查看: 6318|回复: 23
[原创] 国外某IC公司,要求做电路的RULES
发表于 2014-12-4 11:13:46 | 显示全部楼层 |阅读模式
Designer rules.docx (13.87 KB , 下载次数: 221 )
某IC外企要求DESIGNER 设计和REVIEW的RULES
发表于 2014-12-4 13:19:50 | 显示全部楼层
-49.588mm
发表于 2014-12-4 13:25:10 | 显示全部楼层
看不懂。。。
发表于 2014-12-4 14:01:03 | 显示全部楼层
Designer rules
Here is a typical CDR checklist. This will help you remember all the typical simulation required for the block level design review. Note that all of them required are not required for every block, you need to choose as per the need of the block.
1        Agenda/Problem statement
2        Applications Block diagram and background
3        Electrical Specification Table (include environmental and datasheet parameters)
4        Critical Parameters
5        Test Schematic/Bench, include parasitic where required
6        Circuit Schematic  (Display innovation, Identify critical matching and Discuss challenges)
7        Typical simulation results
8        Circuit with Back annotation voltages
9        AC/DC/Transient simulation, as required
10        EN=0V simulations, to check for no floating nodes
11        Startup simulation
12        Worst Case Simulation and assumption discussion  (corner and mismatch)
13        Fault Mode Discussions
14        Statistical Analysis (Cpk discussion)
15        Process and/or PCM sensitivity analysis / discussion
16        Trim discussion (if any)
17        ATE/Test coverage info
18        Reliability Concerns
19        IP Opportunities discussion
20        Reuse list and assumptions
21        Layout / Size Discussion (critical nets / size / shape)
22        Conclusion (meets spec or did not meet spec)
23        Action Item review, including owners and implications to product
发表于 2014-12-4 15:33:11 | 显示全部楼层
谢谢了
发表于 2014-12-5 12:53:00 | 显示全部楼层
谢谢啦!
发表于 2014-12-5 13:52:09 | 显示全部楼层
感謝樓主分享
发表于 2014-12-5 14:37:28 | 显示全部楼层
感謝樓主分享
发表于 2014-12-5 14:39:00 | 显示全部楼层
Designer rules
发表于 2014-12-5 15:03:01 | 显示全部楼层
这算不算公司机密啊???
GMT+8, 2025-10-29 12:25 , Processed in 0.021302 second(s), 6 queries , Gzip On, Redis On.
