在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 4399|回复: 4
adm5120 bootloader 源码鉴定
发表于 2009-6-23 18:35:23 | 显示全部楼层 |阅读模式
diff --git a/MAKEALL b/MAKEALL
index 74bf383..033b077 100755
--- a/MAKEALL
+++ b/MAKEALL
@@ -249,7 +249,7 @@ ########################################
## mips Systems  (little endian)
-LIST_mips4kc_el=""
+LIST_mips4kc_el="adm5120"
LIST_mips5kc_el=""
diff --git a/Makefile b/Makefile
index d2534ab..592fd50 100644
--- a/Makefile
+++ b/Makefile
@@ -2121,6 +2121,11 @@ incaip_config: unconfig
tb0229_config: unconfig
  @$(MKCONFIG) $(@:_config=) mips mips tb0229
+adm5120_config: unconfig
+ @mkdir -p $(obj)include
+ @ >$(obj)include/config.h
+ @$(MKCONFIG) $(@:_config=) mips mips adm5120
## MIPS32 AU1X00
diff --git a/board/adm5120/Makefile b/board/adm5120/Makefile
new file mode 100644
index 0000000..20ef1be
--- /dev/null
+++ b/board/adm5120/Makefile
@@ -0,0 +1,41 @@
+# (C) Copyright 2006
+# Robert Delien, <robert@delien.nl>
+# This program is free software; you can redistribute it and/or
+# modify it under the terms of the GNU General Public License as
+# published by the Free Software Foundation; either version 2 of
+# the License, or (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place, Suite 330, Boston,
+# MA 02111-1307 USA
+include $(TOPDIR)/config.mk
+LIB = $(obj)lib$(BOARD).a
+COBJS = $(BOARD).o
+SOBJS = memsetup.o
+SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c)
+OBJS := $(addprefix $(obj),$(COBJS))
+SOBJS := $(addprefix $(obj),$(SOBJS))
+$(LIB): $(obj).depend $(OBJS) $(SOBJS)
+ $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS)
+# defines $(obj).depend target
+include $(SRCTREE)/rules.mk
+sinclude $(obj).depend
diff --git a/board/adm5120/adm5120.c b/board/adm5120/adm5120.c
new file mode 100755
index 0000000..ea5593f
--- /dev/null
+++ b/board/adm5120/adm5120.c
@@ -0,0 +1,65 @@
+ * Board initialize code for ADMtek/Infineon adm5120 SoC.
+ * (C) Copyright 2006
+ * Robert Delien, + *
+ * This program is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU General Public License as
+ * published by the Free Software Foundation; either version 2 of
+ * the License, or (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
+ * MA 02111-1307 USA
+#include <common.h>
+#include <command.h>
+#include <adm51xx_switch.h>
+#include <asm/io.h>
+#if defined(CONFIG_PCI)
+static struct pci_controller hose;
+void pci_init_board (void)
+#endif
+long int initdram(int board_type)
+/* TODO: Make this work with CFG_SDRAM_MAX */
+ return get_ram_size ((void*)CFG_SDRAM_BASE, 16*1024*1024);
+int checkboard (void)
+ unsigned int value;
+ unsigned int mask;
+ printf("SoC:   Infineon ADM5120");
+ if (readl(SWITCH + SWITCH_CODE) & SWITCH_CODE__PK)
+  printf("/PQFP");
+ else
+  printf("/BGA");
+ printf(" @%dMHz ", (int)cpu_CLOCK_RATE/1000000);
+ mask = SWITCH_CODE__REV ;
+ value = readl(SWITCH + SWITCH_CODE) & mask ;
+ while ((mask & 1) == 0) {
+  mask >>= 1 ;
+  value >>= 1 ;
+ printf("(Rev: %04X)\n", value);
+ return 0;
diff --git a/board/adm5120/config.mk b/board/adm5120/config.mk
index 0000000..159de89
--- /dev/null
+++ b/board/adm5120/config.mk
@@ -0,0 +1,24 @@
+# ROM version
+TEXT_BASE = 0xBFC00000
+# RAM version, for debugging purposes
+#TEXT_BASE = 0xA0010000
diff --git a/board/adm5120/memsetup.S b/board/adm5120/memsetup.S
index 0000000..4e6ce8d
--- /dev/null
+++ b/board/adm5120/memsetup.S
@@ -0,0 +1,256 @@
+ * Low level initialization routine for ADMtek/Infineon adm5120 SoC.
+ * Robert Delien, <robert@delien.nl>
+ * Reverse-engineered from register contents of adm5120 in
+ * Sweex LB000021 'Broadband router' and Infineon data sheet.
+#include <config.h>
+#include <version.h>
+#include <asm/regdef.h>
+#include <asm/mipsregs.h>
+#include <adm5120_mpmc.h>
+ .globl  lowlevel_init
+lowlevel_init:
+ /* Setup pointers */
+ la a0, MPMC
+ la a1, SWITCH
+  * Initialize SRAM/ROM
+ /* Set MEM_CONT__SR0S to 2MiB, enable MEM_CONT__SDR1E, set MEM_CONT__SDRS to 4Mib x32*/
+ li t0, (SWITCH_MEM_CONT__SR0S_2MB | \
+       SWITCH_MEM_CONT__SDR1E |  \
+       SWITCH_MEM_CONT__SDRS_4Mx32)
+ sw t0, SWITCH_MEM_CONT(a1)
+ /* MPMC_SC1 */
+ li t0, (MPMC_SCx__BLS |   \
+       MPMC_SCx__MW_16BIT)
+ sw t0, MPMC_SC1(a0)
+ /* MPMC_SWW1 */
+ li t0, (MPMC_SWWx__WWE & 0)
+ sw t0, MPMC_SWW1(a0)
+ /* MPMC_SWO1 */
+ li t0, (MPMC_SWOx__SWO0 & 0)
+ sw t0, MPMC_SWO1(a0)
+ /* MPMC_SWR1 */
+ li t0, (MPMC_SWRx__NMRW & 9)
+ sw t0, MPMC_SWR1(a0)
+ /* MPMC_SWP1 */
+ li t0, (MPMC_SWPx__WPS & 31)
+ sw t0, MPMC_SWP1(a0)
+ /* MPMC_SWWR1 */
+ li t0, (MPMC_SWWRx__WWS & 9)
+ sw t0, MPMC_SWWR1(a0)
+ /* MPMC_SWT1 */
+ li t0, (MPMC_SWTx__WAITTURN & 5)
+ sw t0, MPMC_SWT1(a0)
+#if (TEXT_BASE >= 0xBFC00000)
+  * Initialize SDRAM (if running from ROM)
+ /* Disable address mirroring bit */
+ lw t0, MPMC_C(a0)
+ li t1, ~(MPMC_C__AM)
+ and t0, t0, t1
+ sw t0, MPMC_C(a0)
+ /* Set MPMC_DRP__PCP to 1 */
+ li t0, (MPMC_DRP__PCP & 1)
+ sw t0, MPMC_DRP(a0)
+ /* Set MPMC_DRAS__APCP to 4 */
+ li t0, (MPMC_DRAS__APCP & 4)
+ sw t0, MPMC_DRAS(a0)
+ /* Set MPMC_DSREX__SRET to 16 */
+ li t0, (MPMC_DSREX__SRET & 15)
+ sw t0, MPMC_DSREX(a0)
+ /* Set MPMC_DAPR__LACT */
+ li t0, (MPMC_DAPR__LACT & 1)
+ sw t0, MPMC_DAPR(a0)
+ /* Set MPMC_DDAL__DACT */
+ li t0, (MPMC_DDAL__DACT & 3)
+ sw t0, MPMC_DDAL(a0)
+ /* Set MPMC_DWR__WRT */
+ li t0, (MPMC_DWR__WRT & 1)
+ sw t0, MPMC_DWR(a0)
+ /* Set MPMC_DRC__AACP */
+ li t0, (MPMC_DRC__AACP & 6)
+ sw t0, MPMC_DRC(a0)
+ /* Set MPMC_DRFC__ARACP */
+ li t0, (MPMC_DRFC__ARACP & 6)
+ sw t0, MPMC_DRFC(a0)
+ /* Set MPMC_DXSR__EACP */
+ li t0, (MPMC_DXSR__EACP & 7)
+ sw t0, MPMC_DXSR(a0)
+ /* Set MPMC_DRRD__ABL */
+ li t0, (MPMC_DRRD__ABL & 1)
+ sw t0, MPMC_DRRD(a0)
+ /* Set MPMC_DMRD__LACT */
+ li t0, (MPMC_DMRD__LACT & 1)
+ sw t0, MPMC_DMRD(a0)
+ /* Switch to normal mode of operation, enable continueos clock, enable clock drive high */
+ lw t0, MPMC_DC(a0)
+ li t1, ~(MPMC_DC__SI)
+ and t0, t0, t1
+ li t1, (MPMC_DC__SI_NORMAL | \
+       MPMC_DC__DMC |   \
+       MPMC_DC__CE)
+ or t0, t0, t1
+ sw t0, MPMC_DC(a0)
+ /* Disable bank 0 buffers */
+ lw t0, MPMC_DC0(a0)
+ li t1, ~(MPMC_DCx__BE)
+ and t0, t0, t1
+ sw t0, MPMC_DC0(a0)
+ /* Disable bank 1 buffers */
+ lw t0, MPMC_DC1(a0)
+ and t0, t0, t1
+ sw t0, MPMC_DC1(a0)
+ /* Wait for 1ms to make sure SDRAM power and clocks have stabilized */
+ mtc0 zero, CP0_COUNT
+ li t0, CFG_CP0_COUNT_RATE/1000
+1:
+ mfc0 t1, CP0_COUNT
+ ble t1, t0, 1b
+ nop
+ /* Issue a NOP instruction to SDRAM modules */
+ and t0, t0, t1
+ li t1, MPMC_DC__SI_NOP
+ or t0, t0, t1
+ /* Wait 200us for NOP instruction to execute */
+ li t0, CFG_CP0_COUNT_RATE/5000
+1:
+ ble t1, t0, 1b
+ nop
+ /* Precharge all SDRAM modules */
+ and t0, t0, t1
+ li t1, MPMC_DC__SI_PALL
+ or t0, t0, t1
+ /* Set dynamic refresh to every 32 HCLK cycles */
+ li t0, (MPMC_DR__RT & (32/0x10))
+ sw t0, MPMC_DR(a0)
+ /* Wait 128 AHB cycles */
+ li t0,64
+1:
+ nop
+ nop
+ nop
+ nop
+ nop
+ addiu t0,t0,-1
+ bnez t0,1b
+ nop
+ /* Set dynamic refresh to every 1360 HCLK cycles */
+ li t0, (MPMC_DR__RT & (1360/0x10))
+ /* Set MPMC_DRC0__CASL and MPMC_DRC0__RASL to 2 */
+ li t0, 0x00000202
+ sw t0, MPMC_DRC0(a0)
+ /* Set MPMC_DC0 to 0x14804500 */
+ li t0, 0x14804500
+#if (CONFIG_NR_DRAM_BANKS > 1)
+ /* Set MPMC_DRC1__CASL and MPMC_DRC1__RASL to 2 */
+ li t0, 0x00000202
+ sw t0, MPMC_DRC1(a0)
+ /* Set MPMC_DC1 to 0x14804500 */
+ li t0, 0x14804500
+#endif /* (CONFIG_NR_DRAM_BANKS > 1) */
+ /* Switch to mode programming mode */
+ and t0, t0, t1
+ li t1, MPMC_DC__SI_MODE
+ or t0, t0, t1
+ /* Set mode of bank 0 */
+ li t0,0xA0022000
+ lw t1,0(t0)
+ /* Set mode of bank 1 */
+ li t0,0xA1022000
+ lw t1,0(t0)
+ /* Switch to normal operation mode, use dynamic memory clock */
+ and t0, t0, t1
+ li t1, ~(MPMC_DC__CE)
+ and t0, t0, t1
+ ori t0, t0, MPMC_DC__SI_NORMAL
+ /* Enable buffers bank 0 */
+ li t1, MPMC_DCx__BE
+ or t0, t0, t1
+ /* Enable buffers bank 1 */
+ or t0, t0, t1
+ sw t0,MPMC_DC1(a0)
+#endif /* TEXT_BASE == 0xBFC00000 */
+ j       ra
+ nop
diff --git a/board/adm5120/u-boot.lds b/board/adm5120/u-boot.lds
index 0000000..d2d47ff
--- /dev/null
+++ b/board/adm5120/u-boot.lds
@@ -0,0 +1,65 @@
+OUTPUT_FORMAT("elf32-tradlittlemips", "elf32-tradlittlemips", "elf32-tradlittlemips")
+OUTPUT_ARCH(mips)
+ENTRY(_start)
+SECTIONS
+ . = 0x00000000;
+ . = ALIGN(4);
+ .text       :
+   *(.text)
+ . = ALIGN(4);
+ .rodata  : { *(.rodata) }
+ . = ALIGN(4);
+ .data  : { *(.data) }
+ . = ALIGN(4);
+ .sdata  : { *(.sdata) }
+ . = ALIGN(16);
+ _gp = .;
+ __got_start = .;
+ .got  : { *(.got) }
+ __got_end = .;
+ __u_boot_cmd_start = .;
+ .u_boot_cmd : { *(.u_boot_cmd) }
+ __u_boot_cmd_end = .;
+ uboot_end_data = .;
+ num_got_entries = (__got_end - __got_start) >> 2;
+ . = ALIGN(4);
+ .sbss  : { *(.sbss) }
+ .bss  : { *(.bss) }
+ uboot_end = .;
diff --git a/board/dbau1x00/u-boot.lds b/board/dbau1x00/u-boot.lds
index 10c9917..150ae75 100644
--- a/board/dbau1x00/u-boot.lds
+++ b/board/dbau1x00/u-boot.lds
@@ -46,7 +46,8 @@ SECTIONS
  . = ALIGN(4);
- _gp = ALIGN(16);
+ . = ALIGN(16);
+ _gp = .;
  __got_start = .;
  .got  : { *(.got) }
diff --git a/board/gth2/u-boot.lds b/board/gth2/u-boot.lds
index 8ba0b6d..fa27e96 100644
--- a/board/gth2/u-boot.lds
+++ b/board/gth2/u-boot.lds
  . = ALIGN(4);
- _gp = ALIGN(16);
+ . = ALIGN(16);
+ _gp = .;
  __got_start = .;
  .got  : { *(.got) }
diff --git a/board/incaip/u-boot.lds b/board/incaip/u-boot.lds
--- a/board/incaip/u-boot.lds
+++ b/board/incaip/u-boot.lds
  . = ALIGN(4);
- _gp = ALIGN(16);
+ . = ALIGN(16);
+ _gp = .;
  __got_start = .;
  .got  : { *(.got) }
diff --git a/board/mcc200/Makefile b/board/mcc200/Makefile
index 75808cb..5869119 100644
--- a/board/mcc200/Makefile
+++ b/board/mcc200/Makefile
@@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS := $(BOARD).o lcd.o
+COBJS := $(BOARD).o lcd.o auto_update.o
diff --git a/board/mcc200/auto_update.c b/board/mcc200/auto_update.c
index 0000000..786543e
--- /dev/null
+++ b/board/mcc200/auto_update.c
@@ -0,0 +1,469 @@
+ * Wolfgang Denk, DENX Software Engineering, wd@denx.de.
