在skew_opt命令中有几个选项不是太明白:1:-adjustment_limit val,use guide 是这样说的By default, there is no limit to the amount of latency adjustment that can be made. To limit the amount of latency adjustment, specify the -adjustment_limit option.意思就是说控制adjustment latency的数量的。但是man page上说的就让人不理解了,这个选项能解释一下吗?
2:-decrease_factor val,这个选项看man 更是一头雾水。
3:-improvement_threshold val ,user guide上是这样讲的,If you want to generate a script only if the worst negative slack (WNS) improves by a certain amount,specify the -improvement_threshold option.意思好像是说当WNS被一定数量的adjustment latency提高时指定该项,具体该怎么理解,这些选项都该指定什么样的值呢 |
