楼主: ic_qiand
[2011-11-1][Mentor][Calibre X86 X64 Doc][2011.2_16.14][原创] Calibre一贴搞定...
发表于 2012-10-15 22:44:21 | 显示全部楼层
楼主您好!
我按照你的方法安装设置后,输入calibre -gui出现如下信息,该怎么解决,求指教,我是新手!
WARNING: Calibre software tree not set, using software version at: /home/eda/calibre2011/x86_cal_2011.2_34.26
Application initialization failed: Can't find a usable init.tcl in the following directories:
    /home/eda/calibre2011/pkgs/icv_comp/8.4/lib/tcl8.4 /usr/local/lib/tcl /home/eda/calibre2011/x86_cal_2011.2_34.26/pkgs/icv/lib/tcl8.4 /home/eda/calibre2011/x86_cal_2011.2_34.26/pkgs/lib/tcl8.4 /home/eda/calibre2011/x86_cal_2011.2_34.26/pkgs/icv/library /home/eda/calibre2011/x86_cal_2011.2_34.26/pkgs/library /home/eda/calibre2011/x86_cal_2011.2_34.26/pkgs/tcl8.4.9/library /home/eda/calibre2011/x86_cal_2011.2_34.26/tcl8.4.9/library /home/eda/calibre2011/pkgs/icv_comp/8.4/lib/tcl
This probably means that Tcl wasn't installed properly.
发表于 2012-10-18 11:49:00 | 显示全部楼层
楼主好,请教一下,我安装32bit  calibre会宝segement fault错误,使用图形化安装方式会报
Supply valid installation source to continue.
The following was encountered while reading the source media:
ERROR reading zip file!...null
是什么问题,非常感谢!!
发表于 2012-10-18 13:17:21 | 显示全部楼层
Very good.
发表于 2012-10-19 14:42:11 | 显示全部楼层
顶一下
发表于 2012-10-20 12:04:34 | 显示全部楼层
费了不少信元了。还没有下完啊
发表于 2012-10-23 14:29:06 | 显示全部楼层
不知道下载了能不能装上~
发表于 2012-10-24 00:38:59 | 显示全部楼层
回复 4# frederick_gu
太好了,这个解释的还非常详细
发表于 2012-10-24 18:23:01 | 显示全部楼层
谢谢分享,下下来看看。
发表于 2012-10-24 23:39:49 | 显示全部楼层
谢谢分享,下来看看~~~
发表于 2012-10-27 21:25:58 | 显示全部楼层
楼主太热心
GMT+8, 2025-11-5 03:57 , Processed in 0.019977 second(s), 3 queries , Gzip On, Redis On.
