查看: 14908|回复: 5
[解决] hspice 2014 - 2015 error
发表于 2016-5-8 17:59:54 | 显示全部楼层 |阅读模式
Please !! I need your help
I have installed Hspice K-2015.06-3 and J 2014.09-SP2 Linux (Fedora 22 and CentOS 7.1) and when I run
hspice -i -I or Hspice input .sp
I get the following error (both versions):
** error ** Invalid memory reference
platform: Fedora 22 - Centos 7.1 64bit
CPU: i7
the complete error is:
$ hspice -I
Using: /usr/synopsys/J-2014.09-SP2/hspice/amd64/hspice  -I
lic:
lic: FLEXlm: v10.9.8
lic: USER:   xxxx                HOSTNAME: yyyyy
lic: HOSTID: xxxx        PID:      3717
**error** invalid memory reference
1
****** job statistics summary tnom=   0.000 temp=   0.000 ******
/usr/synopsys/J-2014.09-SP2/hspice/bin/hspice: line 409:  3717 Segmentation fault      (core dumped) /usr/synopsys/J-2014.09-SP2/hspice/amd64/hspice -I
发表于 2016-5-9 17:31:11 | 显示全部楼层
you don't have a good license.
 楼主| 发表于 2016-5-9 20:14:47 | 显示全部楼层
回复 2# ysliu168
Thank you.
You confirm my doubts.
Please do you know a good LicManager which produce a good license?
发表于 2017-3-10 18:43:32 | 显示全部楼层
hspice 2014 - 2015 error ??
发表于 2019-1-23 16:17:31 | 显示全部楼层
where can I find the good license?
发表于 2020-5-3 19:24:02 | 显示全部楼层
I have same problem
GMT+8, 2025-11-6 08:03 , Processed in 0.021110 second(s), 5 queries , Gzip On, Redis On.
