楼主: min4max
Cadence IC616等套件以及Calibre2013的正规设置及使用,另附Jake Baker的教科书
发表于 2015-7-9 12:37:19 | 显示全部楼层
厉害 学习了 给力啊
发表于 2015-7-15 17:16:13 | 显示全部楼层
厉害厉害啊
发表于 2015-7-16 16:55:19 | 显示全部楼层
回复 1# min4max
   我的cadence套件是IC616,ASSURA41,MMSIM141,PVS151,EXT151。请问运行QRC时为什么会出现如下错误?   *WARNING* QRC_HOME environmental variable is set but UI can't locate correct QRC installation.          In order to run UI in QRC compatibility mode you need to have QRC executables in your $PATH and QRC version should be 8.1 or greater.
          Check your QRC installation and environmental settings.
发表于 2015-7-16 16:55:56 | 显示全部楼层
谢谢分享。
发表于 2015-7-16 16:56:34 | 显示全部楼层
回复 7# YULONGUTK
请教一下   我的cadence套件是IC616,ASSURA41,MMSIM141,PVS151,EXT151。请问运行QRC时为什么会出现如下错误?   *WARNING* QRC_HOME environmental variable is set but UI can't locate correct QRC installation.          In order to run UI in QRC compatibility mode you need to have QRC executables in your $PATH and QRC version should be 8.1 or greater.
发表于 2015-7-18 16:16:42 | 显示全部楼层
thanks!!!!
发表于 2015-7-18 16:26:18 | 显示全部楼层
 楼主| 发表于 2015-7-19 23:02:50 | 显示全部楼层
回复  min4max
   我的cadence套件是IC616,ASSURA41,MMSIM141,PVS151,EXT151。请问运行QRC时为什 ...
lowby 发表于 2015-7-16 16:55
    license和设置不正确。参阅我的最新更正与更新教程:http://bbs.eetop.cn/thread-479940-1-1.html 将其中所有链接的教程都通读一下
发表于 2015-7-25 16:19:38 | 显示全部楼层
楼主在吗?教程里面那个patch适合对IC616、MMSIM14等进行patch吗?还是只能对IC616进行patch??
 楼主| 发表于 2015-7-25 21:46:36 | 显示全部楼层
xy131368 发表于 2015-7-25 16:19
    适用于Cadence的所有工具套件!
GMT+8, 2025-9-6 05:42 , Processed in 0.015976 second(s), 3 queries , Gzip On, Redis On.
