发表于 2016-5-8 13:20:31
显示全部楼层
楼主,我尝试着用这个方法来转换,但是提示缺少oa格式的TF文件如下:
ERROR (CDBOA-500): Cannot translate CDB design library
"../designmodel_copy/bak" to OpenAccess because CDB
technology library "asmc035hv" referenced by the CDB design
library is not available in the OpenAccess format. Before
translating the CDB design library, ensure that all the
referenced CDB technology libraries are available in
OpenAccess and defined in 'cds.lib'.
Translation of library "bak" stopped.
Message Summary:
ERROR (CDBOA-500): Cannot translate CDB design library <path>/<name> to
OpenAccess because CDB technology library <name> referenced
by the CDB design library is not available in the
OpenAccess format. Before translating the CDB design
library, ensure that all the referenced CDB technology
libraries are available in OpenAccess and defined in
'cds.lib'.
Generated once. The translator stopped because the CDBA
library references an attached technology library that does
not exist in OpenAccess.
Check the source library files and correct the library
attachments as required. Ensure that the cds.lib file is
present in the current directory and any technology library
that is referenced by the current library is defined in the
cds.lib file and is available in OpenAccess at the time it
is referenced. If the design library is referencing itself
as an attached technology library, ensure that there is an
appropriate tech.db technology file present in the
OpenAccess library directory.
请问该怎么解决? |
