发表于 2017-2-18 08:21:57
显示全部楼层
回复 chenqiwei
首先,设计规则给的是voltage range,应该是工作电压范围,并不是耐压范围,跟击穿 ...
ygyg100 发表于 2015-1-9 10:15
那一般 UHV 500V DEVICE 看过上面绕 poly , 是POLY 电阻可以使用高压 500V吗?
Nitrogen implanted polysilicon resistor for high-voltage CMOS technology application
Characteristics and Breakdown Behaviors of Polysilicon Resistors for High Voltage Applications
[size=+1] ULTRAHIGH VOLTAGE RESISTOR, SEMICONDUCTOR DEVICE, AND THE MANUFACTURING METHOD THEREOF
United States Patent Application 20160181351 Kind Code:
A1 |
