查看: 3230|回复: 8
[求助] Creating a Standard Cell Library
发表于 2017-6-7 00:48:59 | 只看该作者 |倒序浏览 |阅读模式
Hello eetop designer,
I can find eetop peoples can help me for create a standard cell library from industrial pdk or cadence gpdk? I want create a my standard cell and after I / O with cadence EDA only if possible for objective educative.
My email: d2jamel@gmail.com
2#
发表于 2017-6-7 09:24:19 | 只看该作者
Would you like to create a library? which process?
 楼主| 发表于 2017-6-8 06:59:11 | 只看该作者
in first step with 1.00 um (or 0.5 um) and after with 0.18 or 0.13
发表于 2017-6-8 14:07:58 | 只看该作者
a standard cell or a library?
 楼主| 发表于 2017-6-9 00:52:47 | 只看该作者
Library of standard cells and I/O for can use digital flow : RTL to GDS ... as industrial standard cells and I/O TSMC, ST, AMS, ...
发表于 2017-6-9 09:04:24 | 只看该作者
回复 3# Desingman
   How could I help you?
My email : songwei19890420@163.com
 楼主| 发表于 2017-6-9 23:29:21 | 只看该作者
Reply 6 # Qinshi moon sw
I want create my standard cell and I/O library. I not know how can generate different file with cadence. if you can help for create a standard cells in first as industrial standard cell library for can synthesis RTL code to GDS II. and after I/O library
If you can send me a tutorial (step by step) for can create this education standard cells library with cadence only.
发表于 2018-6-9 18:32:50 | 只看该作者
Reply 7# Desingman
I know its old thread. But this can be usefull to someone new.
   http://eeweb.poly.edu/labs/nanov ... orial_StdCells.html
Thanks.
发表于 2018-11-4 16:47:32 | 只看该作者
learning ~~ thanks
GMT+8, 2025-11-9 05:41 , Processed in 0.015012 second(s), 2 queries , Gzip On, Redis On.
