登录 注册
手机短信,快捷登录
查看: 24500|回复: 22
安装SYNOPSYS LICENSE 报错,请专家帮忙!
发表于 2014-3-28 07:48:07 | 显示全部楼层 |阅读模式
5:43:44 (lmgrd) -----------------------------------------------
5:43:44 (lmgrd)   Please Note:
5:43:44 (lmgrd)
5:43:44 (lmgrd)   This log is intended for debug purposes only.
5:43:44 (lmgrd)   In order to capture accurate license
5:43:44 (lmgrd)   usage data into an organized repository,
5:43:44 (lmgrd)   please enable report logging. Use Flexera Software, Inc.'s
5:43:44 (lmgrd)   software license administration  solution,
5:43:44 (lmgrd)   FLEXnet Manager, to  readily gain visibility
5:43:44 (lmgrd)   into license usage data and to create
5:43:44 (lmgrd)   insightful reports on critical information like
5:43:44 (lmgrd)   license availability and usage. FLEXnet Manager
5:43:44 (lmgrd)   can be fully automated to run these reports on
5:43:44 (lmgrd)   schedule and can be used to track license
5:43:44 (lmgrd)   servers and usage across a heterogeneous
5:43:44 (lmgrd)   network of servers including Windows NT, Linux
5:43:44 (lmgrd)   and UNIX. Contact Flexera Software, Inc. at
5:43:44 (lmgrd)   www.flexerasoftware.com for more details on how to
5:43:44 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
5:43:44 (lmgrd)   for your enterprise.
5:43:44 (lmgrd)
5:43:44 (lmgrd)
5:43:44 (lmgrd)
5:43:44 (lmgrd) The license server manager (lmgrd) running as root:
5:43:44 (lmgrd)     This is a potential security problem
5:43:44 (lmgrd)     and is not recommended.
5:43:44 (lmgrd) FLEXnet Licensing (v11.10.0.3 build 96543 x64_lsb) started on hypersilicon02 (linux) (3/27/2014)
5:43:44 (lmgrd) Copyright (c) 1988-2011 Flexera Software, Inc. All Rights Reserved.
5:43:44 (lmgrd) US Patents 5,390,297 and 5,671,412.
5:43:44 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
5:43:44 (lmgrd) License file(s): /home/user01/synopsys/Synopsys.dat
5:43:44 (lmgrd) lmgrd tcp-port 27000
5:43:44 (lmgrd) Starting vendor daemons ...
5:43:44 (lmgrd) Started snpslmd (internet tcp_port 57973 pid 2731)
5:43:44 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 x64_lsb
5:43:44 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
03/27/2014 05:43:44 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.7
5:43:45 (lmgrd) snpslmd exited with status 0 signal = 17
5:43:45 (lmgrd) Since this is an unknown status, license server
5:43:45 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
5:43:45 (lmgrd) REStarted snpslmd (internet tcp_port 57658 pid 2924)
5:43:45 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 x64_lsb
5:43:45 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
03/27/2014 05:43:45 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.7
5:43:45 (lmgrd) REStarted snpslmd (internet tcp_port 54467 pid 3010)
5:43:45 (lmgrd) REStarted snpslmd (internet tcp_port 45081 pid 3097)
5:43:45 (lmgrd) REStarted snpslmd (internet tcp_port 40309 pid 3183)
5:43:45 (lmgrd) REStarted snpslmd (internet tcp_port 50221 pid 3271)
5:43:45 (lmgrd) REStarted snpslmd (internet tcp_port 56587 pid 3357)
5:43:45 (lmgrd) REStarted snpslmd (internet tcp_port 51762 pid 3454)
5:43:45 (lmgrd) REStarted snpslmd (internet tcp_port 57934 pid 3543)
5:43:45 (lmgrd) REStarted snpslmd (internet tcp_port 50157 pid 3629)
5:43:45 (lmgrd) REStarted snpslmd (internet tcp_port 58212 pid 3715)
5:43:46 (lmgrd) snpslmd exited with status 0 signal = 17
5:43:46 (lmgrd) Please correct problem and restart daemons
发表于 2014-3-28 11:26:53 | 显示全部楼层
license不对吧
发表于 2014-3-28 13:11:57 | 显示全部楼层
用scl11.5试试
发表于 2014-3-28 13:30:39 | 显示全部楼层
打命令:lmhostid是多少,如果是0000000000,不是自己MAC,请改掉网卡名字。
发表于 2014-3-28 15:26:37 | 显示全部楼层
如果是64位系统,改lic的  DAEMON snpslmd 指向64位的snpslmd,一般就ok了
发表于 2014-3-29 00:04:51 | 显示全部楼层
不要用root
 楼主| 发表于 2014-3-29 18:26:16 | 显示全部楼层
hostid 和sshostid 显示均为000000000000,  另外看不到Eth0,   只有em1,em2,em3,em4,em5,em6. 但上网正常
发表于 2014-3-29 19:40:46 | 显示全部楼层
回复 7# scsi
   1、在grub里增加biosdevname=0的启动参数,形如
kernel /vmlinuz-2.6.32-131.21.1.el6.i686 ro root=/dev/mapper/vg_test-lv_root rd_LVM_LV=vg_test/lv_root rd_LVM_LV=vg_test/lv_swap rd_NO_LUKS rd_NO_MD rd_NO_DM LANG=en_US.UTF-8 SYSFONT=latar
cyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=us crashkernel=auto rhgb quiet biosdevname=0
2、删除udev的配置文件rm -f /etc/udev/rules.d/70-persistent-net.rules
3、把网卡配置文件改名
mv ifcfg-em1 ifcfg-eth0
4、把网卡配置文件内容修正,把em1的全部改成eth0
可以使用 perl -p -i -e 's/em1/eth0/g' ifcfg-eth0 或sed -i 's/em1/eth0/g' ifcfg-eth0 进行替换。
5、重启系统即可.
发表于 2014-11-12 17:19:06 | 显示全部楼层
有用,顶一下!!!
发表于 2015-6-26 16:08:05 | 显示全部楼层
回复 4# sjsware
请问怎么改
GMT+8, 2026-2-17 09:32 , Processed in 0.138941 second(s), 6 queries , Gzip On, Redis On.