+#include <malloc.h>
+#include <image.h>
+#include <asm/byteorder.h>
+#include <usb.h>
+#ifdef CFG_HUSH_PARSER
+#include <hush.h>
+#endif
+#ifdef CONFIG_AUTO_UPDATE
+#ifndef CONFIG_USB_OHCI
+#error "must define CONFIG_USB_OHCI"
+#endif
+#ifndef CONFIG_USB_STORAGE
+#error "must define CONFIG_USB_STORAGE"
+#endif
+#ifndef CFG_HUSH_PARSER
+#error "must define CFG_HUSH_PARSER"
+#endif
+#if !(CONFIG_COMMANDS & CFG_CMD_FAT)
+#error "must define CFG_CMD_FAT"
+#endif
+ * Check whether a USB memory stick is plugged in.
+ * If one is found:
+ * 1) if prepare.img ist found load it into memory. If it is
+ *  valid then run it.
+ * 2) if preinst.img is found load it into memory. If it is
+ *  valid then run it. Update the EEPROM.
+ * 3) if firmw_01.img is found load it into memory. If it is valid,
+ *  burn it into FLASH and update the EEPROM.
+ * 4) if kernl_01.img is found load it into memory. If it is valid,
+ * 5) if app.img is found load it into memory. If it is valid,
+ * 6) if disk.img is found load it into memory. If it is valid,
+ * 7) if postinst.img is found load it into memory. If it is
+#undef AU_DEBUG
+#undef debug
+#ifdef AU_DEBUG
+#define debug(fmt,args...) printf (fmt ,##args)
+#else
+#endif /* AU_DEBUG */
+/* possible names of files on the USB stick. */
+#define AU_FIRMWARE "u-boot.img"
+#define AU_KERNEL "kernel.img"
+struct flash_layout
+ long start;
+ long end;
+/* layout of the FLASH. ST = start address, ND = end address. */
+#define AU_FL_FIRMWARE_ST 0xfC000000
+#define AU_FL_FIRMWARE_ND 0xfC03FFFF
+#define AU_FL_KERNEL_ST  0xfC0C0000
+#define AU_FL_KERNEL_ND  0xfC1BFFFF
+static int au_usb_stor_curr_dev; /* current device */
+/* index of each file in the following arrays */
+#define IDX_FIRMWARE 0
+#define IDX_KERNEL 1
+/* max. number of files which could interest us */
+#define AU_MAXFILES 2
+/* pointers to file names */
+char *aufile[AU_MAXFILES];
+/* sizes of flash areas for each file */
+long ausize[AU_MAXFILES];
+/* array of flash areas start and end addresses */
+struct flash_layout aufl_layout[AU_MAXFILES] = { \
+ {AU_FL_FIRMWARE_ST, AU_FL_FIRMWARE_ND,}, \
+ {AU_FL_KERNEL_ST, AU_FL_KERNEL_ND,}, \
+/* where to load files into memory */
+#define LOAD_ADDR ((unsigned char *)0x00200000)
+/* the app is the largest image */
+#define MAX_LOADSZ ausize[IDX_KERNEL]
+/*i2c address of the keypad status*/
+#define I2C_PSOC_KEYPAD_ADDR 0x53
+/* keypad mask */
+#define KEYPAD_ROW 3
+#define KEYPAD_COL 3
+#define KEYPAD_MASK_LO ((1<<(KEYPAD_COL-1+(KEYPAD_ROW*4-4)))&0xFF)
+#define KEYPAD_MASK_HI ((1<<(KEYPAD_COL-1+(KEYPAD_ROW*4-4)))>>8)
+/* externals */
+extern int fat_register_device(block_dev_desc_t *, int);
+extern int file_fat_detectfs(void);
+extern long file_fat_read(const char *, void *, unsigned long);
+extern int i2c_read (unsigned char, unsigned int, int , unsigned char* , int);
+extern int flash_sect_erase(ulong, ulong);
+extern int flash_sect_protect (int, ulong, ulong);
+extern int flash_write (char *, ulong, ulong);
+/* change char* to void* to shutup the compiler */
+extern block_dev_desc_t *get_dev (char*, int);
+extern int u_boot_hush_start(void);
+int
+au_check_cksum_valid(int idx, long nbytes)
+ image_header_t *hdr;
+ unsigned long checksum;
+ hdr = (image_header_t *)LOAD_ADDR;
+ if (nbytes != (sizeof(*hdr) + ntohl(hdr->ih_size)))
+  printf ("Image %s bad total SIZE\n", aufile[idx]);
+  return -1;
+ /* check the data CRC */
+ checksum = ntohl(hdr->ih_dcrc);
+ if (crc32 (0, (uchar *)(LOAD_ADDR + sizeof(*hdr)), ntohl(hdr->ih_size))
+  != checksum)
+  printf ("Image %s bad data checksum\n", aufile[idx]);
+  return -1;
+ return 0;
+int
+au_check_header_valid(int idx, long nbytes)
+ unsigned char buf[4];
+ /* check the easy ones first */
+#undef CHECK_VALID_DEBUG
+#ifdef CHECK_VALID_DEBUG
+ printf("magic %#x %#x ", ntohl(hdr->ih_magic), IH_MAGIC);
+ printf("arch %#x %#x ", hdr->ih_arch, IH_CPU_arm);
+ printf("size %#x %#lx ", ntohl(hdr->ih_size), nbytes);
+ printf("type %#x %#x ", hdr->ih_type, IH_TYPE_KERNEL);
+#endif
+ if (nbytes < sizeof(*hdr))
+  printf ("Image %s bad header SIZE\n", aufile[idx]);
+  return -1;
+ if (ntohl(hdr->ih_magic) != IH_MAGIC || hdr->ih_arch != IH_CPU_PPC)
+  printf ("Image %s bad MAGIC or ARCH\n", aufile[idx]);
+  return -1;
+ /* check the hdr CRC */
+ checksum = ntohl(hdr->ih_hcrc);
+ hdr->ih_hcrc = 0;
+ if (crc32 (0, (uchar *)hdr, sizeof(*hdr)) != checksum) {
+  printf ("Image %s bad header checksum\n", aufile[idx]);
+  return -1;
+ hdr->ih_hcrc = htonl(checksum);
+ /* check the type - could do this all in one gigantic if() */
+ if ((idx == IDX_FIRMWARE) && (hdr->ih_type != IH_TYPE_FIRMWARE)) {
+  printf ("Image %s wrong type\n", aufile[idx]);
+  return -1;
+ if ((idx == IDX_KERNEL) && (hdr->ih_type != IH_TYPE_KERNEL)) {
+  return -1;
+ /* recycle checksum */
+ checksum = ntohl(hdr->ih_size);
+ /* for kernel and app the image header must also fit into flash */
+ if (idx != IDX_FIRMWARE)
+  checksum += sizeof(*hdr);
+ /* check the size does not exceed space in flash. HUSH scripts */
+ /* all have ausize[] set to 0 */
+ if ((ausize[idx] != 0) && (ausize[idx] < checksum)) {
+  printf ("Image %s is bigger than FLASH\n", aufile[idx]);
+  return -1;
+ return 0;
+int
+au_do_update(int idx, long sz)
+ char *addr;
+ long start, end;
+ int off, rc;
+ uint nbytes;
+ /* execute a script */
+ if (hdr->ih_type == IH_TYPE_SCRIPT) {
+  addr = (char *)((char *)hdr + sizeof(*hdr));
+  /* stick a NULL at the end of the script, otherwise */
+  /* parse_string_outer() runs off the end. */
+  addr[ntohl(hdr->ih_size)] = 0;
+  addr += 8;
+  parse_string_outer(addr, FLAG_PARSE_SEMICOLON);
+  return 0;
+ start = aufl_layout[idx].start;
+ end = aufl_layout[idx].end;
+ /* unprotect the address range */
+ /* this assumes that ONLY the firmware is protected! */
+ if (idx == IDX_FIRMWARE) {
+#undef AU_UPDATE_TEST
+#ifdef AU_UPDATE_TEST
+  /* erase it where Linux goes */
+  start = aufl_layout[1].start;
+  end = aufl_layout[1].end;
+#endif
+  flash_sect_protect(0, start, end);
+  * erase the address range.
+ debug ("flash_sect_erase(%lx, %lx);\n", start, end);
+ flash_sect_erase(start, end);
+ wait_ms(100);
+ /* strip the header - except for the kernel and ramdisk */
+ if (hdr->ih_type == IH_TYPE_KERNEL) {
+  addr = (char *)hdr;
+  off = sizeof(*hdr);
+  nbytes = sizeof(*hdr) + ntohl(hdr->ih_size);
+ } else {
+  /* copy it to where Linux goes */
+#endif
+  off = 0;
+  nbytes = ntohl(hdr->ih_size);
+ /* copy the data from RAM to FLASH */
+ debug ("flash_write(%p, %lx %x)\n", addr, start, nbytes);
+ rc = flash_write(addr, start, nbytes);
+ if (rc != 0) {
+  printf("Flashing failed due to error %d\n", rc);
+  return -1;
+ /* check the dcrc of the copy */
+ if (crc32 (0, (uchar *)(start + off), ntohl(hdr->ih_size)) != ntohl(hdr->ih_dcrc)) {
+  printf ("Image %s Bad Data Checksum After COPY\n", aufile[idx]);
+  return -1;
+ /* protect the address range */
+  flash_sect_protect(1, start, end);
+ return 0;
+ * this is called from board_init() after the hardware has been set up
+ * and is usable. That seems like a good time to do this.
+ * Right now the return value is ignored.
+int
+do_auto_update(void)
+ block_dev_desc_t *stor_dev;
+ long sz;
+ int i, res, bitmap_first, cnt, old_ctrlc, got_ctrlc;
+ char *env;
+ long start, end;
+ char keypad_status1[2] = {0,0}, keypad_status2[2] = {0,0};
+  * Read keypad status
+ i2c_read(I2C_PSOC_KEYPAD_ADDR, 0, 0, keypad_status1, 2);
+ wait_ms(500);
+ i2c_read(I2C_PSOC_KEYPAD_ADDR, 0, 0, keypad_status2, 2);
+  * Check keypad
+ if ( !(keypad_status1[0] & KEYPAD_MASK_HI) ||
+       (keypad_status1[0] != keypad_status2[0])) {
+  return 0;
+ if ( !(keypad_status1[1] & KEYPAD_MASK_LO) ||
+       (keypad_status1[1] != keypad_status2[1])) {
+  return 0;
+ au_usb_stor_curr_dev = -1;
+ /* start USB */
+ if (usb_stop() < 0) {
+  debug ("usb_stop failed\n");
+  return -1;
+ if (usb_init() < 0) {
+  debug ("usb_init failed\n");
+  return -1;
+  * check whether a storage device is attached (assume that it's
+  * a USB memory stick, since nothing else should be attached).
+ au_usb_stor_curr_dev = usb_stor_scan(0);
+ if (au_usb_stor_curr_dev == -1) {
+  debug ("No device found. Not initialized?\n");
+  return -1;
+ /* check whether it has a partition table */
+ stor_dev = get_dev("usb", 0);
+ if (stor_dev == NULL) {
+  debug ("uknown device type\n");
+  return -1;
+ if (fat_register_device(stor_dev, 1) != 0) {
+  debug ("Unable to use USB %d:%d for fatls\n",
+   au_usb_stor_curr_dev, 1);
+  return -1;
+ if (file_fat_detectfs() != 0) {
+  debug ("file_fat_detectfs failed\n");
+ /* initialize the array of file names */
+ memset(aufile, 0, sizeof(aufile));
+ aufile[IDX_FIRMWARE] = AU_FIRMWARE;
+ aufile[IDX_KERNEL] = AU_KERNEL;
+ /* initialize the array of flash sizes */
+ memset(ausize, 0, sizeof(ausize));
+ ausize[IDX_FIRMWARE] = (AU_FL_FIRMWARE_ND + 1) - AU_FL_FIRMWARE_ST;
+ ausize[IDX_KERNEL] = (AU_FL_KERNEL_ND + 1) - AU_FL_KERNEL_ST;
+  * now check whether start and end are defined using environment
+  * variables.
