查看: 2688|回复: 2
[求助] 文件操作语句$fopen仿真打不开文件
发表于 2018-10-11 09:43:12 | 显示全部楼层 |阅读模式
`timescale 1ns / 1ps
`define NULL 0
// Company:
// Engineer:
// Create Date:   14:06:57 09/30/2018
// Design Name:   system
// Module Name:   D:/Xilinx/exercise/system/system_display.v
// Project Name:  system
// Target Device:
// Tool versions:
// Description:
// Verilog Test Fixture created by ISE for module: system
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module system_display;
integer fp_r;
integer fp_w;
integer flag;
reg[3:0] bin;
reg [15:0] data_in;
reg [15:0] cnt = 10;
initial
   begin:file_fscanf//块名ç§
fp_r = $fopen("data_in.txt","r");
fp_w = $fopen("data_out.txt","w");
if(fp_r == `NULL)//ERROR
disable file_fscanf;
if(fp_w == `NULL)//ERROR
while(cnt>0)begin
flag = $fscanf(fp_r,"%d",data_in);
cnt = cnt -1;
$write("%d",data_in,",");
$fwrite(fp_w,"%d\n",data_in);
#5;
end
$fclose(fp_r);
$fclose(fp_w);
   end
endmodule
仿真结果如下:显示无法打开文件,其中我把data_in.txt与data_out.txt文件放在system_display.v的同目录下
发表于 2018-10-11 10:40:59 | 显示全部楼层
应该放在执行仿真的目录。
 楼主| 发表于 2018-10-11 20:35:00 | 显示全部楼层
回复 2# orlye
   我今天又把文件挪了几个位置都不行,后来发现.V文件目录下自己生成了data_in.txt文件,于是又放回去,就可以了!!! 微信截图_20181011204245.png
GMT+8, 2025-11-24 03:42 , Processed in 0.016980 second(s), 4 queries , Gzip On, Redis On.
