查看: 4133|回复: 5
请教这是什么问题?
发表于 2014-4-24 16:20:45 | 显示全部楼层 |阅读模式
[hnxu@missile ~]$ lmgrd -c /home/hnxu/synopsys_2013/license/synopsys.dat -l ~/syn_lic.log
[hnxu@missile ~]$ lmstat -c /home/hnxu/synopsys_2013/license/synopsys.dat
lmstat - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
Flexible License Manager status on Thu 4/24/2014 16:02
License server status: 27000@localhost.localdomain
    License file(s) on localhost.localdomain: /home/hnxu/synopsys_setup_2013/synopsys.dat:
localhost.localdomain: license server UP (MASTER) v10.8
Vendor daemon status (on localhost.localdomain):
   snpslmd: The desired vendor daemon is down. (-97,121)
[hnxu@missile ~]$ dc_shell
Unable to obtain feature 'Design-Compiler ' because:
Error: Cannot open key file '/home/hnxu/synopsys_2013/DC/admin/license/key' or a licensing environment parameter has not been set correctly. (SEC-2)
Fatal: Design-Compiler is not enabled. (DCSH-1)
 楼主| 发表于 2014-4-24 17:08:29 | 显示全部楼层
找到了,重启license manager
发表于 2014-6-6 17:12:30 | 显示全部楼层
回复 2# atlandis
   lmdown 之后再lmgrd -c 吗
 楼主| 发表于 2014-6-7 14:44:49 | 显示全部楼层
回复 3# lirongxuan
   恩呀,是的
发表于 2021-12-7 18:48:50 | 显示全部楼层
lirongxuan 发表于 2014-6-6 17:12
回复 2# atlandis
请问 ,用setenv LM_LICENSE_FILE 27000@servername
这个方式来check 的 license  怎么制作?
我制作的license  好像 只能 setenv LM_LICENSE_FILE ${SNPS_HOME}/license/Synopsys.dat 这样设环境变量才行。
发表于 2023-1-27 15:17:23 | 显示全部楼层
想询问一下大佬,重启之后为什么显示error,问题报错好像也不是sentaurus的lincense端口冲突
ERROR: license files have conflicting port numbers
2:37:08 (lmgrd)    5280 and 7367
2:37:08 (lmgrd)     Please edit the license files so the port numbers
2:37:08 (lmgrd)     on the SERVER line are identical.
2:37:08 (lmgrd)     License files include: /usr/eda/mathworks/license.dat 5280@eda3 7367@eda3 7377@eda3 28001@eda3 /usr/eda/altera/altera-eda3.dat /usr/eda/arm/rvds4.0/rvds-eda3.dat
GMT+8, 2025-11-4 10:09 , Processed in 0.016430 second(s), 6 queries , Gzip On, Redis On.
