查看: 6958|回复: 5
[求助] noise和xtalk之间有哪些不同
发表于 2016-6-15 09:27:45 | 显示全部楼层 |阅读模式
noise和xtalk之间有哪些不同
发表于 2016-6-16 15:43:16 | 显示全部楼层
noise是指静态信号(恒0或恒1)被干扰而引起的毛刺;
xtalk指两个变化相反的信号相互干扰叠加引起的延时;
 楼主| 发表于 2016-6-16 19:55:03 | 显示全部楼层
回复 2# iseepiglet
   谢谢回复
发表于 2016-7-7 22:51:52 | 显示全部楼层
回复 2# iseepiglet
修正一下,Xtalk对于setup来讲,考虑变化相反的影响,对于hold来讲,考虑变化相同的影响。
发表于 2016-7-11 16:05:29 | 显示全部楼层
Xtalk(crosstalk)induced two types effects: delay and static noise.
crosstalk delay effect: crosstalk can affect signal delays by changing the times at which signal transitions occur,because of capacitive corss-coupling. this delay change maybe cause the transition to occur later or earlier, possibly contributing to a setup or hold violaion for a path.
crosstalk noise effect: due to crosstalk, a noise bump happens on cross-coupled nets, which on steady-state(0 or 1). If the bump is sufficiently large and wide, it can cause an incorrect logic value to be propagated to the next gate.
发表于 2021-2-18 14:37:28 | 显示全部楼层
crosstalk delay effect: crosst ...
学习了 mark
GMT+8, 2025-8-20 20:37 , Processed in 0.012465 second(s), 3 queries , Gzip On, Redis On.
