查看: 3797|回复: 2
[求助] 菜鸡求助
发表于 2016-10-12 00:02:32 | 显示全部楼层 |阅读模式
刚开始接触fpga 一个简单的计数器一直提示语法错误 希望各位能不吝赐教Error (10170): Verilog HDL syntax error at cnt_num.v(21) near text: a. Check for and fix any syntax errors that appear immediately before or at the specified keyword. The Altera Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/s ... ge-base/search.html and search for this specific error message number.
  1. module cnt_num
  2. (clk,
  3. rst_n,
  4. cnt_num_out,
  5. );
  6. input clk,rst_n;
  7. output cnt_num_out;
  8. reg [27:0]cnt;
  9. reg cnt_num_out_r;
  10. always @ (posedge clk,negedge rst_n)
  11.         begin
  12.         if (!rst_n) begin
  13.                 cnt<=28'd0;
  14.                 cnt_num_out_r<=1'b0;
  15.                 end
  16.                 else if (cnt == 28'b&#8237;0010111110101111000010000000&#8236;) //此行报错
  17.                         begin
  18.                                 cnt<=1'b0;
  19.                                 cnt_num_out_r<=1'b1;
  20.                         end
  21.                                 else cnt<=cnt+1'b1;
  22.         end
  23.
  24.         assign cnt_num_out = cnt_num_out_r;
  25. endmodule
  26.
    复制代码
发表于 2016-10-12 12:07:29 | 显示全部楼层
应该是第23行错了,cnt 在 23行被写成了1bit, 年轻人,仔细点。
 楼主| 发表于 2016-10-13 21:33:15 | 显示全部楼层
回复 2# y23angchen
    嗯嗯 已经解决了 小的多谢了
GMT+8, 2025-11-4 05:43 , Processed in 0.020713 second(s), 7 queries , Gzip On, Redis On.
