在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 4467|回复: 0
[求助] libx11交叉编译(mips)问题
发表于 2011-1-9 21:41:45 | 显示全部楼层 |阅读模式
libx11编译是没有问题的呀(很顺利的就通过)
可是当我编译别的别东西时候用到这个库就出现下面的错误(换了个老的库就好了):
顺便说一下,编译libX11时libxcb,libxau这些依赖库也是自已编的,
/opt/gcc-3.4.6/bin/../lib/gcc/mipsel-linux/3.4.6/../../../../mipsel-linux/bin/ld: warning: libxcb.so.1, needed by /home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so, not found (try using -rpath or -rpath-link)
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_disconnect’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_writev’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_connect’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_generate_id’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_poll_for_event’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_wait_for_event’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_poll_for_reply’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_connect_to_display_with_auth_info’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_get_setup’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_wait_for_reply’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_connection_has_error’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_get_file_descriptor’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_get_maximum_request_length’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_parse_display’未定义的引用
/home/loongson/lib_mipsel_gcc3.4.6/libX11-1.3.2/lib/libX11.so:对‘xcb_take_socket’未定义的引用
请高手指点
GMT+8, 2024-4-27 06:46 , Processed in 0.018485 second(s), 10 queries , Gzip On, Redis On.
