查看: 2930|回复: 2
[求助] how to use report_net_fanout after current_design
发表于 2018-10-8 04:36:46 | 显示全部楼层 |阅读模式
tried to use
report_net_fanout {n105} in ICC
First loaded design, sram256x64ddr4_routed
from open design in my library orca_lib.mw
then use the following
current_design sram256x64ddr4_routed
to set current_design:
icc_shell> current_designsram256x64ddr4_routed
It looks that the current_design was defined
but when I use report_net_fanout:
icc_shell> report_net_fanout {n105}
it still gave me:
# GUI Debug: Building dc from empty. -- Time: 3msError: Current design is not defined. (UID-4)Error: Can't find net 'n105'. (UID-109)Error: Value for list 'list_of_nets' must have 1 elements. (CMD-036)
why, please help
发表于 2018-10-12 09:21:43 | 显示全部楼层
看样子好像是没有打开cel的原因吧,用的是ICC吗?打开lib,接下来应该打开cel.
 楼主| 发表于 2018-10-18 23:02:49 | 显示全部楼层
回复 2# shenteng
   Thanks for the response,
That is what I did, open lib, open CEL
GMT+8, 2025-12-3 19:24 , Processed in 0.025607 second(s), 3 queries , Gzip On, Redis On.
