查看: 27014|回复: 131
[ICTOP50 之第9]Power,accuracy and noise aspects.......(现已全部上传完整)
发表于 2008-8-2 10:52:02 | 显示全部楼层 |阅读模式
给大家共享一本在ICTOP50里面排第九位的书,相信大家都会喜欢,我看了一下,应该是论坛里还没有的书,如果论坛已有,请提醒我一下
Power, accuracy and noise aspects in CMOS mixed-signal design
Author: Sanduleanu, Mihai Adrian Tiberiu
ISBN: 90-3651265-4
Ó1999, Mihai A.T. Sanduleanu
Table of Contents
Selected Symbols and Abbreviations
Chapter 1 Introduction
1.1. Motivation
1.2. Problem definition
1.3. Scope and outline
References
Chapter 2 Power considerations in sub-micron digital CMOS
2.1. Introduction
2.2. Fundamental limits
2.3. From fundamental limits to practical limits of power. An architecture level approach
2.4. S/N ratio and power in fixed point applications
2.5. Adders and computational power
2.6. Ways to low-power in digital
2.7. Example of a digital video filter
2.8. Conclusions
References
Chapter 3 Power considerations in sub-micron analog CMOS
3.1. Introduction
3.2. Process tuning towards digital needs. Consequences on analog
3.3. Fundamental limits
3.4. From fundamental limits to practical limits of power. Noise related power
3.5. From fundamental limits to practical limits of power. Mismatch related power
3.6. Power estimations in continuous time filters
3.7. Conclusions
References
Chapter 4 Gm-C integrators for low-power and low voltage applications. A gaussian polyphase filter for mobile transceivers in 0.35μm CMOS
4.1. Introduction
4.2. Large swing and high linearity transconductor
4.3. Low voltage current Gm-C integrator with high power efficiency
4.4. Low-power luminance video filter. Noise driven power
4.5. Low-power, gaussian, polyphase filter for mobile transceivers. Matching driven power
4.6. Conclusions
References
Chapter 5 Chopping: a technique for noise and offset reduction
5.1. Introduction
5.2. Ways to reduce offset and 1/f noise
5.3. Chopping seen as a modulation technique
5.4. Noise modulation
5.5. Chopped amplifiers and offset reduction
5.6. Low-power low-voltage chopped transconductance amplifier for noise and offset reduction
5.7. A low-power bandgap voltage reference
5.8. Conclusions
References
Chapter 6 Low-noise, low residual offset, chopped amplifiers for high-end application
6.1. Introduction
6.2. Low-pass filtering in a digital audio system. Application specific constraints
6.3. The gain stage
6.4. A low noise, low residual offset, chopped amplifier in 0.8mm CMOS
6.5. A low noise, low residual offset, chopped amplifier in 0.5mm CMOS
6.6. Conclusions
References
Chapter 7 A 16-bit D/A interface with Sinc approximated semidigital reconstruction lter
7.1. Introduction
7.2. Bitstream D/A conversion system with time-discrete filtering
7.3. S-D modulators and noise shaping
7.4. Semidigital FIR filter principles
7.5. Semidigital FIR filter design
7.6. Noise properties of the D/A interface
7.7. Realisation
7.8. Experimental results
7.9. Interpolative D/A converter with Sinc approximation in the time domain
7.10. Conclusions
References
Chapter 8 Conclusions
8.1. Summary
8.2. Conclusions
8.3. Original contributions
8.4. Recommendations for further research
Appendix 1
Appendix 2
Appendix 3
先发一至四章,稍后发5-8章
8月5日,已上传完整 (第5-8章已补上)
[ 本帖最后由 xinhunlei 于 2008-8-5 13:27 编辑 ]
Power, accuracy and noise aspects in CMOS mixed-signal design.pdf
1.75 MB, 下载次数: 928 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CHAPTER 5-8.pdf
2.7 MB, 下载次数: 667 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-8-2 11:00:39 | 显示全部楼层
大家看看落,这是全球IC设计书籍前50位中的排第九位的那本书,是高清晰,非扫描版的,免费共享,超值的!!!
 楼主| 发表于 2008-8-2 11:17:08 | 显示全部楼层
居然没人?
发表于 2008-8-2 12:54:21 | 显示全部楼层
thank you
发表于 2008-8-2 17:17:26 | 显示全部楼层
thanks to you.
发表于 2008-8-2 17:46:23 | 显示全部楼层
多谢楼主共享
发表于 2008-8-2 17:52:35 | 显示全部楼层
很不错的一本书,谢了
现在是好书太多,时间太少,要精选一下,不然只放在电脑上岂不是浪费
发表于 2008-8-2 19:01:58 | 显示全部楼层
谢谢分享
发表于 2008-8-2 20:31:27 | 显示全部楼层
Thanks very much
发表于 2008-8-2 20:48:01 | 显示全部楼层
WA~~~~OH
厉害
GMT+8, 2025-12-27 22:14 , Processed in 0.022820 second(s), 7 queries , Gzip On, Redis On.