+ start = -1;
+ end = 0;
+ env = getenv("firmware_st");
+ if (env != NULL)
+  start = simple_strtoul(env, NULL, 16);
+ env = getenv("firmware_nd");
+ if (env != NULL)
+  end = simple_strtoul(env, NULL, 16);
+ if (start >= 0 && end && end > start) {
+  ausize[IDX_FIRMWARE] = (end + 1) - start;
+  aufl_layout[0].start = start;
+  aufl_layout[0].end = end;
+ start = -1;
+ end = 0;
+ env = getenv("kernel_st");
+ if (env != NULL)
+ env = getenv("kernel_nd");
+ if (env != NULL)
+  ausize[IDX_KERNEL] = (end + 1) - start;
+  aufl_layout[1].start = start;
+  aufl_layout[1].end = end;
+ /* make certain that HUSH is runnable */
+ u_boot_hush_start();
+ /* make sure that we see CTRL-C and save the old state */
+ old_ctrlc = disable_ctrlc(0);
+ bitmap_first = 0;
+ /* just loop thru all the possible files */
+ for (i = 0; i < AU_MAXFILES; i++) {
+  /* just read the header */
+  sz = file_fat_read(aufile, LOAD_ADDR, sizeof(image_header_t));
+  debug ("read %s sz %ld hdr %d\n",
+   aufile, sz, sizeof(image_header_t));
+  if (sz <= 0 || sz < sizeof(image_header_t)) {
+   debug ("%s not found\n", aufile);
+   continue;
+  if (au_check_header_valid(i, sz) < 0) {
+   debug ("%s header not valid\n", aufile);
+   continue;
+  sz = file_fat_read(aufile, LOAD_ADDR, MAX_LOADSZ);
+  if (sz <= 0 || sz <= sizeof(image_header_t)) {
+   continue;
+  if (au_check_cksum_valid(i, sz) < 0) {
+   debug ("%s checksum not valid\n", aufile);
+   continue;
+  /* this is really not a good idea, but it's what the */
+  /* customer wants. */
+  cnt = 0;
+  got_ctrlc = 0;
+  do {
+   res = au_do_update(i, sz);
+   /* let the user break out of the loop */
+   if (ctrlc() || had_ctrlc()) {
+    clear_ctrlc();
+    if (res < 0)
+     got_ctrlc = 1;
+    break;
+   cnt++;
+#ifdef AU_TEST_ONLY
+  } while (res < 0 && cnt < 3);
+  if (cnt < 3)
+#else
+  } while (res < 0);
+#endif
+ usb_stop();
+ /* restore the old state */
+ disable_ctrlc(old_ctrlc);
+ return 0;
+#endif /* CONFIG_AUTO_UPDATE */
diff --git a/board/mcc200/mcc200.c b/board/mcc200/mcc200.c
index 5d74bde..67969a6 100644
--- a/board/mcc200/mcc200.c
+++ b/board/mcc200/mcc200.c
@@ -44,6 +44,7 @@ DECLARE_GLOBAL_DATA_PTR;
extern flash_info_t flash_info[]; /* FLASH chips info */
+extern int do_auto_update(void);
ulong flash_get_size (ulong base, int banknum);
#ifndef CFG_RAMBOOT
@@ -227,6 +228,10 @@ int misc_init_r (void)
  ulong flash_sup_end, snum;
+ /* this has priority over all else */
+ do_auto_update();
+#endif
   * Adjust flash start and offset to detected values
diff --git a/board/pb1x00/u-boot.lds b/board/pb1x00/u-boot.lds
index a2d19a8..5ef8ba7 100644
--- a/board/pb1x00/u-boot.lds
+++ b/board/pb1x00/u-boot.lds
  . = ALIGN(4);
- _gp = ALIGN(16);
+ . = ALIGN(16);
+ _gp = .;
  __got_start = .;
  .got  : { *(.got) }
diff --git a/board/purple/u-boot.lds b/board/purple/u-boot.lds
index 1bdac1f..4c1f0d3 100644
--- a/board/purple/u-boot.lds
+++ b/board/purple/u-boot.lds
@@ -56,7 +56,8 @@ SECTIONS
  . = ALIGN(4);
- _gp = ALIGN(16);
+ . = ALIGN(16);
+ _gp = .;
  __got_start = .;
  .got  : { *(.got) }
diff --git a/board/tb0229/u-boot.lds b/board/tb0229/u-boot.lds
index 30a2bc5..55c0b19 100644
--- a/board/tb0229/u-boot.lds
+++ b/board/tb0229/u-boot.lds
  . = ALIGN(4);
- _gp = ALIGN(16);
+ . = ALIGN(16);
+ _gp = .;
  __got_start = .;
  .got  : { *(.got) }
diff --git a/cpu/mips/cache.S b/cpu/mips/cache.S
index aad76e0..e1251c7 100644
--- a/cpu/mips/cache.S
+++ b/cpu/mips/cache.S
@@ -267,3 +267,76 @@ mips_cache_lock:
  j ra
  .end mips_cache_lock
+* _dma_cache_wback_inv - Write back and invalidate cache
+* a0: start address
+* a1: size
+* RETURNS: N/A
+ .globl _dma_cache_wback_inv
+ .ent _dma_cache_wback_inv
+_dma_cache_wback_inv:
+ and t0, a0, ~(CFG_CACHELINE_SIZE-1) /* Round down start address to t0 */
+ add t1, t0, a1   /* Load end address in t1 */
+1:
+ cache 0x15, 0(t0)   /* Hit writeback invalidate D */
+ add t0, t0, CFG_CACHELINE_SIZE /* Next line */
+ blt t0, t1, 1b   /* Check if we're done */
+ nop     /* Delay slot */
+ j ra
+ .end _dma_cache_wback_inv
+* _dma_cache_wback - Write back cache
+* a1: size
+* RETURNS: N/A
+_dma_cache_wback:
+1:
+ cache 0x19, 0(t0)   /* Hit writeback D */
+ j ra
+* _dma_cache_inv - Invalidate cache
+* a1: size
+* RETURNS: N/A
+ .globl _dma_cache_inv
+ .ent _dma_cache_inv
+_dma_cache_inv:
+1:
+ cache 0x11, 0(t0)   /* Hit invalidate D */
+ j ra
+ .end _dma_cache_inv
diff --git a/cpu/mips/config.mk b/cpu/mips/config.mk
index b29986e..caac276 100644
--- a/cpu/mips/config.mk
+++ b/cpu/mips/config.mk
@@ -30,8 +30,10 @@ else \
fi)
ifneq (,$(findstring 4KCle,$(CROSS_COMPILE)))
+BIG_ENDIAN = n
ENDIANNESS = -EL
else
+BIG_ENDIAN = y
ENDIANNESS = -EB
endif
diff --git a/cpu/mips/cpu.c b/cpu/mips/cpu.c
old mode 100644
new mode 100755
index f48675e..f4edf76
--- a/cpu/mips/cpu.c
+++ b/cpu/mips/cpu.c
@@ -25,6 +25,10 @@ #include <common.h>
#include <asm/inca-ip.h>
+#ifdef CONFIG_ADM5120
+#  include <asm/io.h>
+#  include <adm51xx_switch.h>
+#endif /* CONFIG_ADM5120 */
int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
@@ -34,6 +38,8 @@ #elif defined(CONFIG_PURPLE) || defined(
  void (*f)(void) = (void *) 0xbfc00000;
  f();
+#elif defined(CONFIG_ADM5120)
+ writel(0, CONFIG_ADM51xx_SWITCH_BASE + SWITCH_SFT_RES);
#endif
  fprintf(stderr, "*** reset failed ***\n");
  return 0;
diff --git a/cpu/mips/start.S b/cpu/mips/start.S
old mode 100644
new mode 100755
index e91e213..332e581
--- a/cpu/mips/start.S
+++ b/cpu/mips/start.S
@@ -29,15 +29,16 @@ #include <asm/regdef.h>
-#define RVECENT(f,n) \
-   b f; nop
-#define XVECENT(f,bev) \
-   b f     ;           \
-   li k0,bev
+#define RVECENT(f,n) \
+ b f; \
+ nop
- .set noreorder
+#define XVECENT(f,bev) \
+ b f; \
+ li k0, bev
- .globl _start
+ .set noreorder
+ .globl _start
  .text
_start:
  RVECENT(reset,0) /* U-boot entry point */
@@ -226,10 +227,6 @@ #endif
  /* CAUSE register */
  mtc0 zero, CP0_CAUSE
- /* Init Timer */
- mtc0 zero, CP0_COUNT
- mtc0 zero, CP0_COMPARE
  /* CONFIG0 register */
  li t0, CONF_CM_UNCACHED
  mtc0 t0, CP0_CONFIG
@@ -334,7 +331,27 @@ #endif
  /* If caches were enabled, we would have to flush them here.
+ li t3, CFG_SDRAM_BASE  /* Load start address in t3 */
+ and t3, t3, 0x1FFFFFFF  /* Convert t3 to physical address */
+ or t3, t3, 0x80000000  /* Convert t3 to cached alias */
+ add t4, t3, CFG_DCACHE_SIZE  /* Load start address in t4 */
+ mtc0 CP0_TAGLO, zero
+1:
+ cache 0x9, 0(t3)   /* Index store tag D */
+ add t3, t3, CFG_CACHELINE_SIZE
+ bne t3, t4, 1b
+ nop
+ addu t4, t3, CFG_ICACHE_SIZE  /* Load start address in t4 */
+1:
+ cache 0x0, 0(t3)   /* Index invalidate tag I */
+ bne t3, t4, 1b
+ nop
  /* Jump to where we've relocated ourselves.
  addi t0, a2, in_ram - _start
@@ -384,7 +401,9 @@ in_ram:
  /* Exception handlers.
romReserved:
- b romReserved
+ b romReserved
+ nop
romExcHandle:
- b romExcHandle
+ b romExcHandle
+ nop
diff --git a/doc/README.adm5120 b/doc/README.adm5120
index 0000000..a09858a
--- /dev/null
+++ b/doc/README.adm5120
@@ -0,0 +1,133 @@
+U-Boot for Infineon ADM5120
+Robert Delien
[email=+robert@delien.nl]+robert@delien.nl[/email]
+www.delien.nl
+Tue Oct 17 14:05:30 CEST 2006
+1. Overview
+The Infineon ADM5120 is a MIPS32 4Kc based SoC commonly found in many
+low end router products.  See
+ http://www.linux-mips.org/wiki/Adm5120#Products_based_on_the_ADM5120
+for a list of devices using the ADM5120.
+2. Updating U-Boot using U-Boot
+To update U-Boot using U-boot, the following procedure can be used:
+2.1 Using the serial port, indirectly
+With this procedure, U-Boot is loaded to RAM first. From there it can
+be written to FLASH memory.
+Setup U-Boot to receive a new version of U-Boot, using an offset of
+0xE0410000 to make sure U-Boot (build for address 0xBFC00000) is loaded
+at address 0xA0010000. (Note: the prompt is "ADM5120 # ")
+ ADM5120 # loads E0410000
+ ## Ready for S-Record download ...
+Send the S-Record file file with you terminal program
+ ## First Load Addr = 0xA0010000
+ ## Last  Load Addr = 0xA0023BC7
+ ## Total Size      = 0x00013BC8 = 80840 Bytes
+ ## Start Addr      = 0xBFC00000
+Disable protection of NOR FLASH
+ ADM5120 # protect off all
+ Un-Protect Flash Bank # 1
+Erase the NOR FLASH area to write U-Boot to
+ ADM5120 # erase BFC00000 +30000
+ ..... done
+ Erased 5 sectors
+Copy U-Boot to NOR FLASH
+ ADM5120 # cp.b 0xA0010000 0xBFC00000 0x00030000
+ Copy to Flash... done
+Reset the board
+ ADM5120 # reset
+ U-Boot 1.1.6-g4684cddb-dirty (Dec 11 2006 - 19:21:02)
+ SoC:   Infineon ADM5120/PQFP @175MHz (Rev: 0008)
+ DRAM:  16 MB
+ Flash:  2 MB
+ In:    serial
+ Out:   serial
+ Err:   serial
+ Hit any key to stop autoboot:  0
+ ADM5120 #
+2.2 Using the serial port, directly
+With this procedure, U-Boot is loaded to FLASH memory directly.
+ ..... done
+ Erased 5 sectors
+Setup U-Boot to receive a new version of U-Boot (Note: the prompt is
+"ADM5120 # ").
+ ADM5120 # loads
+ ## First Load Addr = 0xBFC00000
+ ## Last  Load Addr = 0xBFC23BC7
+2.3 Using Ethernet, indirectly
+Put the binary file on a TFTP server and have U-Boot load in into
+memory. You can specify the name of the file and the destination
+address. If you don't the environment variables 'loadaddr' and
+'bootfile' to specify them.
+ ADM5120 # tftp 0xA0010000 u-boot.bin
+ Using adm0 device
+ TFTP from server 192.168.1.10; our IP address is 192.168.1.25
+ Filename 'u-boot.bin'.
+ Load address: 0xa0010000
+ Loading: ############################
+ done
+ Bytes transferred = 140444 (2249c hex)
+ ..... done
+ Erased 5 sectors
+2.4 Using Ethernet, directly
+Use your imagination...
+3. Configuring U-Boot
+To configure and build U-Boot for the ADM5120 do
+ $ make adm5120_config
+ $ make
diff --git a/drivers/Makefile b/drivers/Makefile
index 5a369df..cf38029 100644
--- a/drivers/Makefile
+++ b/drivers/Makefile
@@ -27,7 +27,7 @@ # CFLAGS += -DET_DEBUG -DDEBUG
LIB = $(obj)libdrivers.a
-COBJS = 3c589.o 5701rls.o ali512x.o atmel_usart.o \
+COBJS = 3c589.o 5701rls.o adm51xx_switch.o ali512x.o atmel_usart.o \
    bcm570x.o bcm570x_autoneg.o cfb_console.o cfi_flash.o \
    cs8900.o ct69000.o dataflash.o dc2114x.o dm9000x.o \
    e1000.o eepro100.o \
diff --git a/drivers/adm51xx_switch.c b/drivers/adm51xx_switch.c
index 0000000..dfdf17f
--- /dev/null
+++ b/drivers/adm51xx_switch.c
@@ -0,0 +1,592 @@
+ * adm51xx_eth.c -- Ethernet driver for ADM5120, ADM5106 (untested)
+ *                  and possibly more SoCs
+ * Copyright (c) 2006 SATO Masuhiro <thomas@fenix.ne.jp>
+ * See file CREDITS for list of people who contributed to this
+ * project.
+ * Usage for this driver is difficult to explain, since ADM5120 Ether
+ * net controler has programable HUB.
+ * - ADM5120 has 6 HUBs, which makes VLAN.
+ * - The software send/receive packets to/from CPU port on the VLANs
+ *   instead of physical Ether NET ports.
