各位好,问一个问题哈,我要把ICC布局布线后的gds设计导到virtuoso中进行修改,请问怎么设置ICC的set_write_stream_options?
下面是我的report_write_stream_options的信息。
icc_shell> report_write_stream_options
Report stream out options
Layer mapping file name : (null)
Rename cell file name : (null)
Child cell depth : 0
Skip reference lib cells : false
Text height width ratio : 1.000000
Text width : 0.000000
Flatten contact : false
Flatten contact array : false
Contact prefix : $$
Output notch : false
Output gap : false
Output fill : false
Output outdated fill : false
Output instance name as property : false
Output geometry property : false
Strip backslash from instance net names : false
Long name length : -1
Keep data type : false
By layer number :
Output compressed OASIS : false
Output compressed GDSII : false
Output pin as text : false
Output pin as geometry : false
Pin name magnitude : 1.000000
Net name magnitude : 1.000000
Rotate pin text by access direction : false
Output net as text : false
Output net as property : false
Output net as plex : false
Output odd pin : false
Design intent struct name : (null)
Critical name list : (null)
Design intent layer mapping : (null)
With original data : true
Output design intent data : false
谢谢~~~~~ |
