查看: 23471|回复: 35
red hat enterprise 5下安装ic610的问题
发表于 2008-4-3 22:02:49 | 显示全部楼层 |阅读模式
不知道有没有大侠在red hat enterprise 5下安装ic610的?
我在安装时遇到下面的问题:
Initializing InstallScape using JVM at /eda_soft/Cadence/InstallScape/iscape/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /eda_soft/Cadence/InstallScape/iscape/runtime/LNX86/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1503)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at sun.security.action.LoadLibraryAction.run(LoadLibraryAction.java:50)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Toolkit.loadLibraries(Toolkit.java:1437)
at java.awt.Toolkit.<clinit>(Toolkit.java:1458)
at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:70)
然后就退出了,不知道如何解决?
发表于 2008-4-3 23:51:53 | 显示全部楼层
在RHEL3 AS上可以成功安装
发表于 2008-4-4 18:22:03 | 显示全部楼层
安装过IC530, IC610 没有装过, 以前IC530 是在RH7.2 上装的.
 楼主| 发表于 2008-4-4 22:09:04 | 显示全部楼层
上面的问题已经解决,但是在启动icfb时出现如下错误:
\e Display :0.0 Error "BadWindow (invalid Window parameter)"
\e
request 12 error 3 serial 1738
\e
request 10 error 3 serial 1739
\e
request 10 error 3 serial 1740
\e
request 15 error 3 serial 1741
\o
&copy; 1992-2006
UNIX SYSTEMS Laboratories INC.,
\e Display :0.0 Error "BadDrawable (invalid Pixmap or Window parameter)"
\e
request 62 error 9 serial 1764
\e Display :0.0 Error "BadMatch (invalid parameter attributes)"
\e
request 1 error 8 serial 1766
\e
request 155 error 9 serial 1767
\e
request 18 error 3 serial 1768
\e
request 18 error 3 serial 1769
\e
request 18 error 3 serial 1770
\e
request 18 error 3 serial 1771
\e
request 18 error 3 serial 1772
\e
request 12 error 3 serial 1773
\e
request 18 error 3 serial 1774
\e
request 18 error 3 serial 1775
\e
request 18 error 3 serial 1776
不知道是什么情况?请大家指教!多谢!
发表于 2008-4-23 11:13:17 | 显示全部楼层
楼主解决了吗
发表于 2008-4-23 11:16:53 | 显示全部楼层
我遇到了同样的问题,头疼阿!!
发表于 2008-4-28 23:10:26 | 显示全部楼层
没遇到过!
发表于 2008-4-30 08:32:11 | 显示全部楼层
redhat 5太新了,好多eda tools在上面安装都有问题。
发表于 2008-4-30 18:10:00 | 显示全部楼层
楼主辛苦了!很好!很强大!
IDC评测网永远支持您!
发表于 2008-4-30 19:34:33 | 显示全部楼层
我遇到过相同的问题,好像是在xorg.conf里面加上下面一段就可以了,lz试试看
Section "Extensions"
Option "Composite" "Disable"
EndSection
GMT+8, 2025-12-26 08:03 , Processed in 0.052923 second(s), 7 queries , Gzip On, Redis On.