+ * Setting of the HUB can be overrided by environment value, "ethports", like
+ * ethports=0x4f,0x50
+ * This parameter makes.
+ * VLAN0: port0, port1, port2, port3, cpu
+ * VLAN1: port4, cpu
+#if (CONFIG_COMMANDS & CFG_CMD_NET) && defined(CONFIG_NET_MULTI) && \
+ defined(CONFIG_ADM51xx_SWITCH)
+#include <net.h>
+#define RX_HP_BUF_COUNT 4
+#define TX_HP_BUF_COUNT 4
+#define RX_BUF_COUNT 4
+#define TX_BUF_COUNT 4
+#define BUFSIZE  1536
+#define DESC_OWN_SC 0x80000000
+#define DESC_RING_END 0x10000000
+struct buf_desc {
+ u32 buffer1;
+ u32 buffer2;
+ u32 buffer1_length;
+ u32 flags;
+} __attribute__((packed));
+static int adm5120_eth_init(struct eth_device* dev, bd_t * bd);
+static void adm5120_eth_halt(struct eth_device *dev);
+static int adm5120_eth_recv(struct eth_device *dev);
+static int adm5120_eth_send(struct eth_device *dev, volatile void *packet, int length);
+static int adm5120_eth_update(void);
+static void init_buffer(void);
+static int init_buf_ring(struct buf_desc *buf_desc, int count, u8 *buf, u32 own);
+static void adm5120_switch_init(void);
+static int tx_hp_update(void);
+static int tx_update(void);
+static int rx_hp_update(void);
+static int rx_update(void);
+/* all ports are connected to VLAN0 */
+static u8 port_map[SWITCH__VLAN_PORTS] = {
+ SWITCH__PORT_CPU | SWITCH__PORT_4 | SWITCH__PORT_3 | SWITCH__PORT_2 | SWITCH__PORT_1 | SWITCH__PORT_0
+static u32 port_enable;
+static int tx_put, tx_done, tx_hp_put, tx_hp_done;
+static int rx_put, rx_done, rx_suspend, rx_hp_put, rx_hp_done, rx_hp_suspend;
+/* buffers for high priority packets */
+static u8 tx_hp_buf[RX_HP_BUF_COUNT * BUFSIZE] __attribute__((aligned(32)));
+static u8 rx_hp_buf[TX_HP_BUF_COUNT * BUFSIZE] __attribute__((aligned(32)));
+/* buffers for normal priority packets */
+static u8 tx_buf[RX_BUF_COUNT * BUFSIZE] __attribute__((aligned(32)));
+static u8 rx_buf[TX_BUF_COUNT * BUFSIZE] __attribute__((aligned(32)));
+struct buf_desc rx_hp_desc[RX_HP_BUF_COUNT] __attribute__((aligned(32)));
+struct buf_desc tx_hp_desc[TX_HP_BUF_COUNT] __attribute__((aligned(32)));
+struct buf_desc rx_desc[RX_BUF_COUNT] __attribute__((aligned(32)));
+struct buf_desc tx_desc[TX_BUF_COUNT] __attribute__((aligned(32)));
+int adm5120_eth_initialize(bd_t *bis)
+ char *p;
+ int i;
+ if ((p = getenv("ethports")) != NULL) {
+  long ports;
+  i = 0;
+  memset(port_map, 0, sizeof(port_map));
+  while (*p) {
+   ports = simple_strtol(p, &p, 0x10);
+   if (ports)
+    port_map[i++] = (u8)ports;
+   if (*p == 0)
+    break;
+   if (*p != ',' && *p != ':')
+    break;
+   p++;
+ adm5120_switch_init();
+#ifdef DEBUG
+ printf("adm5120_eth port groups ");
+#endif
+ for (i = 0; i < SWITCH__VLAN_PORTS && port_map != 0; i++) {
+  struct eth_device *dev;
+#ifdef DEBUG
+  int j;
+  u8 bit = 0x01;
+  printf("%d:", i);
+  for (j = 0; j < SWITCH__PHYS_PORTS + 2; j++) {
+   if (bit & port_map) {
+    if (j > 0)
+     printf(".", j);
+    printf("%d", j);
+   bit <<= 1;
+  printf(" ");
+#endif
+  dev = (struct eth_device *)malloc(sizeof(struct eth_device));
+  if (dev == NULL) {
+   printf("\nadm5120_eth_initialize(): malloc() failed\n");
+   break;
+  memset(dev, 0, sizeof(struct eth_device));
+  sprintf(dev->name, "adm%d", i);
+  dev->iobase = 0;
+  dev->priv   = (void *)i;
+  dev->init   = adm5120_eth_init;
+  dev->halt   = adm5120_eth_halt;
+  dev->send   = adm5120_eth_send;
+  dev->recv   = adm5120_eth_recv;
+  eth_register(dev);
+ return 1;
+static void adm5120_switch_init()
+ int i;
+ writel( SWITCH_CPUP_CONF__CRCP,
+  SWITCH_CPUP_CONF + CONFIG_ADM51xx_SWITCH_BASE );
+ writel( SWITCH_PORT_CONF0__DP,
+  SWITCH_PORT_CONF0 + CONFIG_ADM51xx_SWITCH_BASE );
+ barrier();
+ udelay(10000);
+ writel( SWITCH_VLAN_GI__VLAN0_SET(port_map[0]) |
+  SWITCH_VLAN_GI__VLAN1_SET(port_map[1]) |
+  SWITCH_VLAN_GI__VLAN2_SET(port_map[2]) |
+  SWITCH_VLAN_GI__VLAN3_SET(port_map[3]),
+  SWITCH_VLAN_GI + CONFIG_ADM51xx_SWITCH_BASE );
+ writel( SWITCH_VLAN_GII__VLAN4_SET(port_map[4]) |
+  SWITCH_VLAN_GII__VLAN5_SET(port_map[5]),
+  SWITCH_VLAN_GII + CONFIG_ADM51xx_SWITCH_BASE );
+ barrier();
+ port_enable = 0;
+ for (i = 0; i < SWITCH__VLAN_PORTS; i++)
+  port_enable |= port_map;
+#ifdef DEBUG
+ printf("port_enable = %08x\n", port_enable);
+#endif
+ /* CPU port to be disabled, CRC padding, disable unknown packets */
+ writel( SWITCH_CPUP_CONF__DCPUP |
+  SWITCH_CPUP_CONF__CRCP |
+  SWITCH_CPUP_CONF__DUNP_SET(SWITCH__PORTS_NET),
+ /* enable ports, multicast, back pressure */
+ writel( SWITCH_PORT_CONF0__DP_SET(~port_enable) |
+  SWITCH_PORT_CONF0__EMCP_SET(port_enable) |
+  SWITCH_PORT_CONF0__EBP_SET(port_enable),
+ writel( SWITCH_PORT_CONF1__SASM_SET(0) |
+  SWITCH_PORT_CONF1__PA_SET(port_enable) |
+  SWITCH_PORT_CONF1__BM_SET(0) |
+  SWITCH_PORT_CONF1__BS_SET(0) |
+  SWITCH_PORT_CONF1__DISL_SET(0),
+  SWITCH_PORT_CONF1 + CONFIG_ADM51xx_SWITCH_BASE );
+ if (port_enable & SWITCH__PORT_GIGA) {
+  writel( SWITCH_PORT_CONF2__GMIIAN | /* AN enable */
+   SWITCH_PORT_CONF2__FMPS_100M | /* 100M */
+   SWITCH_PORT_CONF2__FMDP | /* full duplex */
+   SWITCH_PORT_CONF2__FMPFC_RXTX, /* flow control */
+   SWITCH_PORT_CONF2 + CONFIG_ADM51xx_SWITCH_BASE );
+ } else {
+  writel( SWITCH_PORT_CONF2__FMPS_100M | /* 100M */
+   SWITCH_PORT_CONF2__FMPFC_RXTX | /* flow control */
+   SWITCH_PORT_CONF2__TXCC, /* disable check TXC */
+ barrier();
+ udelay(10000);
+ writel( SWITCH_PHY_CNTL2__ANE_SET(port_enable) | /* auto negotiation */
+  SWITCH_PHY_CNTL2__SC_SET(port_enable) |  /* speed control */
+  SWITCH_PHY_CNTL2__DC_SET(port_enable) |  /* duplex control */
+  SWITCH_PHY_CNTL2__RFCV_SET(port_enable) | /* FC rec */
+  SWITCH_PHY_CNTL2__PHYR_SET(port_enable),  /* disable reset */
+  SWITCH_PHY_CNTL2 + CONFIG_ADM51xx_SWITCH_BASE );
+#if 1
+ writel( SWITCH_PHY_CNTL3__DFEFI |
+  SWITCH_PHY_CNTL3__RPIC |
+  SWITCH_PHY_CNTL3__RRJE |
+  SWITCH_PHY_CNTL3__RBLL_VAL(0) |
+  SWITCH_PHY_CNTL3__PFRV_VAL(2) |
+  SWITCH_PHY_CNTL3__RBLL_VAL(3),
+  SWITCH_PHY_CNTL3 + CONFIG_ADM51xx_SWITCH_BASE );
+#else
+ writel( SWITCH_PHY_CNTL3__RPIC |
+#endif
+ /* Mask all interrupts */
+ writel( SWITCH_INT_MASK__ALL_INTS,
+  SWITCH_INT_MASK + CONFIG_ADM51xx_SWITCH_BASE );
+ /* Clear all pending interrupts */
+ writel( readl(SWITCH_INT_ST + CONFIG_ADM51xx_SWITCH_BASE),
+  SWITCH_INT_ST + CONFIG_ADM51xx_SWITCH_BASE );
+ barrier();
+ int i;
+ memset(buf, 0, BUFSIZE * count);
+ for (i = 0; i < count; i++) {
+  buf_desc.buffer1 = own |
+   ((i == count - 1) ? DESC_RING_END : 0) |
+   virt_to_phys(buf + (i * BUFSIZE));
+  buf_desc.buffer2 = 0;
+  buf_desc.buffer1_length = BUFSIZE;
+  buf_desc.flags = 0;
+ dma_cache_wback_inv((unsigned long)buf,      BUFSIZE * count);
+ dma_cache_wback_inv((unsigned long)buf_desc, sizeof(struct buf_desc) * count);
+ return i;
+static void init_buffer()
+ tx_put = 0;
+ tx_done = 0;
+ tx_hp_put = 0;
+ tx_hp_done = 0;
+ rx_put = 0;
+ rx_done = 0;
+ rx_suspend = RX_BUF_COUNT;
+ rx_hp_put = 0;
+ rx_hp_done = 0;
+ rx_hp_suspend = RX_HP_BUF_COUNT;
+ init_buf_ring(tx_hp_desc, TX_HP_BUF_COUNT, tx_hp_buf, 0);
+ init_buf_ring(rx_hp_desc, RX_HP_BUF_COUNT, rx_hp_buf, DESC_OWN_SC);
+ init_buf_ring(tx_desc,    TX_BUF_COUNT,    tx_buf,    0);
+ init_buf_ring(rx_desc,    RX_BUF_COUNT,    rx_buf,    DESC_OWN_SC);
+ writel(virt_to_phys(tx_hp_desc), CONFIG_ADM51xx_SWITCH_BASE + SWITCH_SEND_HBADDR);
+ writel(virt_to_phys(tx_desc),    CONFIG_ADM51xx_SWITCH_BASE + SWITCH_SEND_LBADDR);
+ writel(virt_to_phys(rx_hp_desc), CONFIG_ADM51xx_SWITCH_BASE + SWITCH_REC_HBADDR);
+ writel(virt_to_phys(rx_desc),    CONFIG_ADM51xx_SWITCH_BASE + SWITCH_REC_LBADDR);
+ barrier();
+static int adm5120_eth_init(struct eth_device *dev, bd_t *bd)
+#ifdef DEBUG
+ printf( "adm5120_eth_init(): priv=%p dev->enetaddr=%02x:%02x:%02x:%02x:%02x:%02x\n",
+  dev->priv,
+  dev->enetaddr[0],
+  dev->enetaddr[1],
+  dev->enetaddr[2],
+  dev->enetaddr[3],
+  dev->enetaddr[4],
+  dev->enetaddr[5] );
+#endif
+ init_buffer();
+ /* Enable CPU port */
+ writel( readl(SWITCH_CPUP_CONF + CONFIG_ADM51xx_SWITCH_BASE) & ~SWITCH_CPUP_CONF__DCPUP,
+ writel( SWITCH_MAC_WT1__MWA_B5(dev->enetaddr[5]) |
+  SWITCH_MAC_WT1__MWA_B4(dev->enetaddr[4]) |
+  SWITCH_MAC_WT1__MWA_B3(dev->enetaddr[3]) |
+  SWITCH_MAC_WT1__MWA_B2(dev->enetaddr[2]),
+  SWITCH_MAC_WT1 + CONFIG_ADM51xx_SWITCH_BASE );
+ writel( SWITCH_MAC_WT0__MWA_B1(dev->enetaddr[1]) |
+  SWITCH_MAC_WT0__MWA_B0(dev->enetaddr[0]) |
+  SWITCH_MAC_WT0__WAF_SET(1) |
+  SWITCH_MAC_WT0__WVE |
+  SWITCH_MAC_WT0__WVN_SET((unsigned)dev->priv) |
+  SWITCH_MAC_WT0__MAWC,
+  SWITCH_MAC_WT0 + CONFIG_ADM51xx_SWITCH_BASE );
+ barrier();
+ /* Wait for the MAC address write to complete */
+ while ((readl(SWITCH_MAC_WT0 + CONFIG_ADM51xx_SWITCH_BASE) & SWITCH_MAC_WT0__MWD) == 0)
+ barrier();
+ return(1);
+ /* Disable CPU port */
+ writel( readl(SWITCH_CPUP_CONF + CONFIG_ADM51xx_SWITCH_BASE) | SWITCH_CPUP_CONF__DCPUP,
+ barrier();
+ udelay(10000);
+ u8 *bp;
+ int retry;
+ struct buf_desc *dp;
+ retry =  100;
+ while (tx_put - tx_done == TX_BUF_COUNT && --retry) {
+  udelay(1000);
+  adm5120_eth_update();
+ if (retry == 0)
+  return 0;
+ bp = tx_buf + BUFSIZE * (tx_put % TX_BUF_COUNT);
+ memcpy(bp, packet, length);
+ dp = &tx_desc[tx_put % TX_BUF_COUNT];
+ dp->buffer1_length = length;
+ if (length < 60)
+  length = 60;
+ dp->flags = (length << 16) | (1 << (unsigned)dev->priv);
+ dp->buffer1 |= DESC_OWN_SC;
+ dma_cache_wback_inv((unsigned long)bp, length);
+ dma_cache_wback_inv((unsigned long)dp, sizeof(struct buf_desc));
+ writel( SWITCH_SEND_TRIG__STL,
+  SWITCH_SEND_TRIG + CONFIG_ADM51xx_SWITCH_BASE );
+ barrier();
+#ifdef DEBUG
+ printf( "adm5120_eth_tx(), tx_put=%d, desc=%p, buf=%p, len=%d\n",
+  tx_put, dp, bp, length );
+#endif
+ tx_put++;
+ return length;
+ volatile struct buf_desc *dp;
+ u8 *bp;
+ int len;
+ len = 0;
+ if (rx_put == rx_done && rx_hp_put == rx_hp_done)
+  while (rx_hp_put > rx_hp_done) {
