查看: 4879|回复: 11
[求助] Error when launch icfb in CentOS
发表于 2014-8-21 22:57:29 | 显示全部楼层 |阅读模式
i installed cadence IC5141 USR6 on centos6.5 x64 bitwhen i open Analog environment cadence stop working
and this is my .bashrc file
[Code]
CDS_ROOT = / usr / local / IC5141 CDS_INSTALL_PATH = $ CDS_ROOT / tools / dfII export CDS_LIC_FILE = $ CDS_ROOT / Share / license / license.dat export PATH = $ PATH: $ CDS_ROOT / tools / bin: $ CDS_INSTALL_PATH / bin: $ CDS_ROOT / tools / specter / bin export PATH = $ PATH: / bin: / etc:.: / usr / local / bin: / usr / openwin / bin: / usr / X11R6 / bin: / usr / bin: / usr / ucb export CDS_WAVESCAN_JRE_DIR = $ CDS_ROOT / tools / jre1.42 export MALLOC_CHECK = 0 export CDS_Netlisting_Mode = Analog
[/ code]
发表于 2014-8-21 23:22:24 | 显示全部楼层
回复 1# Islam2014
any other error message?I use IC5141USR6 in centOS 5.10 x64, it is worked.
 楼主| 发表于 2014-8-21 23:27:27 | 显示全部楼层
Reply 2 # x81717
   no error mesaages , it is just stop working
发表于 2014-8-21 23:40:51 | 显示全部楼层
post the file cds.log~~
 楼主| 发表于 2014-8-22 00:00:21 | 显示全部楼层
Reply 4 # snk88
    CDS.log.rar (2.02 KB , 下载次数: 3 )
发表于 2014-8-22 00:11:50 | 显示全部楼层
回复 5# Islam2014
it   looks normal except some warning.try to comment lines about  sonet and ads  of  .bashrc
 楼主| 发表于 2014-8-22 00:16:55 | 显示全部楼层
Reply 6 # snk88
   it also doesn't work
发表于 2014-8-22 00:19:17 | 显示全部楼层
回复 7# Islam2014
   ╮(╯_╰)╭good night
 楼主| 发表于 2014-8-22 00:21:40 | 显示全部楼层
Reply 8 # snk88
    Thanks for your time )
发表于 2014-8-22 00:43:30 | 显示全部楼层
cent os , need some per-request packages to load icfb in proper way
GMT+8, 2025-11-15 00:28 , Processed in 0.018259 second(s), 4 queries , Gzip On, Redis On.
