发表于 2015-8-18 10:57:14
显示全部楼层
回复 34# 西风醉雨
Hi , I am sorry the computer I am using now cannot type Chinese. In the figure you show the CMR curve, it is dB(VOUT). if the output is differential, should it be dB(VOUT)-dB(VOUTB)? Anyway, I am assuming now you are working on substitute the ideal CMFB to transistor level circuit. Good luck;-)
Best,
Ying |