+  bp = rx_hp_buf + BUFSIZE * (rx_hp_done % RX_BUF_COUNT);
+  dp = &rx_hp_desc[rx_hp_done % RX_BUF_COUNT];
+  len = dp->flags >> 16;
+  if (len > 0) {
+   NetReceive(bp, len);
+   dma_cache_inv((unsigned long)bp, len);
+  rx_hp_done++;
+  rx_hp_suspend++;
+#ifdef DEBUG
+  printf( "adm5120_eth_rx() pull %d bytes. rx_hp_done=%d\n",
+   len, rx_hp_done );
+#endif
+ while (rx_put > rx_done) {
+  bp = rx_buf + BUFSIZE * (rx_done % RX_BUF_COUNT);
+  dp = &rx_desc[rx_done % RX_BUF_COUNT];
+  if (len > 0) {
+  rx_done++;
+  rx_suspend++;
+#ifdef DEBUG
+  printf( "adm5120_eth_rx() pull %d bytes. rx_done=%d\n",
+   len, rx_done );
+#endif
+ return 0;
+static int rx_update()
+ int n = 0;
+ while (rx_put < rx_suspend) {
+  dp = &rx_desc[rx_put % RX_BUF_COUNT];
+  dma_cache_inv((unsigned long)dp, sizeof(struct buf_desc));
+  if ((dp->buffer1 & DESC_OWN_SC) != 0)
+   break;
+  rx_put++;
+  n++;
+#ifdef DEBUG
+  printf( "rx_update() rx_put=%0d, rx_suspend=%d\n",
+   rx_put, rx_suspend );
+#endif
+ return n;
+static int rx_hp_update()
+ int n = 0;
+ while (rx_hp_put < rx_hp_suspend) {
+  dp = &rx_hp_desc[rx_put % RX_BUF_COUNT];
+   break;
+  rx_hp_put++;
+  n++;
+ return n;
+static int tx_update()
+ int n = 0;
+ while (tx_put > tx_done) {
+  dp = &tx_desc[rx_put % RX_BUF_COUNT];
+   break;
+  tx_done++;
+  n++;
+#ifdef DEBUG
+  printf( "tx_update() tx_put=%0d, tx_done=%d\n",
+   tx_put, tx_done );
+#endif
+ if (tx_put > tx_done) {
+  barrier();
+ return n;
+static int tx_hp_update()
+ int n = 0;
+ while (tx_hp_put > tx_hp_done) {
+  dp = &tx_hp_desc[rx_put % RX_BUF_COUNT];
+   break;
+  tx_hp_done++;
+  n++;
+#ifdef DEBUG
+  printf( "tx_hp_update() tx_hp_put=%0d, tx_hp_done=%d\n",
+   tx_hp_put, tx_hp_done );
+#endif
+ return n;
+static int adm5120_eth_update()
+ int n = 0;
+ n += rx_hp_update();
+ n += rx_update();
+ n += tx_hp_update();
+ n += tx_update();
+ return n;
+#endif
diff --git a/drivers/serial_pl010.c b/drivers/serial_pl010.c
index 417b6ae..dc798a2 100644
--- a/drivers/serial_pl010.c
+++ b/drivers/serial_pl010.c
@@ -29,14 +29,12 @@
/* Should be fairly simple to make it work with the PL010 as well */
#include <common.h>
#ifdef CFG_PL010_SERIAL
#include "serial_pl011.h"
-#define IO_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (val))
-#define IO_READ(addr) (*(volatile unsigned int *)(addr))
/* Integrator AP has two UARTs, we use the first one, at 38400-8-N-1 */
#define CONSOLE_PORT CONFIG_CONS_INDEX
#define baudRate CONFIG_BAUDRATE
@@ -56,7 +54,7 @@ int serial_init (void)
   ** First, disable everything.
- IO_WRITE (port[CONSOLE_PORT] + UART_PL010_CR, 0x0);
+ writel (0x0, port[CONSOLE_PORT] + UART_PL010_CR);
   ** Set baud rate
@@ -64,43 +62,32 @@ int serial_init (void)
  switch (baudRate) {
  case 9600:
-  divisor = UART_PL010_BAUD_9600;
-  break;
  case 19200:
-  break;
  case 38400:
-  divisor = UART_PL010_BAUD_38400;
-  break;
  case 57600:
-  divisor = UART_PL010_BAUD_57600;
-  break;
  case 115200:
-  divisor = UART_PL010_BAUD_115200;
+  divisor = UART_PL010_BAUD2DIVISOR(baudRate);
   break;
  default:
+  divisor = UART_PL010_BAUD2DIVISOR(38400);
- IO_WRITE (port[CONSOLE_PORT] + UART_PL010_LCRM,
-    ((divisor & 0xf00) >> 8));
- IO_WRITE (port[CONSOLE_PORT] + UART_PL010_LCRL, (divisor & 0xff));
+ writel (((divisor & 0xf00) >> 8),
+  port[CONSOLE_PORT] + UART_PL010_LCRM);
+ writel ((divisor & 0xff),
+  port[CONSOLE_PORT] + UART_PL010_LCRL);
   ** Set the UART to be 8 bits, 1 stop bit, no parity, fifo enabled.
- IO_WRITE (port[CONSOLE_PORT] + UART_PL010_LCRH,
-    (UART_PL010_LCRH_WLEN_8 | UART_PL010_LCRH_FEN));
+ writel ((UART_PL010_LCRH_WLEN_8 | UART_PL010_LCRH_FEN),
+  port[CONSOLE_PORT] + UART_PL010_LCRH);
   ** Finally, enable the UART
- IO_WRITE (port[CONSOLE_PORT] + UART_PL010_CR, (UART_PL010_CR_UARTEN));
+ writel ((UART_PL010_CR_UARTEN), port[CONSOLE_PORT] + UART_PL010_CR);
  return (0);
@@ -137,10 +124,10 @@ void serial_setbrg (void)
static void pl010_putc (int portnum, char c)
  /* Wait until there is space in the FIFO */
- while (IO_READ (port[portnum] + UART_PL01x_FR) & UART_PL01x_FR_TXFF);
+ while (readl (port[portnum] + UART_PL01x_FR) & UART_PL01x_FR_TXFF);
  /* Send the character */
- IO_WRITE (port[portnum] + UART_PL01x_DR, c);
+ writel (c, port[portnum] + UART_PL01x_DR);
static int pl010_getc (int portnum)
@@ -148,14 +135,14 @@ static int pl010_getc (int portnum)
  unsigned int data;
  /* Wait until there is data in the FIFO */
- while (IO_READ (port[portnum] + UART_PL01x_FR) & UART_PL01x_FR_RXFE);
+ while (readl (port[portnum] + UART_PL01x_FR) & UART_PL01x_FR_RXFE);
- data = IO_READ (port[portnum] + UART_PL01x_DR);
+ data = readl (port[portnum] + UART_PL01x_DR);
  /* Check for an error flag */
  if (data & 0xFFFFFF00) {
   /* Clear the error */
-  IO_WRITE (port[portnum] + UART_PL01x_ECR, 0xFFFFFFFF);
+  writel (0xFFFFFFFF, port[portnum] + UART_PL01x_ECR);
   return -1;
@@ -164,7 +151,7 @@ static int pl010_getc (int portnum)
static int pl010_tstc (int portnum)
- return !(IO_READ (port[portnum] + UART_PL01x_FR) &
+ return !(readl (port[portnum] + UART_PL01x_FR) &
diff --git a/drivers/serial_pl011.h b/drivers/serial_pl011.h
old mode 100644
new mode 100755
index 5f20fdd..b99aa1a
--- a/drivers/serial_pl011.h
+++ b/drivers/serial_pl011.h
@@ -77,18 +77,8 @@ #define UART_PL010_LCRH_EPS
#define UART_PL010_LCRH_PEN             (1 << 1)
#define UART_PL010_LCRH_BRK             (1 << 0)
+#define UART_PL010_BAUD2DIVISOR(baud) ((CFG_UART_PL010_CLOCK+(0x8*(baud)))/(0x10*(baud))-1)
-#define UART_PL010_BAUD_460800            1
-#define UART_PL010_BAUD_230400            3
-#define UART_PL010_BAUD_115200            7
-#define UART_PL010_BAUD_57600             15
-#define UART_PL010_BAUD_38400             23
-#define UART_PL010_BAUD_19200             47
-#define UART_PL010_BAUD_14400             63
-#define UART_PL010_BAUD_9600              95
-#define UART_PL010_BAUD_4800              191
-#define UART_PL010_BAUD_2400              383
-#define UART_PL010_BAUD_1200              767
  *  PL011 definitions
diff --git a/examples/Makefile b/examples/Makefile
index 423a79b..7729915 100644
--- a/examples/Makefile
+++ b/examples/Makefile
@@ -121,6 +121,8 @@ endif
ifeq ($(BIG_ENDIAN),y)
EX_LDFLAGS += -EB
+else
+EX_LDFLAGS += -EL
endif
COBJS := $(SREC:.srec=.o)
diff --git a/include/adm5120_glb.h b/include/adm5120_glb.h
index 0000000..9ffe52e
--- /dev/null
+++ b/include/adm5120_glb.h
@@ -0,0 +1,37 @@
+ * Definitions for memory memory map of
+ * ADMtek/Infineon adm5120 SoC.
+#ifndef ADM5120_GLB_H
+#define ADM5120_GLB_H
+#define TO_PHYSICAL(addr)  ((unsigned long)(addr) & 0x1FFFFFFFUL)
+#define TO_UNCACHED(addr)  ((unsigned long)(addr) | 0xA0000000UL)
+#define TO_CACHED(addr)   ((unsigned long)(addr) | 0x80000000UL)
+#define UART_1    0xB2800000
+#define UART_0    0xB2600000
+#define INTC    0xB2200000
+#define SWITCH    0xB2000000
+#define MPMC    0xB1000000
+#endif /* ADM5120_GLB_H */
diff --git a/include/adm5120_mpmc.h b/include/adm5120_mpmc.h
index 0000000..5ac74c0
--- /dev/null
+++ b/include/adm5120_mpmc.h
@@ -0,0 +1,123 @@
+ * Register definitions for memory controller of
+#ifndef ADM5120_MPMC_H
+#define ADM5120_MPMC_H
+#define MPMC_C    0x00000000
+#define MPMC_S    0x00000004
+#define MPMC_CONF   0x00000008
+#define MPMC_DC    0x00000020
+#define MPMC_DR    0x00000024
+#define MPMC_DRP   0x00000030
+#define MPMC_DRAS   0x00000034
+#define MPMC_DSREX   0x00000038
+#define MPMC_DAPR   0x0000003C
+#define MPMC_DDAL   0x00000040
+#define MPMC_DWR   0x00000044
+#define MPMC_DRC   0x00000048
+#define MPMC_DRFC   0x0000004C
+#define MPMC_DXSR   0x00000050
+#define MPMC_DRRD   0x00000054
+#define MPMC_DMRD   0x00000058
+#define MPMC_SEW   0x00000080
+#define MPMC_DC0   0x00000100
+#define MPMC_DRC0   0x00000104
+#define MPMC_DC1   0x00000120
+#define MPMC_DRC1   0x00000124
+#define MPMC_DC2   0x00000140
+#define MPMC_DRC2   0x00000144
+#define MPMC_DC3   0x00000160
+#define MPMC_DRC3   0x00000164
+#define MPMC_SC0   0x00000200
+#define MPMC_SWW0   0x00000204
+#define MPMC_SWO0   0x00000208
+#define MPMC_SWR0   0x0000020C
+#define MPMC_SWP0   0x00000210
+#define MPMC_SWWR0   0x00000214
+#define MPMC_SWT0   0x00000218
+#define MPMC_SC1   0x00000220
+#define MPMC_SWW1   0x00000224
+#define MPMC_SWO1   0x00000228
+#define MPMC_SWR1   0x0000022C
+#define MPMC_SWP1   0x00000230
+#define MPMC_SWWR1   0x00000234
+#define MPMC_SWT1   0x00000238
+#define MPMC_C__AM   (1<<1)
+#define MPMC_C__ME   (1<<0)
+#define MPMC_DC__SI   (3<<7)
+#define MPMC_DC__SI_NORMAL  (0<<7)
+#define MPMC_DC__SI_MODE  (1<<7)
+#define MPMC_DC__SI_PALL  (2<<7)
+#define MPMC_DC__SI_NOP   (3<<7)
+#define MPMC_DC__DMC   (1<<1)
+#define MPMC_DC__CE   (1<<0)
+#define MPMC_DRP__PCP   0x0000000F
+#define MPMC_DRAS__APCP   0x0000000F
+#define MPMC_DSREX__SRET  0x0000000F
+#define MPMC_DAPR__LACT   0x0000000F
+#define MPMC_DDAL__DACT   0x0000000F
+#define MPMC_DWR__WRT   0x0000000F
+#define MPMC_DRC__AACP   0x0000001F
+#define MPMC_DRFC__ARACP  0x0000001F
+#define MPMC_DXSR__EACP   0x0000001F
+#define MPMC_DRRD__ABL   0x0000000F
+#define MPMC_DMRD__LACT   0x0000000F
+#define MPMC_DR__RT   0x000007FF
+#define MPMC_DCx__BE   (1<<19)
+#define MPMC_SCx__BLS   (1<<7)
+#define MPMC_SCx__MW   (3<<0)
+#define MPMC_SCx__MW_8BIT  (0<<0)
+#define MPMC_SCx__MW_16BIT  (1<<0)
+#define MPMC_SCx__MW_32BIT  (2<<0)
+#define MPMC_SCx__MW_RES  (3<<0)
+#define MPMC_SWWx__WWE   0x0000000F
+#define MPMC_SWOx__SWO0   0x0000000F
+#define MPMC_SWRx__NMRW   0x0000000F
+#define MPMC_SWPx__WPS   0x0000001F
+#define MPMC_SWWRx__WWS   0x0000001F
+#define MPMC_SWTx__WAITTURN  0x0000000F
+#endif /* ADM5120_MPMC_H */
diff --git a/include/adm51xx_switch.h b/include/adm51xx_switch.h
index 0000000..01a81be
--- /dev/null
+++ b/include/adm51xx_switch.h
@@ -0,0 +1,369 @@
+ * Register definitions for switch controller of
+ * ADMtek/Infineon adm5120 and adm5106 SoC.
