Author:
Aaron Buchwald, Ph.D. Founder, CEO, Mobius Semiconductor, CA, USA
Aaron Buchwald was born in Ames , IA , in 1960. He received the BSEE degree from the University of Iowa in 1982, and the MS and Ph.D. degrees in electrical engineering from the University of California , Los Angeles , in 1984 and 1993. He has worked for Hughes Aircraft in El Segundo , CA , and Siemens in Munich , Germany . He was also an Assistant Professor at The Hong Kong University of Science and Technology (HKUST). He joined Broadcom Corporation in 1994 as the first member of the Analog group. In 2003 he founded Mobius Semiconductor, an early-phase start-up in Irvine CA , focusing on mixed-signal and analog technology advancements for next-generation communication physical-layer transceivers
Contents:
High-speed data converters are essential in nearly every communication device. Often the system performance is limited by the accuracy, speed and power of the data converters. This course will cover essential details to enable the student to design high-resolution high-speed Nyquist-rate analog-to-digital converters. We'll survey the current state-of-the art in ADC design and review fundamental concepts and constraints. The course will progress to advanced topics and give several design examples along the way including Flash, SAR, Pipelined and Folding ADCs. An important section on ADC testing is also included which covers the basics of testing techniques and presents some real-world debugging challenges. The course will present basic material in a tutorial context so no prior ADC experience is assumed. The course is also valuable to experienced ADC designers as many subtle issues with regard to 2nd-order effects limiting higher precision designs will be presenting in the context of the design examples.
Total 10 chapters in 16 RAR files~~
