查看: 44511|回复: 111
怒了,sentaurus 2010(32/64),2012(32/64),2013(64),破解、安装器与最新src 百度盘
发表于 2013-12-5 10:59:15 | 显示全部楼层 |阅读模式
64位用户首选2013,32位用户首选2012;这两个版本用rhel6平台最适合内含installer,scl(32、64),三个版本通用的license maker(packs文件件下的src就是最新的,基于论坛里的2013破解方法,加入两个新feature)
三个版本通用破解方法:http://bbs.eetop.cn/viewthread.php?tid=418143&extra=&page=1 注意更新一下src文件,同样适用其他synopsys软件(medici除外)
2010的可靠破解方法:http://bbs.eetop.cn/thread-371758-1-1.html
2012版本之前通用破解方法:http://bbs.eetop.cn/viewthread.php?tid=366602&rpid=7448388&ordertype=0&page=22#pid7448388
sentaurus.rar (123 Bytes , 下载次数: 884 )
顺应网盘分享潮流!!!
发表于 2013-12-5 11:25:48 | 显示全部楼层
收藏,楼主多怒了!
发表于 2013-12-5 13:03:41 | 显示全部楼层
还是网盘好啊!
发表于 2013-12-5 18:35:30 | 显示全部楼层
多谢楼主分享!
发表于 2013-12-6 08:27:17 | 显示全部楼层
多谢楼主分享!
发表于 2013-12-7 01:52:43 | 显示全部楼层
谢谢楼主分享!
发表于 2013-12-8 14:57:48 | 显示全部楼层
回复 1# qfliuyang
请问楼主:启动lmgrd时
   /Desktop/2013/amd64/bin/lmgrd: /lib64/ld-lsb-x86-64.so.3: bad ELF interpreter: No such file or directory 是神马原因啊?
 楼主| 发表于 2013-12-9 12:35:05 | 显示全部楼层
回复 7# hqjian
Solution: Check your system whether LSB is installed by running
   $ lsb_release
on any shell. If it returns info about LSB packages  (core-3*, graphics-3*, desktop-3*, cxx-3* etc.), your system may be LSB 3 compliant. Addationally you could check whether the lsb linker/loader shared library is present on your system, for example:
   $ ls -al /lib64/ | grep linux
   lrwxrwxrwx 1 root root 9 Oct 17 11:07 ld-linux-x86-64.so.2 -> ld-2.5.so
If the LSB linker/loader shared library ls-lsb-x86-64.so.3 is not present, add LSB support to your operating system. As a quick workaround you may create the LSB linker/loader library manually as a symblic link to the Linux dynamic linker/loader library, for example (requires (sudo) root rights):
   # ln -s /lib64/ld-linux-x86-64.so.2 /lib64/ld-lsb-x86-64.so.3
发表于 2013-12-9 13:45:47 | 显示全部楼层
謝謝您的分享!!
发表于 2013-12-9 20:12:12 | 显示全部楼层
回复 8# qfliuyang
    THX !!lmgrd已经可以启动了。
但是又出现一个问题,GENESISe: error while loading shared libraries: libXaw.so.7: cannot open shared object file: No such file or directory
GMT+8, 2025-12-8 09:30 , Processed in 0.023105 second(s), 5 queries , Gzip On, Redis On.