+#ifndef ADM51xx_SWITCH_H
+#define ADM51xx_SWITCH_H
+ * Layout of Switch registers
+#define SWITCH_CODE   0x00000000
+#define SWITCH_SFT_RES   0x00000004
+#define SWITCH_BOOT_D   0x00000008
+#define SWITCH_SW_RES   0x0000000C
+#define SWITCH_PHY_ST   0x00000014
+#define SWITCH_PORT_ST   0x00000018
+#define SWITCH_MEM_CONT   0x0000001C
+#define SWITCH_SW_CONF   0x00000020
+#define SWITCH_CPUP_CONF  0x00000024
+#define SWITCH_PORT_CONF0  0x00000028
+#define SWITCH_PORT_CONF1  0x0000002C
+#define SWITCH_PORT_CONF2  0x00000030
+#define SWITCH_RES_1   0x00000034
+#define SWITCH_RES_2   0x00000038
+#define SWITCH_RES_3   0x0000003C
+#define SWITCH_VLAN_GI   0x00000040
+#define SWITCH_VLAN_GII   0x00000044
+#define SWITCH_SEND_TRIG  0x00000048
+#define SWITCH_SRCH_CMD   0x0000004C
+#define SWITCH_ADDR_ST0   0x00000050
+#define SWITCH_ADDR_ST1   0x00000054
+#define SWITCH_MAC_WT0   0x00000058
+#define SWITCH_MAC_WT1   0x0000005C
+#define SWITCH_BW_CNTL0   0x00000060
+#define SWITCH_BW_CNTL1   0x00000064
+#define SWITCH_PHY_CNTL0  0x00000068
+#define SWITCH_PHY_CNTL1  0x0000006C
+#define SWITCH_FC_TH   0x00000070
+#define SWITCH_ADJ_PORT_TH  0x00000074
+#define SWITCH_PORT_TH   0x00000078
+#define SWITCH_PHY_CNTL2  0x0000007C
+#define SWITCH_PHY_CNTL3  0x00000080
+#define SWITCH_PRI_CNTL   0x00000084
+#define SWITCH_VLAN_PRI   0x00000088
+#define SWITCH_TOS_EN   0x0000008C
+#define SWITCH_TOS_MAP0   0x00000090
+#define SWITCH_TOS_MAP1   0x00000094
+#define SWITCH_CUSTOM_PRI1  0x00000098
+#define SWITCH_CUSTOM_PRI2  0x0000009C
+#define SWITCH_PHY_CNTL4  0x000000A0
+#define SWITCH_EMPTY_CNT  0x000000A4
+#define SWITCH_PORT_CNT_SEL  0x000000A8
+#define SWITCH_PORT_CNT   0x000000AC
+#define SWITCH_INT_ST   0x000000B0
+#define SWITCH_INT_MASK   0x000000B4
+#define SWITCH_GPIO_CONF0  0x000000B8
+#define SWITCH_GPIO_CONF2  0x000000BC
+#define SWITCH_WDOG_0   0x000000C0
+#define SWITCH_WDOG_1   0x000000C4
+#define SWITCH_SWAP_IN   0x000000C8
+#define SWITCH_SWAP_OUT   0x000000CC
+#define SWITCH_SEND_HBADDR  0x000000D0
+#define SWITCH_SEND_LBADDR  0x000000D4
+#define SWITCH_REC_HBADDR  0x000000D8
+#define SWITCH_REC_LBADDR  0x000000DC
+#define SWITCH_SEND_HWADDR  0x000000E0
+#define SWITCH_SEND_LWADDR  0x000000E4
+#define SWITCH_REC_HWADDR  0x000000E8
+#define SWITCH_REC_LWADDR  0x000000EC
+#define SWITCH_TIMER_INT  0x000000F0
+#define SWITCH_TIMER   0x000000F4
+#define SWITCH_RES_4   0x000000F8
+#define SWITCH_RES_5   0x000000FC
+#define SWITCH_PORT0_LED  0x00000100
+#define SWITCH_PORT1_LED  0x00000104
+#define SWITCH_PORT2_LED  0x00000108
+#define SWITCH_PORT3_LED  0x0000010C
+#define SWITCH_GL_ST   0x00000010
+#define SWITCH_PORT4_LED  0x00000110
+ * Generic macros
+#define SWITCH__PHYS_PORTS  5
+#define SWITCH__VLAN_PORTS  6
+#define SWITCH__PORT_0   0x01
+#define SWITCH__PORT_1   0x02
+#define SWITCH__PORT_2   0x04
+#define SWITCH__PORT_3   0x08
+#define SWITCH__PORT_4   0x10
+#define SWITCH__PORTS_PHYS  (SWITCH__PORT_0  |\
+      SWITCH__PORT_1  |\
+      SWITCH__PORT_2  |\
+      SWITCH__PORT_3  |\
+      SWITCH__PORT_4)
+#define SWITCH__PORT_GIGA  0x20
+#define SWITCH__PORTS_NET  (SWITCH__PORTS_PHYS |\
+      SWITCH__PORT_GIGA)
+#define SWITCH__PORT_CPU  0x40
+#define SWITCH__PORTS_ALL  (SWITCH__PORTS_NET |\
+      SWITCH__PORT_CPU)
+ * Code register fields
+#define SWITCH_CODE__PK   (0x00000001<<29)
+#define SWITCH_CODE__CLKS  (0x00000003<<20)
+#define SWITCH_CODE__CLKS_175MHZ (0x00000000<<20)
+#define SWITCH_CODE__CLKS_200MHZ (0x00000001<<20)
+#define SWITCH_CODE__CLKS_RES1  (0x00000002<<20)
+#define SWITCH_CODE__CLKS_RES2  (0x00000003<<20)
+#define SWITCH_CODE__REV  (0x0000000F<<16)
+#define SWITCH_CODE__PC   (0x0000FFFF<<0)
+ * CPU port configuration register fields
+#define SWITCH_CPUP_CONF__DBCP  (SWITCH__PORTS_NET<<24)
+#define SWITCH_CPUP_CONF__DBCP_SET(set) (((set)&(SWITCH__PORTS_NET))<<24)
+#define SWITCH_CPUP_CONF__DMCP  (SWITCH__PORTS_NET<<16)
+#define SWITCH_CPUP_CONF__DMCP_SET(set) (((set)&(SWITCH__PORTS_NET))<<16)
+#define SWITCH_CPUP_CONF__DUNP  (SWITCH__PORTS_NET<<9)
+#define SWITCH_CPUP_CONF__DUNP_SET(set) (((set)&(SWITCH__PORTS_NET))<<9)
+#define SWITCH_CPUP_CONF__BTM  (0x00000001<<2)
+#define SWITCH_CPUP_CONF__CRCP  (0x00000001<<1)
+#define SWITCH_CPUP_CONF__DCPUP  (0x00000001<<0)
+ * Port configuration 0 register fields
+#define SWITCH_PORT_CONF0__EBP  (SWITCH__PORTS_NET<<16)
+#define SWITCH_PORT_CONF0__EBP_SET(set) (((set)&(SWITCH__PORTS_NET))<<16)
+#define SWITCH_PORT_CONF0__EMCP  (SWITCH__PORTS_NET<<8)
+#define SWITCH_PORT_CONF0__EMCP_SET(set)(((set)&(SWITCH__PORTS_NET))<<8)
+#define SWITCH_PORT_CONF0__DP  (SWITCH__PORTS_NET<<0)
+#define SWITCH_PORT_CONF0__DP_SET(set) (((set)&(SWITCH__PORTS_NET))<<0)
+ * Port configuration 1 register fields
+#define SWITCH_PORT_CONF1__SASM  (SWITCH__PORTS_NET<<26)
+#define SWITCH_PORT_CONF1__SASM_SET(set) (((set)&(SWITCH__PORTS_NET))<<26)
+#define SWITCH_PORT_CONF1__PA  (SWITCH__PORTS_NET<<20)
+#define SWITCH_PORT_CONF1__PA_SET(set) (((set)&(SWITCH__PORTS_NET))<<20)
+#define SWITCH_PORT_CONF1__BM  (SWITCH__PORTS_NET<<12)
+#define SWITCH_PORT_CONF1__BM_SET(set) (((set)&(SWITCH__PORTS_NET))<<12)
+#define SWITCH_PORT_CONF1__BS  (SWITCH__PORTS_NET<<6)
+#define SWITCH_PORT_CONF1__BS_SET(set) (((set)&(SWITCH__PORTS_NET))<<6)
+#define SWITCH_PORT_CONF1__DISL  (SWITCH__PORTS_NET<<0)
+#define SWITCH_PORT_CONF1__DISL_SET(set) (((set)&(SWITCH__PORTS_NET))<<0)
+ * Port configuration 2 register fields
+#define SWITCH_PORT_CONF2__DUPF  (SWITCH__PORTS_NET<<18)
+#define SWITCH_PORT_CONF2__DUPF_SET(set) (((set)&(SWITCH__PORTS_NET))<<18)
+#define SWITCH_PORT_CONF2__LEDFT (0x00000003<<16)
+#define SWITCH_PORT_CONF2__LEDFT_30 (0x00000000<<16)
+#define SWITCH_PORT_CONF2__LEDFT_60 (0x00000001<<16)
+#define SWITCH_PORT_CONF2__LEDFT_240 (0x00000002<<16)
+#define SWITCH_PORT_CONF2__LEDFT_480 (0x00000003<<16)
+#define SWITCH_PORT_CONF2__CER  (0x00000003<<9)
+#define SWITCH_PORT_CONF2__CER_0 (0x00000000<<9)
+#define SWITCH_PORT_CONF2__CER_1 (0x00000001<<9)
+#define SWITCH_PORT_CONF2__CER_2 (0x00000002<<9)
+#define SWITCH_PORT_CONF2__CER_3 (0x00000003<<9)
+#define SWITCH_PORT_CONF2__TXCC  (0x00000001<<8)
+#define SWITCH_PORT_CONF2__RMIIM (0x00000001<<7)
+#define SWITCH_PORT_CONF2__FMPFC (0x00000003<<4)
+#define SWITCH_PORT_CONF2__FMPFC_RX (0x00000001<<4)
+#define SWITCH_PORT_CONF2__FMPFC_TX (0x00000002<<4)
+#define SWITCH_PORT_CONF2__FMPFC_RXTX (0x00000003<<4)
+#define SWITCH_PORT_CONF2__FMDP  (0x00000001<<3)
+#define SWITCH_PORT_CONF2__FMPS  (0x00000003<<1)
+#define SWITCH_PORT_CONF2__FMPS_10M (0x00000000<<1)
+#define SWITCH_PORT_CONF2__FMPS_100M (0x00000001<<1)
+#define SWITCH_PORT_CONF2__FMPS_1G (0x00000002<<1)
+#define SWITCH_PORT_CONF2__GMIIAN (0x00000001<<0)
+ * VLAN Group 1 register fields
+#define SWITCH_VLAN_GI__VLAN3  (SWITCH__PORTS_ALL<<24)
+#define SWITCH_VLAN_GI__VLAN3_SET(set) (((set)&(SWITCH__PORTS_ALL))<<24)
+#define SWITCH_VLAN_GI__VLAN2  (SWITCH__PORTS_ALL<<16)
+#define SWITCH_VLAN_GI__VLAN2_SET(set) (((set)&(SWITCH__PORTS_ALL))<<16)
+#define SWITCH_VLAN_GI__VLAN1  (SWITCH__PORTS_ALL<<8)
+#define SWITCH_VLAN_GI__VLAN1_SET(set) (((set)&(SWITCH__PORTS_ALL))<<8)
+#define SWITCH_VLAN_GI__VLAN0  (SWITCH__PORTS_ALL<<0)
+#define SWITCH_VLAN_GI__VLAN0_SET(set) (((set)&(SWITCH__PORTS_ALL))<<0)
+ * VLAN Group 2 register fields
+#define SWITCH_VLAN_GII__VLAN5  (SWITCH__PORTS_ALL<<8)
+#define SWITCH_VLAN_GII__VLAN5_SET(set) (((set)&(SWITCH__PORTS_ALL))<<8)
+#define SWITCH_VLAN_GII__VLAN4  (SWITCH__PORTS_ALL<<0)
+#define SWITCH_VLAN_GII__VLAN4_SET(set) (((set)&(SWITCH__PORTS_ALL))<<0)
+ * Send trigger register fields
+#define SWITCH_SEND_TRIG__STH  (0x00000001<<1)
+#define SWITCH_SEND_TRIG__STL  (0x00000001<<0)
+ * MAC Write Address 0 register fields
+#define SWITCH_MAC_WT0__MWA  (0x0000FFFF<<16)
+#define SWITCH_MAC_WT0__MWA_B0(b0) (((b0)&(0xFF))<<16)
+#define SWITCH_MAC_WT0__MWA_B1(b1) (((b1)&(0xFF))<<24)
+#define SWITCH_MAC_WT0__WAF  (0x00000007<<13)
+#define SWITCH_MAC_WT0__WAF_SET(set) (((set)&(0x00000007))<<13)
+#define SWITCH_MAC_WT0__WPMN  (0x0000003F<<7)
