查看: 4312|回复: 6
[求助] spyglass Read Design Read 出错
发表于 2017-7-31 18:30:48 | 显示全部楼层 |阅读模式
SPYGLASS FAILED TO OPEN FILE
Hence, displaying the list of errors
0: ReportAbortReason  Fatal SpyGlass Aborted due to the following error : ERROR [38]    The architecture 'RTL' in library 'WORK' is out-of-date because it has been compiled earlier than the entity 'VECTOR_TOGGLE_SYNC' in library 'WORK'; Please recompile it.(entity(WORK.VECTOR_TOGGLE_SYNC) TimeStamp(Mon Jul 31 17:57:38 2017);architecture(WORK.CPRI2ETH_IN_SYNC.RTL) TimeStamp(Mon Jul 31 17:57:22 2017))
0: STX_VH_202 STX_VH_202 Syntax The architecture 'RTL' in library 'WORK' is out-of-date because it has been compiled earlier than the entity 'VECTOR_TOGGLE_SYNC' in library 'WORK'; Please recompile it.(entity(WORK.VECTOR_TOGGLE_SYNC) TimeStamp(Mon Jul 31 17:57:38 2017);architecture(WORK.CPRI2ETH_IN_SYNC.RTL) TimeStamp(Mon Jul 31 17:57:22 2017))
eth2rp_inst : entity work.RP301_ETH2RP(RTL)
这种例化写法是什么意思?
求指点。
发表于 2017-8-2 15:09:28 | 显示全部楼层
这个是编译问题吧  建议你删除WORK目录 重新跑下spyglass
 楼主| 发表于 2017-8-2 16:25:01 | 显示全部楼层
回复 2# longever
   感谢您的帮助。我是直接加的源文件跑的,没有在spyglass中建work库。你有关于spyglass使用的教程之类的东西吗?
发表于 2017-8-3 10:35:03 | 显示全部楼层
我也就SOLD下的资料 你要的话可以留邮箱 我发给你
 楼主| 发表于 2017-8-3 15:04:47 | 显示全部楼层
回复 4# longever
  万分感谢。478384034@qq.com
 楼主| 发表于 2017-9-8 16:13:21 | 显示全部楼层
求大神解答
发表于 2022-6-15 15:43:43 | 显示全部楼层
请问 解决了 吗 哥们
GMT+8, 2025-11-25 03:38 , Processed in 0.018414 second(s), 3 queries , Gzip On, Redis On.
