitch的位置如果是随机的,那么通过第1个触发器之后的信号是亚稳态的,不能用于后面的与门,会导致与门的结果出错。
2.功能上,连续两个周期为1,才输出1,否则输出0.实际中的glitch有可能是反过来的。当然根据需要来调整就好了。
发表于 2012-8-18 22:49:56 | 显示全部楼层
输出应该是与的关系而不是或的关系吧?
并且第一个触发器输出亚问题的时候怎么办?
发表于 2012-8-19 14:21:01 | 显示全部楼层
异步信号输入起码要用两个触发器打一下,第一用于同步,第二个用于消除亚稳态。
所以第一个图中应该再加一个触发器,第二个要三个或,也需要再加一个。
发表于 2012-8-19 16:33:48 | 显示全部楼层
用寄存器打两拍也不能完全消除亚稳态的出现,不让亚稳态出现的唯一办法是不用异步信号。当然打两拍能够大大减少亚稳态出现的概率。
发表于 2013-9-23 15:34:09 | 显示全部楼层
ghefjwefqwerjwerj
发表于 2013-9-23 15:51:39 | 显示全部楼层
学习了。。。。。
GMT+8, 2025-12-30 23:42 , Processed in 0.025962 second(s), 6 queries , Gzip On, Redis On.