+#define SWITCH_MAC_WT0__WPMN_SET(set) (((set)&(0x0000003F))<<7)
+#define SWITCH_MAC_WT0__WVE  (0x00000001<<6)
+#define SWITCH_MAC_WT0__WVN  (0x00000007<<3)
+#define SWITCH_MAC_WT0__WVN_SET(set) (((set)&(0x00000007))<<3)
+#define SWITCH_MAC_WT0__WFB  (0x00000001<<2)
+#define SWITCH_MAC_WT0__MWD  (0x00000001<<1)
+#define SWITCH_MAC_WT0__MAWC  (0x00000001<<0)
+ * MAC Write Address 1 register fields
+#define SWITCH_MAC_WT1__MWA  (0xFFFFFFFF<<0)
+#define SWITCH_MAC_WT1__MWA_B5(b5) (((b5)&(0xFF))<<24)
+#define SWITCH_MAC_WT1__MWA_B4(b4) (((b4)&(0xFF))<<16)
+#define SWITCH_MAC_WT1__MWA_B3(b3) (((b3)&(0xFF))<<8)
+#define SWITCH_MAC_WT1__MWA_B2(b2) (((b2)&(0xFF))<<0)
+ * PHY Control 2 register fields
+#define SWITCH_PHY_CNTL2__RMAE  (0x00000001<<30)
+#define SWITCH_PHY_CNTL2__AMDIX  (SWITCH__PORTS_PHYS<<25)
+#define SWITCH_PHY_CNTL2__AMDIX_SET(set) (((set)&(SWITCH__PORTS_PHYS))<<25)
+#define SWITCH_PHY_CNTL2__PHYR  (SWITCH__PORTS_PHYS<<20)
+#define SWITCH_PHY_CNTL2__PHYR_SET(set) (((set)&(SWITCH__PORTS_PHYS))<<20)
+#define SWITCH_PHY_CNTL2__RFCV  (SWITCH__PORTS_PHYS<<15)
+#define SWITCH_PHY_CNTL2__RFCV_SET(set) (((set)&(SWITCH__PORTS_PHYS))<<15)
+#define SWITCH_PHY_CNTL2__DC  (SWITCH__PORTS_PHYS<<10)
+#define SWITCH_PHY_CNTL2__DC_SET(set) (((set)&(SWITCH__PORTS_PHYS))<<10)
+#define SWITCH_PHY_CNTL2__SC  (SWITCH__PORTS_PHYS<<5)
+#define SWITCH_PHY_CNTL2__SC_SET(set) (((set)&(SWITCH__PORTS_PHYS))<<5)
+#define SWITCH_PHY_CNTL2__ANE  (SWITCH__PORTS_PHYS<<0)
+#define SWITCH_PHY_CNTL2__ANE_SET(set) (((set)&(SWITCH__PORTS_PHYS))<<0)
+ * PHY Control 3 register fields
+#define SWITCH_PHY_CNTL3__FXE  (SWITCH__PORTS_PHYS<<17)
+#define SWITCH_PHY_CNTL3__FXE_SET(set) (((set)&(SWITCH__PORTS_PHYS))<<17)
+#define SWITCH_PHY_CNTL3__DFEFI  (0x00000001<<16)
+#define SWITCH_PHY_CNTL3__CBDE  (0x00000001<<15)
+#define SWITCH_PHY_CNTL3__RPIC  (0x00000001<<14)
+#define SWITCH_PHY_CNTL3__RPLFT  (0x00000003<<12)
+#define SWITCH_PHY_CNTL3__RPLFT_2 (0x00000000<<12)
+#define SWITCH_PHY_CNTL3__RPLFT_3 (0x00000001<<12)
+#define SWITCH_PHY_CNTL3__RPLFT_4 (0x00000002<<12)
+#define SWITCH_PHY_CNTL3__RPLFT_8 (0x00000003<<12)
+#define SWITCH_PHY_CNTL3__RFGL  (0x00000001<<11)
+#define SWITCH_PHY_CNTL3__RNT  (0x00000001<<10)
+#define SWITCH_PHY_CNTL3__RTJD  (0x00000001<<9)
+#define SWITCH_PHY_CNTL3__RRJE  (0x00000001<<8)
+#define SWITCH_PHY_CNTL3__RADP  (0x00000001<<7)
+#define SWITCH_PHY_CNTL3__IINSEL (0x00000001<<6)
+#define SWITCH_PHY_CNTL3__RSHC  (0x00000003<<4)
+#define SWITCH_PHY_CNTL3__RSHC_VAL(val) (((val)&(0x00000003))<<4)
+#define SWITCH_PHY_CNTL3__PFRV  (0x00000003<<2)
+#define SWITCH_PHY_CNTL3__PFRV_VAL(val) (((val)&(0x00000003))<<2)
+#define SWITCH_PHY_CNTL3__RBLL  (0x00000003<<0)
+#define SWITCH_PHY_CNTL3__RBLL_VAL(val) (((val)&(0x00000003))<<0)
+ * Interrupt mask register fields
+#define SWITCH_INT_MASK__CPUH  (0x00000001<<24)
+#define SWITCH_INT_MASK__SDE  (0x00000001<<23)
+#define SWITCH_INT_MASK__RDE  (0x00000001<<22)
+#define SWITCH_INT_MASK__W1TE  (0x00000001<<21)
+#define SWITCH_INT_MASK__W0TE  (0x00000001<<20)
+#define SWITCH_INT_MASK__MI  (0x00000001<<19)
+#define SWITCH_INT_MASK__PSC  (0x00000001<<18)
+#define SWITCH_INT_MASK__BCS  (0x00000001<<16)
+#define SWITCH_INT_MASK__MD  (0x00000001<<15)
+#define SWITCH_INT_MASK__GQF  (0x00000001<<14)
+#define SWITCH_INT_MASK__CPUQ  (0x00000001<<13)
+#define SWITCH_INT_MASK__P5QF  (0x00000001<<11)
+#define SWITCH_INT_MASK__P4QF  (0x00000001<<10)
+#define SWITCH_INT_MASK__P3QF  (0x00000001<<9)
+#define SWITCH_INT_MASK__P2QF  (0x00000001<<8)
+#define SWITCH_INT_MASK__P1QF  (0x00000001<<7)
+#define SWITCH_INT_MASK__P0QF  (0x00000001<<6)
+#define SWITCH_INT_MASK__LDF  (0x00000001<<5)
+#define SWITCH_INT_MASK__HDF  (0x00000001<<4)
+#define SWITCH_INT_MASK__RLD  (0x00000001<<3)
+#define SWITCH_INT_MASK__RHD  (0x00000001<<2)
+#define SWITCH_INT_MASK__SLD  (0x00000001<<1)
+#define SWITCH_INT_MASK__SHD  (0x00000001<<0)
+#define SWITCH_INT_MASK__ALL_INTS (SWITCH_INT_MASK__CPUH |\
+      SWITCH_INT_MASK__SDE |\
+      SWITCH_INT_MASK__RDE |\
+      SWITCH_INT_MASK__W1TE |\
+      SWITCH_INT_MASK__W0TE |\
+      SWITCH_INT_MASK__MI |\
+      SWITCH_INT_MASK__PSC |\
+      SWITCH_INT_MASK__BCS |\
+      SWITCH_INT_MASK__MD |\
+      SWITCH_INT_MASK__GQF |\
+      SWITCH_INT_MASK__CPUQ |\
+      SWITCH_INT_MASK__P5QF |\
+      SWITCH_INT_MASK__P4QF |\
+      SWITCH_INT_MASK__P3QF |\
+      SWITCH_INT_MASK__P2QF |\
+      SWITCH_INT_MASK__P1QF |\
+      SWITCH_INT_MASK__P0QF  |\
+      SWITCH_INT_MASK__LDF |\
+      SWITCH_INT_MASK__HDF |\
+      SWITCH_INT_MASK__RLD |\
+      SWITCH_INT_MASK__RHD |\
+      SWITCH_INT_MASK__SLD |\
+      SWITCH_INT_MASK__SHD)
+#define SWITCH_TIMER_INT__TOS  (0x00000001<<0)
+#define SWITCH_MEM_CONT__SR0S  (0x00000007<<16)
+#define SWITCH_MEM_CONT__SR0S_DISABLED (0x00000000<<16)
+#define SWITCH_MEM_CONT__SR0S_512KB (0x00000001<<16)
+#define SWITCH_MEM_CONT__SR0S_1MB (0x00000002<<16)
+#define SWITCH_MEM_CONT__SR0S_2MB (0x00000003<<16)
+#define SWITCH_MEM_CONT__SR0S_4MB (0x00000004<<16)
+#define SWITCH_MEM_CONT__SR0S_8MB (0x00000005<<16)
+#define SWITCH_MEM_CONT__SR0S_RES1 (0x00000006<<16)
+#define SWITCH_MEM_CONT__SR0S_RES2 (0x00000007<<16)
+#define SWITCH_MEM_CONT__SDR1E  (0x00000001<<5)
+#define SWITCH_MEM_CONT__SDRS  (0x00000007<<0)
+#define SWITCH_MEM_CONT__SDRS_RES1 (0x00000000<<0)
+#define SWITCH_MEM_CONT__SDRS_1Mx32 (0x00000001<<0)
+#define SWITCH_MEM_CONT__SDRS_2Mx32 (0x00000002<<0)
+#define SWITCH_MEM_CONT__SDRS_4Mx32 (0x00000003<<0)
+#define SWITCH_MEM_CONT__SDRS_16Mx32 (0x00000004<<0)
+#define SWITCH_MEM_CONT__SDRS_32Mx32 (0x00000005<<0)
+#define SWITCH_MEM_CONT__SDRS_RES2 (0x00000006<<0)
+#define SWITCH_MEM_CONT__SDRS_RES3 (0x00000007<<0)
+#endif /* ADM51xx_SWITCH_H */
diff --git a/include/asm-mips/adm5120.h b/include/asm-mips/adm5120.h
new file mode 100644
index 0000000..9333c9f
--- /dev/null
+++ b/include/asm-mips/adm5120.h
@@ -0,0 +1,24 @@
+#include <asm/addrspace.h>
+#define ADM5120_UART1_BASE 0x12800000
+#define ADM5120_UART0_BASE 0x12600000
+#define ADM5120_SYSC_BASE 0x12400000
+#define ADM5120_INTC_BASE 0x12200000
+#define ADM5120_SCR_BASE 0x12000000
+#define ADM5120_MIPS_BASE 0x11a00000
+#define ADM5120_PCIIO_BASE 0x11500000
+#define ADM5120_PCIIO_END (0x115ffff0-1)
+#define ADM5120_PCI_CONFIG_ADDR 0x115ffff0
+#define ADM5120_PCI_CONFIG_DATA 0x115ffff8
+#define ADM5120_PCIMEM_BASE 0x11400000
+#define ADM5120_PCIMEM_END 0x114fffff
+#define ADM5120_USB_BASE 0x11200000
+#define ADM5120_MPMC_BASE 0x11000000
+#define SOFTWARE_RESET      0x1
+#define SW_CPU_PORT_DISABLE     0x00000001
+#define SW_DISABLE_PORT_MASK     0x0000003F
+#endif
diff --git a/include/asm-mips/io.h b/include/asm-mips/io.h
index 857fb03..314ada6 100644
--- a/include/asm-mips/io.h
+++ b/include/asm-mips/io.h
@@ -150,6 +150,11 @@ extern void iounmap(void *addr);
#endif
+ * Some drivers need a memory barrier
+#define barrier() asm volatile ("sync")
  * XXX We need system specific versions of these to handle EISA address bits
  * 24-31 on SNI.
  * XXX more SNI hacks.
@@ -439,12 +444,26 @@ #define IO_SPACE_LIMIT 0xffff
  *    be discarded.  This operation is necessary before dma operations
  *    to the memory.
-extern void (*_dma_cache_wback_inv)(unsigned long start, unsigned long size);
-extern void (*_dma_cache_wback)(unsigned long start, unsigned long size);
-extern void (*_dma_cache_inv)(unsigned long start, unsigned long size);
+extern void *_dma_cache_wback_inv(unsigned long start, unsigned long size);
+extern void *_dma_cache_wback(unsigned long start, unsigned long size);
+extern void *_dma_cache_inv(unsigned long start, unsigned long size);
#define dma_cache_wback_inv(start,size) _dma_cache_wback_inv(start,size)
#define dma_cache_wback(start,size) _dma_cache_wback(start,size)
#define dma_cache_inv(start,size) _dma_cache_inv(start,size)
+ * XXX: MIPS doesn't provide in_le32 etc functions. The externs
+ *      supplied here are just satisfying pci_indirect.c.
+ * Some rework of pci_indirect.c may be required for indirect
+ * PCI bridge support on both big and little endian MIPS targets.
+extern unsigned char in_8     (volatile  u8 *addr);
+extern unsigned short in_le16  (volatile u16 *addr);
+extern unsigned  in_le32  (volatile u32 *addr);
+extern void  out_8    (volatile  u8 *addr, char val);
+extern void  out_le16 (volatile u16 *addr, unsigned short val);
+extern void  out_le32 (volatile u32 *addr, unsigned int val);
#endif /* _ASM_IO_H */
diff --git a/include/configs/adm5120.h b/include/configs/adm5120.h
index 0000000..3398327
--- /dev/null
+++ b/include/configs/adm5120.h
@@ -0,0 +1,141 @@
+ * (C) Copyright 2006
+ * Robert Delien, <robert@delien.nl>
+ * This program is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU General Public License as
+ * published by the Free Software Foundation; either version 2 of
+ * the License, or (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
+ * MA 02111-1307 USA
+ * Config header file for Infineon/ADMtek ADM5120 SoC
+ * This Soc is used in several broadband routers. A long list of
+ * routers using this SoC be found here:
+ * http://www.linux-mips.org/wiki/Adm5120#Products_based_on_the_ADM5120
+#ifndef __CONFIG_H
+#define __CONFIG_H
+#include <adm5120_glb.h>
+#define CONFIG_MIPS32    /* MIPS 4Kc CPU core   */
+#define CONFIG_ADM5120    /* on the ADM5120 SoC   */
+#define CPU_CLOCK_RATE  175000000 /* 175 MHz clock for the MIPS core */
+#define CONFIG_BOOTDELAY 5  /* autoboot after 5 seconds  */
+#define CONFIG_TIMESTAMP   /* Print image info with timestamp */
+#define CONFIG_BOOTFILE  vmlinux.bin
+#define CONFIG_LOADADDR  0x80002000
+#define CONFIG_BOOTCOMMAND "tftp; go 800026D8"
+#define CONFIG_COMMANDS  (CONFIG_CMD_DFL  |\
+     CFG_CMD_DHCP  |\
+     CFG_CMD_PING)
+#include <cmd_confdefs.h>
+ * Miscellaneous configurable options
+#define CFG_LONGHELP    /* undef to save memory      */
+#define CFG_PROMPT  "ADM5120 # " /* Monitor Command Prompt    */
+#define CFG_CBSIZE  256  /* Console I/O Buffer Size   */
+#define CFG_PBSIZE  (CFG_CBSIZE+sizeof(CFG_PROMPT)+16)  /* Print Buffer Size */
+#define CFG_MAXARGS  16  /* max number of command args*/
+#define CFG_MALLOC_LEN  128*1024
+#define CFG_BOOTPARAMS_LEN 128*1024
+#define CFG_CP0_COUNT_RATE ((CPU_CLOCK_RATE)/2)
+#define CFG_HZ   1000
+#define CFG_SDRAM_BASE  0x80000000
+#define CFG_SDRAM_MAX  0x08000000 /* Maximum 128MiB of SDRAM */
+#define CFG_INIT_SP_OFFSET 0x00040000 /* Initial stack at 512kiB */
+#define CFG_LOAD_ADDR  ((CFG_SDRAM_BASE)+(0x00010000)) /* default load address */
+#define CFG_MEMTEST_START (CFG_SDRAM_BASE)
+#define CFG_MEMTEST_END  ((CFG_SDRAM_BASE)+(CFG_INIT_SP_OFFSET))
+#define CFG_SCR_BASE  ADM5120_SCR_BASE
+ * FLASH and environment organization
+#define CFG_FLASH_CFI    /* flash is CFI compatible */
+#define CFG_FLASH_CFI_DRIVER   /* Use common CFI driver */
+#define CFG_FLASH_EMPTY_INFO   /* print 'E' for empty sector */
+#define CFG_MAX_FLASH_SECT 128  /* max number of sectors on one chip */
+#define CFG_MAX_FLASH_BANKS 1  /* max number of memory banks */
+#define CFG_FLASH_BASE  0xBFC00000
+/* The following #defines are needed to get flash environment right */
+#define CFG_MONITOR_BASE TEXT_BASE
+#define CFG_MONITOR_LEN  (192 << 10)
+/* timeout values are in ticks */
+#define CFG_FLASH_ERASE_TOUT 20000 /* Timeout for Flash Erase in ms */
+#define CFG_FLASH_WRITE_TOUT 2000 /* Timeout for Flash Write in ms */
+#define CONFIG_ADM51xx_SWITCH
+#define CONFIG_ADM51xx_SWITCH_BASE KSEG1ADDR(0x12000000)
+#define CONFIG_NET_MULTI
+#define CONFIG_ETHADDR   00:A0:C9:A2:EE:B2 /* Ethernet address */
+#define CONFIG_SERVERIP   192.168.1.10  /* IP address of tftp server */
+#define CONFIG_IPADDR   192.168.1.25  /* Our IP address */
+#define CONFIG_NETMASK   255.255.255.0  /* Our net mask */
+/* Address and size of Primary Environment Sector */
+#define CFG_ENV_IS_IN_FLASH
+#define CFG_ENV_ADDR  0xBFDF0000
+#define CFG_ENV_SIZE  0x00010000
+#define CFG_DIRECT_FLASH_TFTP
+#define CONFIG_NR_DRAM_BANKS 2
+ * Cache Configuration
+#define CFG_DCACHE_SIZE  8192  /*  8 kiB data cache  */
+#define CFG_ICACHE_SIZE  8192  /*  8 kiB instruction cache */
+#define CFG_CACHELINE_SIZE 16  /* 16 Byte cache line size */
+ * Serial Configuration
+#define CFG_PL010_SERIAL
+#define CFG_UART_PL010_CLOCK 62500000 /* 62.5MHz in AMD5120P */
+#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
+#define CFG_SERIAL0  0xB2600000
+#define CFG_SERIAL1  0xB2800000
+#define CONFIG_CONS_INDEX 0
+#define CONFIG_BAUDRATE  115200
+#define CONFIG_PL01x_PORTS { (void *) (CFG_SERIAL0), (void *) (CFG_SERIAL1) }
+ * Console configuration
+#define CFG_HUSH_PARSER    /* Enable HUSH shell parser */
+#define CFG_PROMPT_HUSH_PS2 "> "  /* Configure HUSH sec. prompt */
+#define CONFIG_CMDLINE_EDITING   /* Enable command line editing */
+#endif /* __CONFIG_H */
diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h
index 4cc5085..3206125 100644
--- a/include/configs/dbau1x00.h
+++ b/include/configs/dbau1x00.h
@@ -112,7 +112,8 @@ #if (CFG_MHZ % 12) != 0
#error "Invalid CPU frequency - must be multiple of 12!"
#endif
-#define CFG_HZ                  (CFG_MHZ * 1000000) /* FIXME causes overflow in net.c */
+#define CFG_CP0_COUNT_RATE (CFG_MHZ * 1000000)
#define CFG_SDRAM_BASE  0x80000000     /* Cached addr */
diff --git a/include/configs/gth2.h b/include/configs/gth2.h
index a49ed3b..0a56b6f 100644
--- a/include/configs/gth2.h
+++ b/include/configs/gth2.h
@@ -93,7 +93,8 @@ #define CFG_BOOTPARAMS_LEN 128*1024
#define CFG_MHZ   500
diff --git a/include/configs/incaip.h b/include/configs/incaip.h
index 1c6216b..c62c57a 100644
--- a/include/configs/incaip.h
+++ b/include/configs/incaip.h
@@ -33,7 +33,7 @@ #define CONFIG_INCA_IP  1 /* on a INCA-I
#ifndef CPU_CLOCK_RATE
/* allowed values: 100000000, 133000000, and 150000000 */
-#define CPU_CLOCK_RATE 150000000 /* default: 150 MHz clock for the MIPS core */
+#define CPU_CLOCK_RATE  150000000 /* default: 150 MHz clock for the MIPS core */
#endif
#define INFINEON_EBU_BOOTCFG 0x40C4 /* CMULT = 8 */
@@ -104,7 +104,8 @@ #define CFG_MALLOC_LEN  128*1024
-#define CFG_HZ   (incaip_get_cpuclk() / 2)
+#define CFG_CP0_COUNT_RATE (incaip_get_cpuclk() / 2)
diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h
index 2f6e399..b7561ed 100644
--- a/include/configs/integratorap.h
+++ b/include/configs/integratorap.h
@@ -65,6 +65,7 @@ #define CONFIG_PL01x_PORTS { (void *) (C
#define CFG_SERIAL0  0x16000000
#define CFG_SERIAL1  0x17000000
+#define CFG_UART_PL010_CLOCK 14745600 /* 14.7456MHz */
/*#define CONFIG_COMMANDS (CFG_CMD_DHCP | CFG_CMD_IMI | CFG_CMD_NET | CFG_CMD_PING | CFG_CMD_BDI | CFG_CMD_PCI) */
/*#define CONFIG_NET_MULTI */
diff --git a/include/configs/mcc200.h b/include/configs/mcc200.h
index 0c935bf..f60973b 100644
--- a/include/configs/mcc200.h
+++ b/include/configs/mcc200.h
@@ -94,6 +94,8 @@ #define CONFIG_DOS_PARTITION
#define CONFIG_USB_OHCI
#define ADD_USB_CMD  CFG_CMD_USB | CFG_CMD_FAT
#define CONFIG_USB_STORAGE
+/* automatic software updates (see board/mcc200/auto_update.c) */
+#define CONFIG_AUTO_UPDATE 1
  * Supported commands
@@ -173,7 +175,7 @@ #define CFG_IPBSPEED_133  /* define for
  * I2C configuration
#define CONFIG_HARD_I2C  1 /* I2C with hardware support */
-#define CFG_I2C_MODULE  1 /* Select I2C module #1 or #2 */
+#define CFG_I2C_MODULE  2 /* Select I2C module #1 or #2 */
#define CFG_I2C_SPEED  100000 /* 100 kHz */
#define CFG_I2C_SLAVE  0x7F
diff --git a/include/configs/purple.h b/include/configs/purple.h
index 2ecb7fb..28d11e5 100644
--- a/include/configs/purple.h
+++ b/include/configs/purple.h
@@ -31,8 +31,8 @@ #define __CONFIG_H
#define CONFIG_MIPS32  1 /* MIPS 5Kc CPU core */
#define CONFIG_PURPLE  1 /* on a PURPLE Board */
-#define CPU_CLOCK_RATE 125000000   /* 125 MHz clock for the MIPS core */
-#define ASC_CLOCK_RATE  62500000   /* 62.5 MHz ASC clock              */
+#define CPU_CLOCK_RATE  125000000   /* 125 MHz clock for the MIPS core */
+#define ASC_CLOCK_RATE  62500000   /* 62.5 MHz ASC clock              */
#define INFINEON_EBU_BOOTCFG 0xE0CC
@@ -99,7 +99,8 @@ #define CFG_LONGHELP    /* undef to save
#define CFG_PROMPT  "URPLE # " /* Monitor Command Prompt    */
-#define CFG_HZ   (CPU_CLOCK_RATE/2)
+#define CFG_CP0_COUNT_RATE (CPU_CLOCK_RATE/2)
#define CFG_LOAD_ADDR  0x80500000 /* default load address */
diff --git a/lib_mips/time.c b/lib_mips/time.c
index cd8dc72..9c9529c 100644
--- a/lib_mips/time.c
+++ b/lib_mips/time.c
@@ -22,62 +22,56 @@
#include <common.h>
+#include <asm/mipsregs.h>
-static inline void mips_compare_set(u32 v)
- asm volatile ("mtc0 %0, $11" : : "r" (v));
-static inline void mips_count_set(u32 v)
- asm volatile ("mtc0 %0, $9" : : "r" (v));
-static inline u32 mips_count_get(void)
- u32 count;
- asm volatile ("mfc0 %0, $9" : "=r" (count) ;
- return count;
+#define TICKS_PER_USEC  1000000
  * timer without interrupts
int timer_init(void)
- mips_compare_set(0);
- mips_count_set(0);
+#ifdef CONFIG_MIPS_CPU_PR4450
+ int configPR;
- return 0;
+ /* enable and start counter */
+ configPR = read_c0_configPR();
+ configPR &= ~0x8;
+ write_c0_configPR(configPR);
-void reset_timer(void)
+#endif /* CONFIG_MIPS_CPU_PR4450 */
-ulong get_timer(ulong base)
- return mips_count_get() - base;
+ write_32bit_cp0_register(CP0_COUNT, 0);
+ write_32bit_cp0_register(CP0_COMPARE, ~0);
+ return 0;
-void set_timer(ulong t)
+ulong get_timer(ulong base)
- mips_count_set(t);
+ return (read_32bit_cp0_register(CP0_COUNT)/(CFG_CP0_COUNT_RATE/CFG_HZ)) - base;
void udelay (unsigned long usec)
- ulong tmo;
- ulong start = get_timer(0);
+ ulong startTicks = read_32bit_cp0_register(CP0_COUNT);
+ ulong delayTicks = usec*(CFG_CP0_COUNT_RATE/TICKS_PER_USEC);
+ ulong endTicks;
+ /* Safeguard for too-long delays */
+ if (delayTicks >= 0x80000000)
+  delayTicks = 0x7FFFFFFF;
+ /* Calculate end of delay (once) */
+ endTicks = startTicks + delayTicks;
+ /* If end of delay is behind COUNT rol-over, wait for COUNT to rol-over first */
+ while ((read_32bit_cp0_register(CP0_COUNT) & 0x80000000) > (endTicks & 0x80000000))
+  ; /* nop */
- tmo = usec * (CFG_HZ / 1000000);
- while ((ulong)((mips_count_get() - start)) < tmo)
-  /*NOP*/;
+ /* Wait for end of delay */
+ while (read_32bit_cp0_register(CP0_COUNT) < endTicks)
+  ; /* nop */
@@ -86,7 +80,7 @@ void udelay (unsigned long usec)
unsigned long long get_ticks(void)
- return mips_count_get();
+ return read_32bit_cp0_register(CP0_COUNT);
@@ -95,5 +89,5 @@ unsigned long long get_ticks(void)
ulong get_tbclk(void)
- return CFG_HZ;
+ return CFG_CP0_COUNT_RATE;
diff --git a/net/eth.c b/net/eth.c
index cca9392..10a6f67 100644
--- a/net/eth.c
+++ b/net/eth.c
@@ -222,6 +222,9 @@ #endif
#if defined(CONFIG_AU1X00)
  au1x00_enet_initialize(bis);
#endif
+#if defined(CONFIG_ADM5120)
+ adm5120_eth_initialize(bis);
+#endif
#if defined(CONFIG_IXP4XX_NPE)
  npe_initialize(bis);
#endif
发表于 2009-10-19 15:49:57 | 显示全部楼层
弄个附件多好
发表于 2009-11-22 21:43:06 | 显示全部楼层
挺不错的文档啊....
发表于 2009-12-4 19:06:57 | 显示全部楼层
头像被屏蔽
发表于 2009-12-16 18:58:49 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2024-4-26 09:05 , Processed in 0.043542 second(s), 10 queries , Gzip On, Redis On.
